CUCM 12.5.1 - LDAP Authentication to Sub Domain
dryliciouz
Beginner
Beginner
Hi Gurus,
Currently in CUCM, have1 integration for user to LDAP with domain: abc.domain.com.
I need some help to achieve the objective which is to integrate another domain in the same tree which: def.domain.com
Understand from LDAP Directory we can add 1 Integration point which is def.domain.com.
For Authentication, what i understand is we can only have 1 Authentication point in CUCM.
For the current setup the ldap authentication point to abc.domain.com with search base as dc=abc, dc=domain, dc=com.
In that case to achieve the authentication for abc.domain.com and def.domain.com
Should i put the the LDAP Authentication point to the root : domain.com, in that case able to authenticate both child domain?
Is that possible?
Nithin Eluvathingal
VIP Mentor VIP Mentor
VIP Mentor
Keeping domain.com should work
Response Signature
Mohammed al Baqari
VIP Advisor VIP Advisor
VIP Advisor
Yes this should work. In this case, your LDAP will act as a global catalog
to allow authentication and lookup again all child domains.
**** please remember to rate useful posts
Recognize Your Peers
