a80386dx25iv
Beginner
CUCM 11.05 Multiply Servers Detected
Hello.
I try to install CUCM 11.05 onto KVM. I moved
mv Cisco/hssi/server_implementation/KVM/QEMU/shared/bin/api_implementation.sh.proposed to Cisco/hssi/server_implementation/KVM/QEMU/shared/bin/api_implementation.sh
and repuild ISO.
mkisofs -R -J -D -v -d -N -no-emul-boot -boot-load-size 4 -boot-info-table -b isolinux/isolinux.bin -c isolinux/boot.cat -o cucm11.iso /cucm11
 Create VM
virt-install --name cucm11 --vcpu 2 --ram 4096 --virt-type kvm --os-type linux --os-variant rhel6 --cdrom ./cucm11.iso --disk ./cucm.img,size=240,bus=virtio --machine pc-1.3 --noautoconsole
When I try to install it I see a lot of "Multiply Servers Detected"
And then: Avlidation error on HSSI mode:
HSSI implementation error !!!
Detected multiple server's: OpenStack
 What wrong?
1 REPLY 1
Jaime Valencia
Hall of Fame Cisco Employee
You're trying to install this on a NOT supported virtualization option, there is really no way to tell you what behavior, or what to expect from what you're doing, and hence, also no way to tell you how to fix it.
java
if this helps, please rate
Content for Community-Ad
Spotlight Awards 2021
