CUCM 10 DTMF not working when outgoing call using FAC
Tommy .
Hi all ,
I have Installed CUCM 10  in BE6K , but when I settin route pattern for outgoing call , when using FAC , any call that need DTMF , the DTMF is not responding , but when outgoing call not using FAC , DTMF working perfectly fine .
voice gateway using MGCP with FXO.  I have tested all ports FXO but working fine when used without FAC , when using FAC DTMF not responding.
CUCM version 10.0.1.10000-24
any help please ?
Tommy
2 Accepted Solutions
Rob Huffman
Hi Tommy,
It looks like you may be hitting this bug;
DTMF failure when FAC/CMC is enabled on route pattern
CSCun34848
Symptom:
When FAC/CMC is enabled at the route pattern level, DTMF will not work.
You get the following error after a digit is pressed by the IP Phone.
01509471.001 |22:05:21.251 |AppInfo |StationInit: (0000084) KeypadButton kpButton=8.
01509478.001 |22:05:21.251 |AppInfo |FacCmcManager::wait_SsUserInfoInd - route by party failed! ss=18210643
Conditions:
FAC/CMC should be enabled at the route pattern level
Workaround:
Do not use FAC/CMC
Last Modified:
Apr 4,2014
Status:
Fixed
Severity:
2 Severe
Product:
Cisco Unified Communications Manager (CallManager)
Support Cases:
Cheers!
Rob
yusuf habibi
yeahh i have problem too...DTMF not working if using FAC...very weird CUCM 10 buggie
Hi tommy, did u solve it ?
solving after upgrade patch version smiley
10.5(0.98000.520)
10.5(0.98000.312)
10.0(1.11006.1)
Regards, Habibi
10 Replies 10
Jaime Valencia
FAC is before you even try to route the call to any GW, it doesn't matter what you use to make the calls.
What phone are you using??
Is it directly registered to CUCM??
What's the call flow??
If you dial the FAC, and press # does it route the call???
java
if this helps, please rate
Phone type I'm using is 6941, CIPC, 7912
all phone directly registered to CUCM
call flow is
call 9XXXX --> enter FAC XXX --> call connected , BUT if the connected call have IVR , and must choose for any menu , when input digits , there is no respond at all . i have tried many call that have IVR but none working.
if call flow without FAC it is working fine .
Tommy.
Can you describe the full call flow including what devices it's going through?  You mention above an MGCP FXO port being part of the call flow.
6921 sccp --> route pattern --> call 9.XXX --> enter FAC XXX --> Route List (RL1) --> Route Group (RG1) in this route group i specify only to one FXO port --> Voice Gateway 2911 (MGCP Router with FXO)--> PSTN
Tommy
Could you please use the command debug mgcp packets and check whether you receiving any digit on the router when pressed for IVR menu.
Also check the DTMF config on the router and whether MRGL is applied to the MGCP router.
Please provide details if possible traces.
Rob Huffman
Hi Tommy,
CSCun34848
Symptom:
Conditions:
Workaround:
Do not use FAC/CMC
Last Modified:
Apr 4,2014
Status:
Fixed
Severity:
2 Severe
Product:
Support Cases:
Cheers!
Rob
Is CUCM cluster need to be restarted after install the device pack?
Hi Kelvin,
I don't believe that it's a Device Pack that needs to be installed to fix this issue but rather a full CUCM SR/Patch....
Known Fixed Releases:
(4)
10.5(0.98000.520)
10.5(0.98000.312)
10.0(1.11006.1)
10.5(1.10000.7)
It shows this bug as "fixed in" CUCM 10.0(1)SU2 smiley
From;
http://www.cisco.com/web/software/282074295/114809/cucm-readme-1001su2.pdf
Cheers!
Rob
Yea, I have upgraded to the CUCM 10.0(1)SU2 and the problem solve :D
yusuf habibi
10.5(0.98000.520)
10.5(0.98000.312)
10.0(1.11006.1)
Regards, Habibi
