CUCM 6.1(5) to 8.6(2a) with Hardware Migration Advice???
ciscology
I have a simple environment but a fairly complex requirement, and am seeking some advice from the assembled body of experts
Currently the environment consists of:
  • In service Publisher & Subscriber on HP DL380 G5’s
  • Running CUCM V6.1(5)
The intention is to upgrade the platform to V8.6(2a), however the following caveats apply:
  • The upgrades must be done offline
  • Have a TEST hardware platform at a HQ site, built at 6.1(5) DRS’d Publisher from site applied
  • We do not have a subscriber at the HQ site
  • We have two new MCS-7825-I5 platforms with CUCM 8.5, 3 yr ESW for the final environment
The existing plan was to:
  • Upgrade the cluster using the single TEST Publisher from UCM 6.1(5) to 8.5 which is supported in the matrix
  • Create a new UPGRADE DRS 8.5 copy for one of the new MCS-7825-I5 platforms which will be the new Publisher
  • Build the first MCS-7825-I5 platforms as Publisher at UCM V8.5 and apply the UPGRADE DRS
  • Upgrade new Publisher to UCM 8.6(2a) on the new platform
  • As abobve for a build of 2nd MCS-7825-I5 platform as Subscriber to new Publisher
  • Attach  2nd MCS-7825-I5 platform to CUCM Cluster as Subscriber
Having come into the environment to assist as an external resource, the questions I have are:
  • Can we upgrade the TEST 6.1(5) installation using the Publisher only, in other words is there a mechanism by which I upgrade the Publisher and Subscriber using the above single TEST platform without having a live Subscriber?
  • Could I delete the subscriber, upgrade the publisher and re-add a subscriber and have the same result as the upgrade would have provisioned i.e a Subscriber at 8.6(2a) using same IP address etc?
Many thanks for any input proffered!
S
11 Replies 11
Rob Huffman
Hi Steve,
Sorry to veer away from your questions here, but I have a few of my own
before we come up with a plan of attack here. As the "old" production servers are
not going to come into play here, the only real goal is to migrate the existing database
from 6.1(5) to 8.6(2) to prepare for the "cutover"
1. what hardware is running the "test" 6.1(5) Publisher?
2. what version of Cisco "build" DVD's/media do you have available?
3. there is a direct path from 6.1(5) to 8.6(2a)su1 that would be possible and would
alleviate the need of the "Refresh" upgrade from 8.5 to 8.6 as the last step. Is that
something you've considered?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
4. what is the time frame you're working with here?
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Rob,
Many thanks for answering - and questions are welcome as they will probably clarify the picture!
As the "old" production servers are not going to come into play here, the only real goal is to migrate the existing database
from 6.1(5) to 8.6(2) to prepare for the "cutover"       BANG ON!!!
ANSWER:   Same as in-service a HP DL380 G5
ANSWER:   8.5 - chasing for contract number to get 8.6(2a)
3. there is a direct path from 6.1(5) to 8.6(2a)su1 that would be possible and wouldalleviate the need of the "Refresh" upgrade from 8.5 to 8.6 as the last step. Is that something you've considered?
ANSWER:   Yup but until see 2. above - if I can get details and download the necessary CUCM 8.6(2a) great!!!
                   for now I assumed it might be two step but I had looked at the 8.6(2a) which I think is a bridged upgrade!
In terms of timeframe - within the next week or two at the outside.
Thanks again
Steve
Hi Steve,
No worries my friend
You've certainly done your homework here, so I will try to stay on topic. If you are
working in a tight timeframe then I would just move forward with the 8.5 DVD's to expedite
things. Here's my thoughts (weak as they are and in no pertinent order ).
***as a first step we always look at what phone firmware will be applied on the final
build version of CUCM and upgrade the phones on the current version to match ahead
of time*** - this takes one big variable out of the equation on "cut' night
*** also, contact licensing@cisco.com at this early phase to secure the 8.x Software
feature license, node, and phone licensing (tied to new Publisher MAC)
LAB work**
- It looks like your "test" Publisher DL380G5 will move to 8.5/8.6 without requiring the
Bridge Upgrade process which is good.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Bridge Upgrade - just in case
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_6_1/cucos/iptpch7.html#wp1119088
- But I would load the 8.5 DVD ASAP on your "test" box to make sure that it passes the Hardware checks
in the initial process.
- Disregard the Sub for this migration of the DB, I might even delete it from the Test config
as you nicely noted.
- Do a final DRS backup and restore onto the Test Pub on your chosen start date, after that
call an embargo where minimal changes are done and any that are "must haves" are duly noted
to be added back in at the end of the Migration to 8.x.
- do the upgrade of the test box to 8.x to secure a good DRS
- Build the new pub (same IP/Hostname as previous) and do your DRS restore that
was secured in the previous step.
- add/build the new Subscriber even if you have to re-IP later.
Changing the IP Address and Host Name for Cisco Unified Communications Manager Release 8.5(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_5_1/ipchange/ipchg851.html#wp42666
- Test, Test,Test
I know this list does not address all the requirements here, but sometimes just thinking out loud helps a bit And hopefully
some of our fellow NetPros who are far smarter than I will weigh in on this as well.
