Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM 10.5 upgrade and Gateways
zoro072011
Hi All,
I am upgrading to cucm 10.5, my question is there any configuration need to be done in the gateways before the upgrade, or i can use same config while the ip address still the same?
2 Accepted Solutions
Hi zoro072011,
 you are welcome. Can I consider this question answered? Do you need any more info?
Regards.
6 Replies 6
 you can use the same config while the IP Address still the same.
Hope this helps.
Yes everything will be the same accept we adding E.164 dial plane, I do not need to configure anything for that in the gateways, do I?
Hi zoro072011,
 your gateway is MGCP or H.323?
 If it is MGCP then you only need to make changes in CUCM, but if it is H.323 you must make changes in CUCM and in the gateway.
Regards.
Hi Marcelo,
My Gateway is MGCP, thanks so much
Hi zoro072011,
Regards.
