Enthusiast
CUCM 11.5 WARNING: DNS unreachable
Hi Guys
I have a issue with the DNS: In the CUCM web admin, it show WARNING: DNS unreachable.
I have the follow tests:
Starting diagnostic test(s)
test - disk_space          : Passed (available: 1207 MB, used: 12475 MB)
skip - disk_files          : This module must be run directly and off hours
test - service_manager     : Passed
test - tomcat              : Passed
test - tomcat_deadlocks    : Passed
test - tomcat_keystore     : Passed
test - tomcat_connectors   : Passed
test - tomcat_threads      : Passed
test - tomcat_memory       : Passed
test - tomcat_sessions     : Passed
skip - tomcat_heapdump     : This module must be run directly and off hours
test - validate_network    : Reverse DNS lookup mismatch
test - raid                : Passed
test - system_info         : Passed (Collected system information in diagnostic
             log)
test - ntp_reachability    : Passed
test - ntp_clock_drift     : Passed
test - ntp_stratum         : Passed
skip - sdl_fragmentation   : This module must be run directly and off hours
skip - sdi_fragmentation   : This module must be run directly and off hours
03-01-2018 12:19:31 validate_network:     Hostname: [ANDROMEDA]
03-01-2018 12:19:31 validate_network:     found pub name [ANDROMEDA]
03-01-2018 12:19:31 validate_network:     result: 7, message: Reverse DNS lookup mismatch
show network eth0:
DNS
Primary      : 10.175.0.113       Secondary  : 10.175.0.40
Options      : timeout:5 attempts:2
admin:utils network ping 10.175.0.113
PING 10.175.0.113 (10.175.0.113) 56(84) bytes of data.
64 bytes from 10.175.0.113: icmp_seq=1 ttl=126 time=1.07 ms
64 bytes from 10.175.0.113: icmp_seq=2 ttl=126 time=1.00 ms
64 bytes from 10.175.0.113: icmp_seq=3 ttl=126 time=0.990 ms
64 bytes from 10.175.0.113: icmp_seq=4 ttl=126 time=1.19 ms
--- 10.175.0.113 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3014ms
rtt min/avg/max/mdev = 0.990/1.068/1.195/0.080 ms
admin:utils network ping 10.175.0.40
PING 10.175.0.40 (10.175.0.40) 56(84) bytes of data.
64 bytes from 10.175.0.40: icmp_seq=1 ttl=127 time=0.495 ms
64 bytes from 10.175.0.40: icmp_seq=2 ttl=127 time=0.845 ms
64 bytes from 10.175.0.40: icmp_seq=3 ttl=127 time=0.879 ms
64 bytes from 10.175.0.40: icmp_seq=4 ttl=127 time=0.742 ms
--- 10.175.0.40 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3001ms
rtt min/avg/max/mdev = 0.495/0.740/0.879/0.151 ms
Any idea?
TIA
Cristian
7 REPLIES 7
Advocate
Re: CUCM 11.5 WARNING: DNS unreachable
Look at this posting.
I do not see your domain in the "show network eth0" - output
https://supportforums.cisco.com/t5/ip-telephony/cucm-warning-dns-unreachable/td-p/2714928
Regards, Alex. Please rate useful posts.
Enthusiast
Dear Alex
It´s have DNS. I didn´t write.
Advocate
Participant
Your DNS server is reachable, make sure forward and reverse lookup entries in your DNS server are correct.
Forward Lookup
A cucm.local 10.10.10.10
Reverse Lookup
PTR 10.10.10.10 cucm.local
Please rate if found helpful
Aeby
Please rate if you find this helpful.
Aeby
Enthusiast
Dear Aeby
Thank you for your answer. I´m going to talk the DNS admin and try explaining it to him. Hard task is waiting for me.  :)
Highlighted
Contributor
The message
are showing a mismatch between reverse and forward dns record.
you can test the resolution with "nslookup"
setting the server an resolving the name and the ip address of the CUCM and vice versaCattura.PNGCMD prompt
Enthusiast
Dear Sandro
Thank you . I´m going to test and then comments the results.
Content for Community-Ad
July's Community Spotlight Awards
