CUCM 6 hardware
UCBNOCWAN
Beginner
Beginner
To install CUCM 6.0, is any server which meets minimum requirements ( 2GB RAM for example) sufficient or do we still need to go for Cisco approved servers only like in 4x versions?
5 REPLIES 5
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hey Abhijit,
How's things? It is Highly recommended to use only Cisco supported servers for CCM 6.x production builds. Here is an excellent list;
This doc shows all the supported models for the different CCM Versions ;
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Hi Rob,
Will definitely check it out on Monday, currently I am on leave..Thanks as usual for your support. Wish you a very merry Christmas in advance...
Abhijit.
Rob:
Is there a similar matrix which outlines other applications like Unity/IPCC/MPE.
I searched a lot on cisco.com and couldnt find it.
This matrix is really helpful to determine hardware dependency
s.lehmann
Beginner
Beginner
like before:
MCS or www.cisco.com/go/swonly
you can also check here:
for lab, you can install in a vmware.
regards
Steffen
Steffen,
Thanks a lot for your support. Wish you a very merry Christmas in advance.
