09-05-2019 11:28 AM
Hi All
I have a problem.
I have a CUCM 11 and H323 PRI E1. For outgoing call, the follow message is show it:
Requested circuit/channel not available
Here a ISDN Q931 debug
Sep 5 14:33:37.771: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x3470
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '229793200'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '226928000'
Sep 5 14:33:37.855: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xB470
Sep 5 14:33:37.859: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xB470
Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep 5 14:33:37.871: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x3470
Cause i = 0x80AC - Requested circuit/channel not available
Sep 5 14:33:38.047: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xB470
Sep 5 14:33:38.051: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x347
TIA
Cristian
09-05-2019 12:43 PM
It can be several things but first, make sure the number of channels you have configured in your voice gw matches the number of channels you are purchasing from the Service Provider. If you have more channels in your voice gw than the service provider, eventually the voice gw will try to use a channel that is not in service on the Service Provider's end.
09-06-2019 04:04 AM
It's a long time since I used it but there's a configuration command to tell the Cisco whether to number B channels contiguously, ie from 1 to 30, or mapped directly to time slots ie 1-15 and 17-31. The convention needs to match the provider, otherwise any call for channel 16 or above will fair.
The command was "isdn contiguous-bchan" but you will need to check it still applies to your particular IOS.
