CUCM 11.5.1 & Microsoft Active Directory 2016
Slavi
Hey Guys,
is it possible to integrate a Callmanager 11.5.1 with a MS AD 2016?
I cannot find a Compatiblity Matrx for this.
And if it doesn´t works, is there a solution for this Problem? Our Customer only has AD 2016 ...
Thanks!
Chris Deren
2016 is not officially supported on CUCM 11.5, see page 255:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/sysConfig/11_5_1_SU1/cucm_b_system-configuration-guide-1151su1.pdf
Supported LDAP Directories
Cisco Unified Communications Manager supports synchronization with the following LDAP directories: Microsoft Active Directory 2003 R1/R2 (32-bit)
Microsoft Active Directory 2008 R1 (32-bit) / R2 (64-bit)
Microsoft Active Directory Application Mode 2003 R1/R2 (32-bit)
Microsoft Active Directory 2012
Microsoft Lightweight Directory Services 2008 R1(32-bit) / R2(64-bit) Microsoft Lightweight Directory Services 2012
Sun ONE Directory Server 7.0
Open LDAP 2.3.39
Open LDAP 2.4
Oracle Directory Server Enterprise Edition 11gR1
Other LDAPv3 Compliant Directories
5 Replies 5
Chris Deren
Open LDAP 2.3.39
Open LDAP 2.4
Just to add to Chris' reply, AD 2106 is supported with CUCM 12.0
java
if this helps, please rate
It seems the document was updated, because now, in the page 259, we have the following:
• Microsoft Active Directory 2003 R1/R2 (32-bit)
• Microsoft Active Directory 2008 R1 (32-bit) / R2 (64-bit)
• Microsoft Active Directory Application Mode 2003 R1/R2 (32-bit)
• Microsoft Active Directory 2012
• Microsoft Active Directory 2016
• Microsoft Lightweight Directory Services 2008 R1(32-bit) / R2(64-bit)
• Microsoft Lightweight Directory Services 2012
• Sun ONE Directory Server 7.0
• Open LDAP 2.3.39
• Open LDAP 2.4
• Oracle Directory Server Enterprise Edition 11gR1
• Other LDAPv3 Compliant Directories
Link:
Indeed, it was updated with the latest SU.
java
Hello Jaime,
So we can say that AD 2016 is only supported with CUCM 11.5 SU5?
I can't find info about the AD compatibility for other CUCM 11.5 versions.
Lara
