11-05-2009 04:43 AM - edited 03-15-2019 08:21 PM
We currently have CUCM 4.1 and we bought NFR CUCM 7.1.3. With the DMA tool I was migrate data and licenses and upload these data on Cisco web to generate license.
Then I upload generated license on CUCM and now I have active Phone and Node licenses, but the status of Software License is missing.
Whether someone has an idea where it could be a problem.
Solved! Go to Solution.
11-05-2009 05:37 AM
You will still need the 7.x software license. Upgrading from 6.x first and then to 7.x will not change that.
11-05-2009 05:25 AM
DMA will not issue you a 7.x software license. You must purchase or obtain the 7.x software license via the product upgrade tool. I don't think the not for resale software will include a legit software license either.
11-05-2009 05:29 AM
Thank You a lot.
One more Q.
We have CUCM 6.1.3 also.
Can I migrate license for it, and then upgrade CUCM to 7.1.3?
11-05-2009 05:37 AM
11-05-2009 05:38 AM
Ok.
Than You again
