CUCM 6 hardware
UCBNOCWAN
To install CUCM 6.0, is any server which meets minimum requirements ( 2GB RAM for example) sufficient or do we still need to go for Cisco approved servers only like in 4x versions?
5 Replies 5
Rob Huffman
Hey Abhijit,
How's things? It is Highly recommended to use only Cisco supported servers for CCM 6.x production builds. Here is an excellent list;
This doc shows all the supported models for the different CCM Versions ;
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Hi Rob,
Will definitely check it out on Monday, currently I am on leave..Thanks as usual for your support. Wish you a very merry Christmas in advance...
Abhijit.
Rob:
Is there a similar matrix which outlines other applications like Unity/IPCC/MPE.
I searched a lot on cisco.com and couldnt find it.
This matrix is really helpful to determine hardware dependency
s.lehmann
like before:
MCS or www.cisco.com/go/swonly
you can also check here:
for lab, you can install in a vmware.
regards
Steffen
Steffen,
Thanks a lot for your support. Wish you a very merry Christmas in advance.
