CUCM 7.1.2.21900-5 to 7.1.5
satish rawat
         I am trying to upgrade CM 7.1.2.21900-5 to next upgradable version...tried upgrading to UCSInstall_UCOS_UNRST_7.1.5.30000-1 but failed. I also loaded .cop file needed on 7.1.2 for upgrade but no luck.
I looked compatibility matrix and it says the version can be upgraded to 7.1.5.30000-1 not sure why its failing. any ideas ??
From the output that you have posted it is apparent that you are attempting to upgrade on VMWare, there are several attempts that can be seen where the hardware validation failed for HP and IBM such as the following 11/09/2012 00:52:09 Serverpak|DEBUG: Mismatch Manufacturer: expected HP\|Hewlett-Packard found  VMware, Inc.|<:INFO>.
As you are probably aware, but just to clarify the point, CUCM 7.x is not supported on Virtualised platform, so I assume that you are upgrading for lab purposes.
Ordinarily in fresh installs of CUCM 8 for Virtualisation a valid or reachable NTP is required otherwise the installation cannot proceed.  As in your case the installation has detected no valid NTP source thus the upgrade fails:
11/09/2012 01:27:19 InstallWizard|Internal Error, File:installWizMain.c:8624, Function: populateFromPlatformXml(), VMware primary node MUST have external NTP server(s)|<:CRITICAL>
11/09/2012 01:27:19 upgrade_os.sh|System info not updated by InstallWizard on new partition (1)|<:ERROR>
11/09/2012 01:27:19 upgrade_manager.sh|Platform upgrade failed|<:ERROR>
Allan.
13 Replies 13
Chris Deren
Check out this matrix for exact supported upgrade paths:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
what error are you getting?
Also, why are you installing unrestricted vs. restricted, what is your current version?  What country are you in?  Most of the time restricted is what you want, and you can not upgrade from one to the other.
HTH,
Chris
allan.thomas
Level 8
Level 8
It could be one of two things, either you are trying to upgrade from restricted to unrestricted release, the difference being that restricted is export restricted and that encryption is enabled whereas unrestricted has encryption disabled. If you upgrade to unrestricted version you have install a specific cop file beforehand, however once upgrade to unrestricted to can no longer upgrade to restricted in order to use encryption.
The other issue is that the hardware is not possibly supported, so have you verified the upgrade against supported hardware?
Allan.
Please kindly rate all helpful posts. thank you.
7.1.2.21900 is independent of Restrictions so it doent matter which path you take to upgrade, bottom line upgrade from this ver to 7.1.5.30000-1 should work, BTW i am now downloading UCSInstall_UCOS_7.1.5.30000-1.sgn.iso_part1of2 and UCSInstall_UCOS_7.1.5.30000-1.sgn.iso_part1of2 to see if this makes a diff, hardware is not an issue i got 4 gig ram and 160 gb HD.
The following was taken from the compatibility matrix for a direct upgrade to 7.1.5.30000-1 Unrestricted release. If you refer to the Unrestricted 7.1.5b column, it is associated with this footnote, implying that you need to install the cop if you are upgrading from either of the releases 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2),
1. You must install COP File ciscocm.allow_upgrades_to_unrestricted.cop.sgn before you upgrade from any of the releases listed in this
column [excluding Releases 4.1(3), 4.2(3), 4.3(2), 7.1(4), 7.1(5), and 7.1(5a)] to the export unrestricted Release 7.1(5a) or 7.1(5b).
Allan
Just to add stronger word of caution to Allen's statement:
Do not upgrade to an unrestricted version! This is a mistake that you cannot undo!
The unrestricted software was intended for installs located in Cuba, Iran, North Korea, Sudan, and Syria; or, foreign governements not esspecially friendly with the United States (exempted countries also listed at the link).
ok i downloaded restricted version ..merged two files and it still failed
i also loaded .cop file but no luck, when trying to upgrade by mounting iso on dvd drive it errors
The version number inside the selected upgrade does not match the filename.
