01-03-2011 06:04 AM - edited 03-16-2019 02:40 AM
We would like to carve-out two small locations (50 and 100 users) of our current callmanager 6.X cluster. Those two locations do not have local callmanagers and will not be connected anymore to the network. They do have SRST and Unity express.
Does anyone know what I need? Afaik 6.X and 7.X is EOS so I need to go from a DLU license model to User license model? I need Cisco Callmanager (no BE or CCME). I guess we can use the MCS-7816-I4-IPC1 for each location but I have no clue which licenses to order. I also need attendant console at one location.
Thanks in advance,
Solved! Go to Solution.
01-03-2011 07:16 AM
The Cisco AM and Cisco Partner are having difficulties putting this together too.
Well, that's a bit disturbing. I guess point them to these two links:
I do have Smartnet on the licenses (ESW) and the hardware (SNTP)
First, let's get the terminology straight:
So what you are saying is that I can upgrade to 8.X (UCL/UWL) without buying user licenses?
Definitally not UWL. There is an entire ordering guide for a DLU-to-UWL transition. For customers with UCSS contracts Cisco is providing a migration into UCL. This is not to be taken lightly though; the entire concept of what is licensed pivots. There are no SKUs for this migration and customers who order UCL now are still provided DLU-based license files since CUCM will not be UWL/UCL aware until 9.0.
Is there a partcode for that?
It's never as simple as a single part number. I choose not to provide a bill of materials or multi-part number suggestions on here. The risk of providing the wrong information is far too high and, frankly, I'm not willing to spend the time for free.
I assume the CUAC is still in 7.1 so that would be another benefit?
No. It was enabled in the 7.0/7.1 code only for clusters that were upgraded from earlier releases. It is past end of life and the installer purposely disables it for any fresh install. Your only option will be the CUxAC product, likely CUBAC. You may want to read Cisco Unified Attendant Console Migration Planning. Due to the cost, Cisco is recommending CUP or KEM for some environments instead. To say this is a sore topic is an understatement.
01-03-2011 06:33 AM
You need to work with your Cisco partner on this. They have access to ordering guides for appropriate part numbers, hopefully a better insight into your network, an ability to have a conversation about what's best, and will have to place the order on your behalf anyways.
Here are the thoughts that come to mind based on what you've said:
01-03-2011 06:59 AM
Hi Jonathan,
Thanks for your quick answer.
I do have Smartnet on the licenses (ESW) and the hardware (SNTP) So what you are saying is that I can upgrade to 8.X (UCL/UWL) without buying user licenses? Is there a partcode for that?
I have been told that 7.1 is not orderable anymore so I will ask why it is not orderable. I assume the CUAC is still in 7.1 so that would be another benefit? I will consider the VMware option too.
Thanks, I will get back on this post.
01-03-2011 07:16 AM
