06-12-2011 05:21 AM - edited 03-16-2019 05:24 AM
HI All ,
we have callmanger 5.1.3 integated with Active Directory 2008 , the problem is i am unable to import all user from AD , LDAP is synching properly but i can not import more then 312 user , what could be the issue ? is there any compatibilty issue ?
regards ,
Aslam
06-12-2011 06:41 AM
Hi Aslam,
how many users are there in the AD?
Are you trying to import the users from the child domain also? If the answer is yes, then you might want to check the following link:
Saurabh
06-12-2011 01:37 PM
As long as all users are in the user search space make sure the users have a first name and last name of they will not sync by design. Alternately check the dirsync logs (detailed) when doing a sync to see if there is a certain user the sync gets stuck on.
