Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
1. Use Extension Mobility - Each user will have his phone profile which his DNs. The profile will be access with userID and PIN 2. If you need to protect call routing only, you can create per-user FAC PIN. Each user will be requested a PIN when match a route pattern with FAC enabled. Only users higher than required authorization level will be able to make calls. You can generate CDR report from CAR which includes FAC PIN and that way you findout who is calling what.
Learn, share, save
