11-24-2015 06:20 AM - edited 03-17-2019 05:00 AM
With previous verions of CUCM you were able to assign a Line Template to the User Device Profile Template within BAT - i'm currently deploying CUCM 11 and this option is no longer available, it only allows you to add a Directory Number to the UDP Profile. If you assign a DN and then do an import the settings aren't mapped to the user's DN.
I know i can run further BAT updates on the line to resolve but its not ideal.
Is this a bug or has something changed in the way that UDP's are imported?
Thanks in advance.
Richard
12-13-2015 11:30 PM
I have the same problem.
Have you figured anything out yet?
12-14-2015 12:43 AM
Looks like a bug, I've not found anything else on it yet.
As a work around I had to import the UDP's with all details which was a bit of a pain but it works.
Create a single UDP with all the correct line settings then export it and use the .csv as a template
Hopefully this will get resolved in the next release.
