CUCM 10.X: manipulating called number based on calling number
raziel78kain
Explorer
Explorer
we have a CUCM 10.X, and we would like to know if we can get this kind of manipulation: if the calling number XXXX calls 3000, the real called number is 4000XXXX.
That is, we would like to manipulate the called number based on the calling number.
Is it possible to get that with only the CUCM?
TIA and regards.
16 REPLIES 16
Dennis Mink
Advisor
Advisor
Use translation  patterns for this. probably the easiets way to achieve it.
Please remember to rate useful posts, by clicking on the stars below.
Hello Dennis,
what we would like to get is to translate the called number based on the calling number. Is it possible with a regular translation pattern?
Regards.
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Are you looking to change the caller ID only when 3000 is called from any phone or specific phones in specific range?
Hello Chris,
here's some examples to be more clear:
  • if if the calling number 2000 calls 3000, the real called number is 40002000;
  • if the calling number 2001 calls 3000, the real called number is 40002001;
  • if the calling number 2999 calls 3000, the real called number is 40002999.
In other words, as written in the first post: if the generic calling number XXXX calls 3000, the real called number has to be 4000XXXX.
Regards.
OK, is this only required when 3000 is called or a specific range or all other internal numbers?
