CUCM 11.5 LDAP Sync failed
Slavi
Hey Guys,
I have a LDAP sync problem at our customer and i can´t find the Problem.
Can you please tell me what the logs mean?
Thanks a lot!
I´ve added the Errorlog output:
2017-11-10 03:15:00,009 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:124) - DSLDAPMain[handleIncomingReq] Sync agreement 54c43f99-a561-4f3a-868d-26a5547445d9 is not available in database....exit
2017-11-11 00:00:00,026 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:320) - DSLDAPMain[handleIncomingReq] Directory type is null
2017-11-11 00:00:00,027 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:331) - DSLDAPMain[handleIncomingReq] Parameter validation failed on sync agreement-dd5ec04b-4890-c76c-fc4c-285b76212582
2017-11-11 03:15:00,009 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:124) - DSLDAPMain[handleIncomingReq] Sync agreement 54c43f99-a561-4f3a-868d-26a5547445d9 is not available in database....exit
2017-11-12 03:15:00,021 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:124) - DSLDAPMain[handleIncomingReq] Sync agreement 54c43f99-a561-4f3a-868d-26a5547445d9 is not available in database....exit
2017-11-13 03:15:00,008 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:124) - DSLDAPMain[handleIncomingReq] Sync agreement 54c43f99-a561-4f3a-868d-26a5547445d9 is not available in database....exit
2017-11-13 08:14:25,808 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:320) - DSLDAPMain[handleIncomingReq] Directory type is null
2017-11-13 08:14:25,808 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:331) - DSLDAPMain[handleIncomingReq] Parameter validation failed on sync agreement-dd5ec04b-4890-c76c-fc4c-285b76212582
2017-11-13 08:15:22,699 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:320) - DSLDAPMain[handleIncomingReq] Directory type is null
2017-11-13 08:15:22,699 ERROR [DSLDAPMain] dirsync.DSLDAPMain (DSLDAPMain.java:331) - DSLDAPMain[handleIncomingReq] Parameter validation failed on sync agreement-dd5ec04b-4890-c76c-fc4c-285b76212582
6 Replies 6
Seems that there is a change in the LDAP configuration either at cucm or ad
server which is causing the problem. Look an re-validate.
Hi  Mohammed,
thanks for your reply.
It is ja complete new Callmanager Installation and its the first LDAP Sync that fails.
It is never been synced before.
Greetings
Silly question, where are the LDAP related logs found?  I am having LDAPS issues right now and trying to verify it is a firewall issue.
Marco Lin
Hi, I fall in same issue, any idea for fix ? thanks a lot.
Marco
Hello Marco,
the Problem is fixed.
It was a wrong Path of the Distingushed Name...
Greetings
Hi, Slavi,
Thanks for your reply, can I know what's version with your openldap integrate with cucm?
Marco