Tried doing an upgrade using sftp.. it ran for about 20 mins and failed with errror that says unknown error cannot access the file. ( that to me me a false error since it took abt 20 mins to copy the file from sftp to inactive partition and the installer ran for abt 20 mins, i got was getting same message when i was trying to upgrade to unrestricted version...cant believe both of my files are corrupt )
any thoughts ?s
Just to let everyone know
my current version is
System version: 7.1.2.21900-5.
the installer file that i have after merging two files is UCSInstall_UCOS_7.1.5.30000-1.sgn
I suppose that version number error has something to do with  cd/dvd mounting, i burned a dvd instead of using iso/sftp and have now passed that error..crossing my fingers
Well after watching the install for nearly 32 mins it failed
File LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso
Start Time Fri Nov 09 00:51:50 PST 2012
Status
Error encountered: An unknown error occurred while accessing the upgrade file
this is killing me now...
logs
11/09/2012 00:51:20 file_list.sh|Starting file_list.sh|<:INFO>
11/09/2012 00:51:20 file_list.sh|Parse argument method=local|<:DEBUG>
11/09/2012 00:51:20 file_list.sh|Parse argument source_dir=.|<:DEBUG>
11/09/2012 00:51:20 file_list.sh|Parse argument dest_file=/var/log/install/downloaded_versions|<:DEBUG>
11/09/2012 00:51:20 file_list.sh|Unmounting /mnt/source incase it is mounted|<:DEBUG>
11/09/2012 00:51:20 file_list.sh|Mount /dev/cdrom on /mnt/source|<:DEBUG>
11/09/2012 00:51:24 file_list.sh|Found version /mnt/source/RedHat/APPRPMS/7.1.5.30000-1|<:INFO>
11/09/2012 00:51:25 file_list.sh|List file (pre-filtered):|<:DEBUG>
11/09/2012 00:51:25 file_list.sh|(CAPTURE) LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:DEBUG>
11/09/2012 00:51:25 file_list.sh|/usr/local/bin/base_scripts/filter.sh file=/var/log/install/downloaded_versions|<:DEBUG>
11/09/2012 00:51:26 file_list.sh|List file (post-filtered):|<:DEBUG>
11/09/2012 00:51:26 file_list.sh|(CAPTURE) LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:DEBUG>
11/09/2012 00:51:26 file_list.sh|List file (pre-structured):|<:DEBUG>
11/09/2012 00:51:27 file_list.sh|List file (post-structured):|<:DEBUG>
11/09/2012 00:51:27 file_list.sh|(CAPTURE) |<:DEBUG>
11/09/2012 00:51:27 file_list.sh|success|<:INFO>
11/09/2012 00:51:27 file_list.sh|file_list.sh complete (rc=0)|<:INFO>
11/09/2012 00:51:37 upgrade_validate_file.sh|Starting upgrade_validate_file.sh|<:INFO>
11/09/2012 00:51:37 upgrade_validate_file.sh|Parse argument method=local|<:DEBUG>
11/09/2012 00:51:37 upgrade_validate_file.sh|Parse argument source_dir=.|<:DEBUG>
11/09/2012 00:51:37 upgrade_validate_file.sh|Parse argument file_name=LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:DEBUG>
11/09/2012 00:51:37 upgrade_validate_file.sh|Unmount DVD|<:INFO>
11/09/2012 00:51:37 upgrade_validate_file.sh|Mount /dev/cdrom on /mnt/source|<:DEBUG>
11/09/2012 00:51:38 upgrade_validate_file.sh|Determining upgrade type for LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:INFO>
11/09/2012 00:51:38 upgrade_validate_file.sh|Getting patch size for /mnt/source|<:INFO>
11/09/2012 00:51:39 upgrade_validate_file.sh|There is enough space on device to proceed.|<:INFO>
11/09/2012 00:51:39 upgrade_validate_file.sh|(CAPTURE) mount: block device /dev/cdrom is write-protected, mounting read-only|<:DEBUG>
11/09/2012 00:51:39 upgrade_validate_file.sh|(CAPTURE)   Free space : 33919950848|<:DEBUG>
11/09/2012 00:51:39 upgrade_validate_file.sh|(CAPTURE) Space needed : 9928900608|<:DEBUG>
11/09/2012 00:51:39 upgrade_validate_file.sh|Checking if isofilename exists on /mnt/source|<:INFO>
11/09/2012 00:51:39 upgrade_validate_file.sh|Found /mnt/source/isofilename|<:INFO>
11/09/2012 00:51:39 upgrade_validate_file.sh|Checking if checksum_file exists on /mnt/source|<:INFO>
11/09/2012 00:51:40 upgrade_validate_file.sh|Found /mnt/source/checksum_file|<:INFO>
11/09/2012 00:51:40 upgrade_validate_file.sh|Validate APPRPMS exists on /mnt/source|<:INFO>
11/09/2012 00:51:40 upgrade_validate_file.sh|Found directory /mnt/source/RedHat/APPRPMS|<:INFO>
11/09/2012 00:51:40 upgrade_validate_file.sh|Validate GUI version with that on the media|<:INFO>
11/09/2012 00:51:41 upgrade_validate_file.sh|Found version 7.1.5.30000-1|<:INFO>
11/09/2012 00:51:41 upgrade_validate_file.sh|Unmount DVD|<:INFO>
11/09/2012 00:51:41 upgrade_validate_file.sh|success|<:INFO>
11/09/2012 00:51:41 upgrade_validate_file.sh|upgrade_validate_file.sh complete (rc=0)|<:INFO>
11/09/2012 00:51:43 upgrade_get_file.sh|Starting upgrade_get_file.sh|<:INFO>
11/09/2012 00:51:43 upgrade_get_file.sh|Parse argument method=local|<:DEBUG>
11/09/2012 00:51:43 upgrade_get_file.sh|Parse argument source_dir=.|<:DEBUG>
