04-12-2017 09:09 AM - edited 03-18-2019 12:13 PM
I have an LDAP feed setup to import users from an OU. I have created an applied a feature group template that "checks" the home cluster option as well as the Enable users for unified CM IM & Presence. When I run the LDAP sync it will not apply those settings to the user.
Any ideas as to why? this user was already on the CUCM from a different feed.
RB
Solved! Go to Solution.
04-12-2017 09:17 AM
If the user was already in CUCM, and then you change the template, those changes do not replicate to existing users, they will only be applied to new users.
04-12-2017 09:17 AM
04-12-2017 09:20 AM
Crap. That is what I was afraid of. How do I work around this? I already have about 13000 employees who need to updated. BAT tool?
04-12-2017 10:03 AM
Yes, you'd need to use BAT to change that setting
01-22-2021 06:42 AM
When using the BAT tool, I get an error saying "LDAP Sync status is enabled. Some fields cannot be updated." I'm only trying to update 2 fields for "Enable User for Unified CM IM" - set to true and "UC Service Profile" name. So how do you update existing users?
