I'm trying to find out if LDAP authentication support Kerberos. In the SRND 10.x it says the following:
" LDAP Synchronization is supported only with Microsoft NT LAN Manager (NTLM). Kerberos and NTLMv2 are not supported."
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/directry.html
But don't know if this also applies to LDAP Authentication and the IMS library. Furthermore authentication use LDAP standard Simple_Bind operation, does this mean CUCM will send in clear text the username/password? (uncheck Use SSL)
Note: no plans in the near future to configure SSO
Please let me know.