11/09/2012 00:51:43 upgrade_get_file.sh|Parse argument file_name=LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:DEBUG>
11/09/2012 00:51:43 upgrade_get_file.sh|Parse argument dest_dir=/common/download/|<:DEBUG>
11/09/2012 00:51:43 upgrade_get_file.sh|source file = /mnt/source/./LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso dest file = /common/download/LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:INFO>
11/09/2012 00:51:43 upgrade_get_file.sh|Unmounting /mnt/source incase it is mounted|<:DEBUG>
11/09/2012 00:51:43 upgrade_get_file.sh|Mount /dev/cdrom on /mnt/source|<:DEBUG>
11/09/2012 00:51:43 upgrade_get_file.sh|Determining upgrade type for LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso|<:INFO>
11/09/2012 00:51:43 upgrade_get_file.sh|Download of iso file RTMTStart|<:NOTICE>
11/09/2012 00:51:43 upgrade_get_file.sh|Create md5 "/common/download/LOCAL_UCSInstall_UCOS_7.1.5.30000-1.sgn.iso.md5"|<:INFO>
11/09/2012 00:51:43 upgrade_get_file.sh|Create md5 complete|<:INFO>
11/09/2012 00:51:44 upgrade_get_file.sh|Authenticate file "/common/download/7.1.5.30000-1/checksum_file.sgn"|<:INFO>
11/09/2012 00:51:44 upgrade_get_file.sh|File authentication complete|<:DEBUG>
11/09/2012 00:51:44 upgrade_get_file.sh| /usr/local/bin/base_scripts/copy_and_authenticate.sh /mnt/source /common/download/7.1.5.30000-1 Cisco/base_scripts/upgrade_manager.sh /common/download/7.1.5.30000-1/checksum_file|<:INFO>
11/09/2012 00:51:44 upgrade_get_file.sh|New Upgrade Software; returning|<:INFO>
11/09/2012 00:51:44 upgrade_get_file.sh|Download of iso file RTMTFinish|<:NOTICE>
11/09/2012 00:51:44 upgrade_get_file.sh|success|<:INFO>
11/09/2012 00:51:44 upgrade_get_file.sh|upgrade_get_file.sh complete (rc=0)|<:INFO>
11/09/2012 00:51:51 Killing background processes
11/09/2012 00:51:57 upgrade_install.sh|Starting Upgrade -- upgrade_install.sh|<:INFO>
11/09/2012 00:51:57 upgrade_install.sh|Parse argument version=7.1.5.30000-1|<:DEBUG>
11/09/2012 00:51:57 upgrade_install.sh|Parse argument dest_dir=/common/download/|<:DEBUG>
11/09/2012 00:51:57 upgrade_install.sh|Parse argument work_dir=/var/log/install|<:DEBUG>
11/09/2012 00:51:57 upgrade_install.sh|IOWAIT monitor starting|<:INFO>
11/09/2012 00:51:57 upgrade_install.sh|/usr/local/platform/bin/startcsa status|<:DEBUG>
11/09/2012 00:51:57 upgrade_install.sh|CSA Status = 0|<:DEBUG>
11/09/2012 00:51:57 upgrade_install.sh|(CAPTURE) Cisco Security Agent is running with pid 1138|<:DEBUG>
11/09/2012 00:51:57 upgrade_install.sh|/etc/init.d/ciscosec stop|<:DEBUG>
11/09/2012 00:52:01 upgrade_install.sh|(CAPTURE) Stopping ciscosec:  [  OK  ]|<:DEBUG>
11/09/2012 00:52:01 upgrade_install.sh|Upgrade the system|<:INFO>
11/09/2012 00:52:01 upgrade_install.sh|-rwxr-xr-x  1 root root 47659 Nov  9 00:51 /common/download/7.1.5.30000-1/Cisco/base_scripts/upgrade_manager.sh|<:DEBUG>
11/09/2012 00:52:01 upgrade_install.sh|Start upgrade manager|<:INFO>
11/09/2012 00:52:01 upgrade_install.sh|/common/download/7.1.5.30000-1/Cisco/base_scripts/upgrade_manager.sh type=upgrade             basepath=/common/download/7.1.5.30000-1             logfile=/var/log/install/install_log_2012-11-09.00.51.20.log             resultfile=/var/log/install/upgrade-results.xml|<:DEBUG>
11/09/2012 00:52:01 upgrade_manager.sh|(CAPTURE) Set logging context for upgrade|<:DEBUG>
11/09/2012 00:52:01 upgrade_manager.sh|(CAPTURE) Initialize logging|<:DEBUG>
11/09/2012 00:52:01 upgrade_manager.sh|(CAPTURE) Copying /mnt/source/Cisco/base_scripts/ilog2.sh to /common/download/7.1.5.30000-1/base_scripts|<:DEBUG>
11/09/2012 00:52:01 upgrade_manager.sh|(CAPTURE) Copying /mnt/source/Cisco/base_scripts/ilog_impl to /common/download/7.1.5.30000-1/base_scripts|<:DEBUG>
11/09/2012 00:52:01 ServerApiManager|In main with args -|initialize|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:01 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:01 ServerApiManager|In main with args -|reset|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:01 Serverpak|IN INITIALIZE model = VMware statefile=  /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 00:52:01 Serverpak|DEBUG: Current Directory=/partB/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 00:52:01 ServerApiManager||Method: reset args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:02 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
11/09/2012 00:52:03 Serverpak|IN INITIALIZE model = VMware statefile=  /tmp/hssi_api_state_file|<:INFO>
11/09/2012 00:52:03 Serverpak|DEBUG: Current Directory=/mnt/source/Cisco/hssi/shared/bin|<:INFO>
11/09/2012 00:52:03 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
11/09/2012 00:52:03 ServerApiManager|In main with args -|initialize|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:03 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:03 ServerApiManager|In main with args -|initHardwareLibrary|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:03 ServerApiManager|Sam_reset being called|<:DEBUG>
