08-03-2011 11:04 AM - edited 03-16-2019 06:17 AM
I have detected a problem in a location that has available bandwidth but in RTMT is out of resources and the client can't make calls.
There were 2 active calls, but in the RTMT the value of tha available bandwidth wasn´t the reflection of 2 active call's, just one. It seem's that one of the calls was stuck, but even so, i had enough available bandwidth to make more calls.
After a bandwidth resync the problem is fixed, but this occurs again randomly and i have to do the same workaround.
Dos anyone have any suggestion?
Thanks in advance.
JG
Solved! Go to Solution.
08-03-2011 11:27 AM
Here's one known locations bandwidth leak in your CUCM version:
08-03-2011 11:27 AM
08-04-2011 02:25 AM
Thank you Joemar.
That is it.
