CUCM 6.1.5 Set local time and not use NTP server
Jay Matrona
Hello
The time on all the handsets in our office are off by 6 minutes even though they are pointing to an internal NTP server that has the correct time.
I want to just remove the NTP and set the time locally on the CUCM?  Either command line or web UI instructions are fine.  Another question is, After the time is changed, is there any way to push the change down to the phones without a reset so calls are not interuppted?
Jay
CUCM info:
admin:show status
Host Name    : ccm1
Date         : Mon Jul 25, 2011 12:23:04
Time Zone    : Eastern Standard Time (America/New_York)
Locale       : en_US.UTF-8
Product Ver  : 6.1.5.11900-13
Platform Ver : 2.0.0.1-1
Uptime:
12:23:06  up 359 days, 13:26,  1 user,  load average: 0.17, 0.14, 0.16
brendand05
Log into OS Administration
Go to Settings > NTP
Delete the NTP Source
Then if you want to set time manually go to
Settings > Time
Otherwise if you want to add a working NTP source go to
Settings > NTP > Add New
Reset 1 phone to check it has the correct time
If still not working try UTILS NTP RESTART from the CLI
8 Replies 8
Clifford McGlamry
Not all phones use NTP directly.  Many phones get their time from CCM.  Mainly, it's the high end phones that use NTP on their own.
You can use the command utils ntp status to see what's going on between CCM and NTP.  But if the phones are models that get their time from CCM, simply updating the time on CCM will fix your issue.
Cliff
Please rate helpful posts.
I meant NTP from CUCM not the phones getting NTP directly.  My question was not written well =(
I know that the CUCM is pointing to an internal server for NTP.  But it is not working.  So, I am looking for the proper steps to:
1. remove the NTP settings
2. Set local time on the CUCM  *not point to NTP server
3. Push correct time out to phones
What stratum is your NTP time source?  I've found that CUCM really likes low stratum numbers, and higher ones may not work.
If you have a stratum 2 or 3 source in your network, those tend to be bulletproof.
Thanks for the responses Cliff.  Here is info re: NTP  The stratum is 11(?!)  How do I get that down....especially when it is pointing to an internal server?
admin:utils ntp status
ntpd (pid 6125) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*127.127.1.0     127.127.1.0     10 l   42   64  377    0.000    0.000   0.004
10.1.0.12       .LOCL.           1 u   24   64  377    0.270  -386346   1.877
synchronised to local net at stratum 11
   time correct to within 11 ms
   polling server every 64 s
Current time in UTC is : Mon Jul 25 17:23:05 UTC 2011
Current time in America/New_York is : Mon Jul 25 13:23:05 EDT 2011
admin:utils ntp
      utils ntp config
      utils ntp restart
      utils ntp start
      utils ntp status
admin:utils ntp config
This node is configured to synchronize with one of the following NTP server(s):
  10.1.0.12
Hmmm....10.1.0.12 isn't synced to an external source (according to your output).  But your server isn't synced to it anyway.
Try doing an UTILS NTP RESTART
That will force it to reset.
What is 10.1.0.12?  Is it a router/switch?  Is it synced against an external source?
That address is actually the IP of the CUCM. And it looks like you are not using any NTP source at all. That is what you were going for?
neocec
That IP is of an internal server that gets NTP updates from outside source.
brendand05
Settings > Time