11/09/2012 00:52:03 ServerApiManager||Method: initHardwareLibrary args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:03 upgrade_manager.sh|Initializing the product API|<:DEBUG>
11/09/2012 00:52:03 upgrade_manager.sh|Get deployment ID from active side|<:DEBUG>
11/09/2012 00:52:03 upgrade_manager.sh|Copying /mnt/source/Cisco/install/callmanager.conf to /common/rpm-archive/7.1.5.30000-1/install.conf|<:DEBUG>
11/09/2012 00:52:03 upgrade_manager.sh|Generate hardware cache file|<:DEBUG>
11/09/2012 00:52:03 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
11/09/2012 00:52:05 Serverpak|In runtime of 7825H4 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:05 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/HP/DL320G5p/7825H4/shared/bin self detection|<:INFO>
11/09/2012 00:52:06 Serverpak|In runtime of 7825H4 args [serverDetect]|<:INFO>
11/09/2012 00:52:06 Serverpak|In runtime of DL320G5p args [serverDetect]|<:INFO>
11/09/2012 00:52:06 Serverpak|In runtime of HP args [serverDetect]|<:INFO>
11/09/2012 00:52:06 Serverpak|In runtime of HP args [Vendor]|<:INFO>
11/09/2012 00:52:06 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:06 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:06 Serverpak|HP shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:06 Serverpak|DEBUG: Mismatch Manufacturer: expected HP\|Hewlett-Packard found  VMware, Inc.|<:INFO>
11/09/2012 00:52:06 Serverpak|HP shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:06 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:06 Serverpak|DL320G5p shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:06 Serverpak|7825H4 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:06 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/HP/DL320G5p/7825H4/shared/bin|<:INFO>
11/09/2012 00:52:06 Serverpak|In runtime of 7825H4 args [error_message_file]|<:INFO>
11/09/2012 00:52:06 Serverpak|7825H4 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:06 Serverpak|7825H4 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:06 Serverpak|HSSI_API ../../server_implementation/HP/DL320G5p/7825H4/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of 7828H4 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:07 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/HP/DL320G5p/7828H4/shared/bin self detection|<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of 7828H4 args [serverDetect]|<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of DL320G5p args [serverDetect]|<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of HP args [serverDetect]|<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of HP args [Vendor]|<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:07 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:07 Serverpak|HP shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:07 Serverpak|DEBUG: Mismatch Manufacturer: expected HP\|Hewlett-Packard found  VMware, Inc.|<:INFO>
11/09/2012 00:52:07 Serverpak|HP shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:07 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:07 Serverpak|DL320G5p shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:07 Serverpak|7828H4 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:07 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/HP/DL320G5p/7828H4/shared/bin|<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of 7828H4 args [error_message_file]|<:INFO>
11/09/2012 00:52:07 Serverpak|7828H4 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:07 Serverpak|7828H4 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:07 Serverpak|HSSI_API ../../server_implementation/HP/DL320G5p/7828H4/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of 7835H2 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:07 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G5/7835H2/shared/bin self detection|<:INFO>
11/09/2012 00:52:07 Serverpak|In runtime of 7835H2 args [serverDetect]|<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of DL380G5 args [serverDetect]|<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of DL380 args [serverDetect]|<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of HP args [serverDetect]|<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of HP args [Vendor]|<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:08 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:08 Serverpak|HP shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:08 Serverpak|DEBUG: Mismatch Manufacturer: expected HP\|Hewlett-Packard found  VMware, Inc.|<:INFO>
