You are getting secondary dial-tone after 4-th digit, this is expected after entering off-net access code, i.e. 9. This means you have patterns (i.e. route patterns, translation patterns) enabled for "provide outside dial tone" which overlap with patterns/DNs that do not. If you desire secondary dial tone after off-net access code you need to enable it only on patterns starting with the off-net code and disable it on all others i.e. XXXX, [2-9]XXXXXXX, etc.
Learn, share, save
