CUCM 7.0(1) corporate directory locale
mscaramelli
Hi all,
I've installed my CUCM 7 with italian locale and all is working well. My phones are all in italian language, but when I press the corporate directory I find fields in english language.
Thanks in advance,
Marco
5 Replies 5
f.gouger
I don't have a answer for you , but I have the same problem but in French!
Look like Cisco have some trouble with their locals!
I thank you for your solidarity.
marco
rcordeiro
Hi all,
I have the same problem but with portuguese, CM 7.0.1, with the portuguese localization from CISCO to CM 7. Everything in Portuguese but the "Personal Directory" (only the menu) and the "Corporate Directory" (menu and inside the menu).
I'm currently upgrading to 7.0.2, if the upgrade changes something in this field (I doubt, since this is localization and the file is the same) I'll post.
Cisco reply me with this Case CSCsx32772. The problem in French will be resolved with the loads in this case. But they will be available only around May!
Thank you very much for your info.
Marco