11/09/2012 00:52:08 Serverpak|HP shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:08 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:08 Serverpak|DL380 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:08 Serverpak|DL380G5 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:08 Serverpak|7835H2 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:08 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G5/7835H2/shared/bin|<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of 7835H2 args [error_message_file]|<:INFO>
11/09/2012 00:52:08 Serverpak|7835H2 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:08 Serverpak|7835H2 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:08 Serverpak|HSSI_API ../../server_implementation/HP/DL380/G5/7835H2/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of 7845H2 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:08 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G5/7845H2/shared/bin self detection|<:INFO>
11/09/2012 00:52:08 Serverpak|In runtime of 7845H2 args [serverDetect]|<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of HP args [Vendor]|<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:09 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:09 Serverpak|HP shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:09 Serverpak|HP shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:09 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:09 Serverpak|DL380 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:09 Serverpak|DL380G5 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:09 Serverpak|7845H2 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:09 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G5/7845H2/shared/bin|<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of 7845H2 args [error_message_file]|<:INFO>
11/09/2012 00:52:09 Serverpak|7845H2 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:09 Serverpak|7845H2 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:09 Serverpak|HSSI_API ../../server_implementation/HP/DL380/G5/7845H2/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of 7835H3 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:09 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G6/7835H3/shared/bin self detection|<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of 7835H3 args [serverDetect]|<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of DL380G6 args [serverDetect]|<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of DL380 args [serverDetect]|<:INFO>
11/09/2012 00:52:09 Serverpak|In runtime of HP args [serverDetect]|<:INFO>
11/09/2012 00:52:10 Serverpak|DL380G6 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:10 Serverpak|7835H3 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:10 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G6/7835H3/shared/bin|<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of 7835H3 args [error_message_file]|<:INFO>
11/09/2012 00:52:10 Serverpak|7835H3 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:10 Serverpak|7835H3 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:10 Serverpak|HSSI_API ../../server_implementation/HP/DL380/G6/7835H3/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of 7845H3 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:10 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G6/7845H3/shared/bin self detection|<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of 7845H3 args [serverDetect]|<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of DL380G6 args [serverDetect]|<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of DL380 args [serverDetect]|<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of HP args [serverDetect]|<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of HP args [Vendor]|<:INFO>
11/09/2012 00:52:10 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:10 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:10 Serverpak|HP shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:10 Serverpak|DEBUG: Mismatch Manufacturer: expected HP\|Hewlett-Packard found  VMware, Inc.|<:INFO>
11/09/2012 00:52:10 Serverpak|HP shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:10 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:10 Serverpak|DL380 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|DL380G6 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|7845H3 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G6/7845H3/shared/bin|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of 7845H3 args [error_message_file]|<:INFO>
11/09/2012 00:52:11 Serverpak|7845H3 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:11 Serverpak|7845H3 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|HSSI_API ../../server_implementation/HP/DL380/G6/7845H3/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of 7845H3PLUS args [detect_and_validate]|<:INFO>
