11-16-2017 12:51 AM - edited 03-17-2019 11:36 AM
What's the difference between SU3 & SU3a? I can't see anything obvious in the release notes. (In fact, the release notes only seem to talk about SU3)
Solved! Go to Solution.
11-16-2017 01:33 AM
Hi Gordon,
Traditionally people would feel SU are safer than ES, i think one of the major reason for that is SU goes through more rigorous testing while ES is more focused to fixing some specific broken code. Both SU3 & SU3a are spun of Base ES: 11.5.1.13032-3. We had to come up with 11.5(SU3a) because of the below Critical BUG introduced by 11.5(S3).
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf96778/?reffering_site=dumpcr
In bonus you also get two other BUG fixes in SU3a which are CSCvb43321 and CSCvf88802. No other reason for 11.5(S3)
Now see both relese notes
https://www.cisco.com/web/software/282074295/139049/cucm-readme-1151su3-Rev3.pdf
https://www.cisco.com/web/software/282074295/139933/cucm-readme-1151su3a-Respin.pdf
(Rate if it helps)
JB
11-16-2017 01:33 AM
Hi Gordon,
(Rate if it helps)
JB
11-16-2017 01:41 AM
Is BugID CSCvf88802 the one that was fixed by the ciscocm.APNS_PushFailure_v1.0.k3.cop.sgn file?
11-16-2017 01:55 AM
