CUCM 7.0 LDAP integration
saeed-zamani
Hello;
I have a question about ldap integration . I have about 500 users in my CUCM and some of them use for SIP accounts. I try to use UC integration for office communicator and as you know in this situation my end user ID and password have to be same with AD. so we want enable LDAP integration.
my question is that if I enable LDAP what happens to current users in CUCM? some of them uses for SIP and for other ones we user extension mobility. some of users IDs are same with AD but passwords are different. what happens to current end users after LDAP integration.
Jaime Valencia
Users that have a matching ID in LDAP will be updated and kept in the system, users whose ID doesn't match LDAP or do not exist in LDAP will be deleted by the garbage mechanism.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk</