Best of luck.
Cheers!
Rob
Hi Rob.
Sorry been away for a few but many thanks for your very detailed response, I am further forward than I was but still have a question or maybe two :-)
Sorry if I misunderstand your inference, but when you say "Disregard the Sub for this migration of the DB, I might even delete it from the Test config as you nicely noted", does that mean that I can do the migration of Publisher to 8.5 (media I currently have) and then upgrade the sub later when you say "add/build the new Subscriber even if you have to re-IP later"?
I would consider deleting the Subscriber but on reflection if I do I may lose some cluster ordered groupings for resources (like phone registration) etc so I want to do some more analysis of what exists now to be 100%!
I think it would be good if Cisco could have an 'upgrade all' option from the Publisher node so that a complete upgrade is undertaken across the DB, but hey - when was this world perfect?
Thanks again!
Steve
Rob Huffman
Hi Steve,
No worries
We are really looking at the Lab work as two distinct tasks;
LAB
1. Migrate your existing cluster data to the lab HP DL380 G5 - this we'll call Phase 1
and this is where the need for an actual Sub would be unnecessary. In hindsight
you shouldn't need to delete the Sub (sorry my BAD!) This Phase is only used
to secure a good DRS backup to be used in Phase 2.
2. Phase 2 is the move of the DRS backup from the Lab HP DL380 G5 to your new
7825's. This is where you will want to re-build the Pub and Sub on your lab network.
The reference to re-IP the Sub is only if will need to move to a different network for production.
I hope this makes sense.
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Thanks again Rob...
Phase 1 starting today in Lab. Re-reading the above and just FYI I have the new hardware here in LAB and a change freeze in place on actual site, so I can complete all the actual work in the LAB thens hip the new kit to site when proven and tested, in a working state with a swapout of the hardware!
We have less than 100 phones (and many of those are not IP phones, just connected to VG224's) so there isn't a big worry on firmware updates.
When I get a known good DRS and start the build on the 7825's I'll set them up with same IP as the LIVE units, therefore there should have no work to do on site.
Last (I hope) question, the following is my process:
- Upgrade TEST PUB in LAB to CUCM 8.5
- Take DRS copy from TEST PUB in LAB now at CUCM 8.5
- Build 7825 PUB in LAB to CUCM 8.5
- Restore DRS CUCM 8.5 copy to 7825 PUB
- Build 7825 SUB in LAB to CUCM 8.5
- Restore DRS CUCM 8.5 copy to 7825 SUB
- TEST everything and then TEST it all again :-)
All being weel and when I have the media...
- Upgrade 7825 PUB in LAB to CUCM 8.6
- Upgrade  7825 SUB in LAB to CUCM 8.5
- Take DRS copy from 7825 PUB in LAB now at CUCM 8.6
- Ship to site....
Have I missed anything or does that look OK to you?
Cheers - your input much appreciated...
Steve
Rob Huffman
Hi Steve,
You are most welcome my friend
The plan looks solid to me....just a couple of further notes;
the steps below will not require DRS, just build the new Sub and let dbreplication
take care of replicating the data over from the Pub
- Restore DRS CUCM 8.5 copy to 7825 SUB (just use the inherent dbreplication)
The move to 8.6 does incorporate a new "Refresh" upgrade portion (see below)
Have a read of these awesome attachments from Ryan
Cheers!
Rob
Attachments look the business - will have a read...
Cheers
Steve
Started yesterday...
All went OK
"Security password is different from the one used for backup or the encrypted password has been tampered with. Restore will Halt"
The complaint is obviously around the old security password being different to that expected - but the customer is adamant that the two usernames and passwords I have are all he was given when the 3rd party installed the system.
So...I looked at the possibilities and I have noted a couple of mentions for recovery:
https://supportforums.cisco.com/docs/DOC-16780#_Reset_Administrator_and_Security_passwords_on_CUCM_6
http://www.gossamer-threads.com/lists/cisco/voip/145117
My question is as to whether at this somewhat precarious stage I will be OK to try and reset the CUCM Security password on my TEST PUB in LAB now at CUCM 8.5 (given that I have no access to the SUB) and then take a new DRS Copy and try to import that?
OR
Should i switch back to V6.1(5) and change the Security password (again and just to reiterate, given that I have no access to the SUB here either)
It sounds feasible - any thoughts. Thanks for any input proffered!
UPDATE
***Interestingly I have been given the Platform XML script that was generated prior to the install - but since the passwords are encrypted by the Standalone Configuration Wizard application I cannot see what they were originally - is there a reverse engineering version of this, or can anyone tell me what this is hashed to so that I could try and recover it from this information ***
Cheers
Steve
Rob Huffman
Hi Steve,
If it were me I wouldn't go down the password reset road quite yet. I would
go ahead and open a TAC case and see if they can access root and decrypt
the original Security password from the production build The Security password
needs to be reset on all nodes, so if worse comes to worse I would go back to the
production build and do the password resets, re-DRS and move forward with the new DRS.
Just my 2 cent$ here.
Cheers!
Rob
Rob,
Thanks...sometimes 2cent$ can seem like a million dollars depending on your situation
I'll see what TAC have to say!
Cheers
Steve
