04-14-2021 10:53 PM
Since the customer deployed SSM on-pre, we need to change the register on CUCM. But I am not sure what is the URL we need to enter on Transport Gateway. Every time I enter the token, it is saying timeout, I have attached the screenshot.
SSM on-pre web link: https://frdv03158:8443
Solved! Go to Solution.
05-20-2021 01:42 AM
A few more additional things came to mind. Do you have your on-prem SSM setup for HTTPS? If not try to use this url for the transport gateway, http://<FQDN of on-prem SSM>/Transportgateway/services/DeviceRequestHandler
You could also try to drop the :8443 part that you have in your URLs posted. We don't have that set on any of our systems that use SL.
12-22-2021 01:10 PM
This worked for me in offline mode on 22 DEC 2021
04-20-2021 07:22 PM
Anyone has the same problem?
04-21-2021 04:52 AM - edited 04-21-2021 04:55 AM
First off I would recommend you to remove the Answered state from your own answer as that would likely give you more attention to your question. Likely the flag that it's been answered might keep people away from reading your post, I know it did for me for a while anyway.
About the transport link, this is stated in the documentation for CM, so you should be able to find it there if you look for it. Never the less see the below url from one of our CMs for reference.
https://<FQDN of on-prem SSM>/Transportgateway/services/DeviceRequestHandler
04-23-2021 01:19 AM
Thanks Roger, I have tried both link, all got the same Communication Timeout like the screenshot I attached before.
https://frdv03158:8443/Transportgateway/services/DeviceRequestHandler
https://frdv03158>/Transportgateway/services/DeviceRequestHandler
04-23-2021 01:25 AM
That does not look like a proper FQDN, it looks like the host name. Can you verify via CLI that the CM can resolve the FQDN of the on-prem SSM?
04-23-2021 01:55 AM
ok, I have also tried the FQDN like below, the same. The PQDN can be resolved under CLI. Since the customer has left the office, I will try it on Chrome next week.
https://frdv03158.abc.com:8443/Transportgateway/services/DeviceRequestHandler
https://frdv03158.abc.com>/Transportgateway/services/DeviceRequestHandler
04-23-2021 01:26 AM
Second thing that I would try is to use any other browser than IE. It's a thing for the past that should be put in a drawer and never be seen again.
05-20-2021 12:25 AM
Sorry for delayed response, I have tried Chrome with this url.
but still not working, do you have any other idea for it?
thanks.
05-20-2021 01:34 AM
Can the CM resolve frdv03158.abc.com and can it communicate with the server? You can test this from CLI by utils network host <FQDN> and utils network ping <FQDN>.
05-20-2021 01:42 AM
05-21-2021 12:35 AM
Great, finally I found http://<FQDN of on-prem SSM>/Transportgateway/services/DeviceRequestHandler working.
I really appreciate your support, thank you very much.
05-21-2021 02:18 AM
Great that you got it to work. You might however want to look into setting your on-prem SSM up for HTTPS for security.
12-22-2021 01:10 PM
