690
Tommy .
Beginner
CUCM 10 Install Subscriber Error
Hi All,
I have plan to install  CUCM 10 in 2 sites :
- sites A : Publiser , Subscriber 1
- sites B : Subscriber 2 , Subscriber 3
When I Install in Sites A there is no problem , but when i Install in Sites B for Subscriber 2 and Subscriber 3 there is always this error :
I had try using ova template from different sites and installer , but no result ,
any help ?
Best Regards,
Tommy
1 ACCEPTED SOLUTION
Do check firewall for TCP and UDP ports usage by CUCM 10 .
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/port/10_0_1/CUCM_BK_T537717B_00_tcp-port-usage-guide-100.pdf
regds,
aman
5 REPLIES 5
yusuf habibi
Beginner
Hi tommy,
make sure the SITE B able to reach the Publisher.
you can not adding subs if publisher unable reached your machine.
btw dont use version 10.0.1.1000-24 because it has bug for DTMF tones,a few day ago i have issue with that. bug(s): CSCun34848
Habibi
Regards, Habibi
Hi Yusuf,
Site B are able to ping Publisher and , publisher also can ping site B
For CUCM Version I  only have 10.0.1.11006-1 unbootable version from TAC , for CUCM 10 can we extract the boot loader to unbootable version ?
Best Regards,
Tommy
Hi Tommy,
did you already upgrade to the fixed version on pub & sub 1 ?
if you already upgrade from v10.0.1.10000-24 to v10.0.1.11006.1 on publisher & sub1, before you install subs 2 & 3, you must install first cucm v10.0.1.10000-24 and then you choose the patch menu when the starting CUCM installer. and then you put the ISO fixed version v10.0.1.11006.1 into DVD.
some error interrupt when installing the secondary node on cucm because the primary node having 2 version active & incative CUCM after doing upgraded. you need make it same version on secondary node.
you can contact me with YM : biemabbit
to make sure this problem clearly :)
Habibi
Regards, Habibi
regds,
aman
Tommy .
Beginner
Hi Aman
Thanks for the suggestions , I have checked the network and find out that there is some blocked ports in firewall .
Best Regards,
Tommy
Create
Recognize Your Peers
Content for Community-Ad
