04-24-2014 02:58 AM - edited 03-16-2019 10:33 PM
Hi All,
I have plan to install CUCM 10 in 2 sites :
- sites A : Publiser , Subscriber 1
- sites B : Subscriber 2 , Subscriber 3
When I Install in Sites A there is no problem , but when i Install in Sites B for Subscriber 2 and Subscriber 3 there is always this error :
I had try using ova template from different sites and installer , but no result ,
any help ?
Best Regards,
Tommy
Solved! Go to Solution.
04-24-2014 03:53 AM
Do check firewall for TCP and UDP ports usage by CUCM 10 .
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/port/10_0_1/CUCM_BK_T537717B_00_tcp-port-usage-guide-100.pdf
regds,
aman
04-24-2014 03:37 AM
Hi tommy,
make sure the SITE B able to reach the Publisher.
you can not adding subs if publisher unable reached your machine.
btw dont use version 10.0.1.1000-24 because it has bug for DTMF tones,a few day ago i have issue with that. bug(s): CSCun34848
Habibi
04-24-2014 03:47 AM
Hi Yusuf,
Site B are able to ping Publisher and , publisher also can ping site B
For CUCM Version I only have 10.0.1.11006-1 unbootable version from TAC , for CUCM 10 can we extract the boot loader to unbootable version ?
Best Regards,
Tommy
04-24-2014 04:44 AM
Hi Tommy,
did you already upgrade to the fixed version on pub & sub 1 ?
if you already upgrade from v10.0.1.10000-24 to v10.0.1.11006.1 on publisher & sub1, before you install subs 2 & 3, you must install first cucm v10.0.1.10000-24 and then you choose the patch menu when the starting CUCM installer. and then you put the ISO fixed version v10.0.1.11006.1 into DVD.
some error interrupt when installing the secondary node on cucm because the primary node having 2 version active & incative CUCM after doing upgraded. you need make it same version on secondary node.
you can contact me with YM : biemabbit
to make sure this problem clearly :)
Habibi
04-24-2014 03:53 AM
regds,
aman
04-27-2014 08:13 PM
Hi Aman
Thanks for the suggestions , I have checked the network and find out that there is some blocked ports in firewall .
Best Regards,
Tommy
