01-09-2018 03:49 AM - edited 03-17-2019 11:54 AM
I can't really find any topics about the new CUCM 12.0 branding feature yet. I have tried to set up a branding.zip file with the contents as specified in the guide, but CUCM throws the following error: "Error: Uploaded zip file is invalid. Please refer to help document for more details. "
The ZIP file has the following contents, as per the documentation:
/Branding/
/Branding/branding_logo.png
/Branding/ccmadmin/
/Branding/ccmadmin/brandingHeader.gif
/Branding/ccmadmin/BrandingProperties.properties
/Branding/ccmadmin/ciscoLogo12pxMargin.gif
The BrandingProperties.properties file has the following plain text format:
heading.heading.color="#FFFFFF" header.navigation.color="#FFFFFF" splash.hex.code.1="#A20067" splash.hex.code.2="#474498" splash.hex.code.3="#65318B" header.go.font.color="#FFFFFF" header.go.background.color="#FFFFFF" header.go.border.color="#FFFFFF" splash.username.color="#FFFFFF" splash.password.color="#FFFFFF" splash.login.text.color="#FFFFFF" splash.login.back.ground.color="#FFFFFF" splash.reset.text.color="#FFFFFF" splash.reset.back.ground.color="#FFFFFF" header.admin.color="#FFFFFF" header.hover.link.color="#FFFFFF" splash.header.color="#FFFFFF" splash.version.color="#FFFFFF"
Does anyone have any experience with this yet?
Ruud van Strijp
02-21-2018 01:57 AM
Hi Ruud,
I'm having the same problem. Which program are you using to create the zip branding file ?
Best Regards,
André Salgueiro
02-21-2018 07:38 PM
I assume you have seen this?
02-22-2018 11:50 AM
Hi @Dennis Mink,
Yes, I followed that guide, but at that time in my lab environment does not work.
Did you get it done ?
André
03-06-2018 02:31 AM
hello,
Any luck ?
I am also trying to append logo in self care portal.
but getting the same error when uploading branding.zip
03-06-2018 07:42 AM
05-16-2018 05:00 PM
Having the same issue. Found bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCve33080
Opened a TAC Case to see if documentation is incorrect, a bug or a workaround. Running 12.0(1)
05-16-2018 05:19 PM
TAC confirmed bug with no public release or workaround yet....
05-16-2018 10:59 PM
05-17-2018 03:38 AM
Thanks for the information!
Best Regards,
06-06-2018 07:53 AM
If these features are tested, it would be nice to know under what conditions they were so we can make sure it is not something we've done.
That's 0/3 on interesting CSR 12 features that don't work out of the box for me - and I thought we were over the ".0" release stigma. Guess not!
06-07-2018 01:33 AM
Nope, this 12.0 unfortunately is still 'beta' to me. Seeing there haven't been any SU's in over half a year shows me Cisco as totally abandoned this release as well and only focusses on 12.5.
I haven't deployed it at any customer yet, and I'm sad I deployed it in my lab since I feel like I'm behind on newer 11.5 SU4 fixes.
11-12-2019 05:48 AM
If anyone is still having the issue, make your Branding folder a lowercase "b". All of the documentation has a capital "b" but after doing some troubleshooting with TAC it seems as though CUCM 12.5 (at least) is looking for the lowercase "b".
02-26-2020 07:36 AM
I'm using CUCM 12.5(1)SU2
I tried to use "b" but it still not working!!
