09-27-2017 03:20 AM - edited 03-17-2019 11:15 AM
Hi!
I have a problem with logging to CUCM 11.5 on VMWare Workstation Pro.
When I try loggin to https://ip_address/ccmservice/ I have a CUCM message:
Log on failed - Invalid User ID or Password
I can logging to CLI and https://ip_address/cmplatform/ on that user ID and password.
Installation CUCM is fresh.
Someone help??
Best regards,
Kamil
Solved! Go to Solution.
09-27-2017 06:07 AM
Take a look on this doc, to reset your password:
It is used for the login on Cisco Unified CM Administration, Cisco Unified Serviceability, Cisco Unified Reporting pages and Real Time Monitoring Tool.
The Application User name must start with an alphabetic character, must be at least six characters long and can contain alphanumeric characters, hyphens and underscores.
Leonardo Santana
09-27-2017 06:28 AM - edited 09-27-2017 06:29 AM
Just to add, OS admin and application credentials could be different. if you know the Application administrator username given during install, then reset the password using the command by logging into CLI with the current working credentials you are using to login to OS admin page:
utils reset_application_ui_administrator_password
Rajan
Pls rate if helpful
09-27-2017 06:07 AM
Leonardo Santana
Rajan
Pls rate if helpful
