431
Highlighted
Beginner
CUCM 12.5 License Smart Reservation
Hi all,
 I am stuck in some issue here, CUCM 12.5 had 164- 8865 phones and 316-7821 phones registered,  I did smart license reservation and installed 1200 enhance licenses, after that 164 devices are showing licensed and authorized but 316 basic licenses are showing not authorized which means 7821 phones are not using that enhance license, but I have read and also seen that 7821 would take enhanced license when available.
kindly support me in solving this
32 REPLIES 32
Highlighted
Can you not use a disconnect on-prem SSM that you manually upload to/from the cloud SSM on a regular schedule?
Please rate all useful posts
Highlighted
Unfortunately no Roger, if it was a one time thing, we could have convinced them to let us connect the servers to internet but regular/scheduled connection is not possible
Its highly secure site where you can't have internet access
Highlighted
It does not need to have access to the internet. You can do manual uploads to/from the on-prem SSM to the account on the cloud SSM with an offline file transfer. As such it’s an air tight gap between the on-prem SSM and the cloud SSM.
Highlighted
Sorry I forgot to mention that in future we too won't  have access to their servers for such synchs
Highlighted
Write a guideline to guide the customer on how to maintain the Smart Licensing with the on-prem SSM in an air tight deployment model.
Highlighted
I am afraid, at this site, from End user there is no one to whom we can give such responsibility
Highlighted
Removing the instance has been explained on the below document. Assign the license as per your requirement on Smart License  reservation Page.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/12_5_1/systemConfig/cucm_b_system-configuration-guide-1251/cucm_b_system-configuration-guide-1251_chapter_01011011.html#concept_55037212E9B4C9A205F9E704BBC18F61
=>>>If this answered your question, please click "ACCEPT AS SOLUTION"<<<=
=>>>If you find this response useful, please mark it as "HELPFUL"<<<=
Highlighted
Thanks Nithin, I am trying to schedule remote access with end user, hopefully i can try your given solution tomorrow
Highlighted
Hi, Now I got the remote access and done the removing product instance part
but now its hitting some new bug, when I am trying to issue license request command on CUCM, its saying Agent is not enabled.
I did restart CUCM, services and disabled and enable license reservation
too many issues in this
Highlighted
There was a COP file i used before reservation but not sure if that is applicable to your case.
Highlighted
can you tell me which cop file you used?
is it
ciscocm-ucm-resetudi.k3.cop.sgn
Highlighted
yes.
Highlighted
Even I have installed this COP file but still the same issue, what it did though is reset the the evaluation period back to 90 days.
its showing as bug CSCvp17210 but its without any workaround/resolution.
Highlighted
Better to contact TAC
Highlighted
Yes, did  already.. tomorrow they will take access and i will update tom how it goes
Content for Community-Ad
