CUCM 6.0 Low Available Virtul Memory
bilalsheikh
cisco unified operation managers shows  "Low Available Virtul Memory" alarm on publisher server, any one can help to resolve this issue thnx
David Hailey
Reboot the server.
Hailey
Please rate helpful posts!
Thnx David, one more thing is there any way to increase the virtual memory.
william_chua
I had this same issue before with CUCM version 6.1.2.
Yes, rebooting the server will resolve the issue. However, eventually, the issue will reoccur.
As a permanent solution, upgrade your CUCM version to 6.1.3 or later. This issue is bug related.
Yeah, agreed... I've seen lots of memory leak type bugs in the early 6.0 releases. Can't remember the specifics unfortunately, but options are really limited to reboots to work round it, or upgrades to fix as you don't have access to tweak any real OS parameters.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