11/09/2012 00:52:11 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G6/7845H3PLUS/shared/bin self detection|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of 7845H3PLUS args [serverDetect]|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of DL380G6 args [serverDetect]|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of DL380 args [serverDetect]|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of HP args [serverDetect]|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of HP args [Vendor]|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:11 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:11 Serverpak|HP shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:11 Serverpak|DEBUG: Mismatch Manufacturer: expected HP\|Hewlett-Packard found  VMware, Inc.|<:INFO>
11/09/2012 00:52:11 Serverpak|HP shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:11 Serverpak|DL380 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|7845H3PLUS api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/HP/DL380/G6/7845H3PLUS/shared/bin|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of 7845H3PLUS args [error_message_file]|<:INFO>
11/09/2012 00:52:11 Serverpak|7845H3PLUS api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:11 Serverpak|7845H3PLUS api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:11 Serverpak|HSSI_API ../../server_implementation/HP/DL380/G6/7845H3PLUS/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of 7816I4 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:11 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/IBM/x3250M2/7816I4/shared/bin self detection|<:INFO>
11/09/2012 00:52:11 Serverpak|In runtime of 7816I4 args [serverDetect]|<:INFO>
11/09/2012 00:52:12 Serverpak|In runtime of x3250M2 args [serverDetect]|<:INFO>
11/09/2012 00:52:12 Serverpak|In runtime of IBM args [serverDetect]|<:INFO>
11/09/2012 00:52:12 Serverpak|In runtime of IBM args [Vendor]|<:INFO>
11/09/2012 00:52:12 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:12 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:12 Serverpak|IBM shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:12 Serverpak|DEBUG:IBM and  VMware, Inc. don't match|<:INFO>
11/09/2012 00:52:12 Serverpak|IBM shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:12 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:12 Serverpak|x3250M2 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:12 Serverpak|7816I4 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:12 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/IBM/x3250M2/7816I4/shared/bin|<:INFO>
11/09/2012 00:52:12 Serverpak|In runtime of 7816I4 args [error_message_file]|<:INFO>
11/09/2012 00:52:12 Serverpak|7816I4 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:12 Serverpak|7816I4 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:12 Serverpak|HSSI_API ../../server_implementation/IBM/x3250M2/7816I4/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:12 Serverpak|In runtime of 7825I4 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:12 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/IBM/x3250M2/7825I4/shared/bin self detection|<:INFO>
11/09/2012 00:52:12 Serverpak|In runtime of 7825I4 args [serverDetect]|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of IBM args [Vendor]|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:13 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:13 Serverpak|IBM shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:13 Serverpak|DEBUG:IBM and  VMware, Inc. don't match|<:INFO>
11/09/2012 00:52:13 Serverpak|IBM shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:13 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:13 Serverpak|x3250M2 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:13 Serverpak|7825I4 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:13 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/IBM/x3250M2/7825I4/shared/bin|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of 7825I4 args [error_message_file]|<:INFO>
11/09/2012 00:52:13 Serverpak|7825I4 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:13 Serverpak|7825I4 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:13 Serverpak|HSSI_API ../../server_implementation/IBM/x3250M2/7825I4/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of 7828I4 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:13 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/IBM/x3250M2/7828I4/shared/bin self detection|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of 7828I4 args [serverDetect]|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of x3250M2 args [serverDetect]|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of IBM args [serverDetect]|<:INFO>
11/09/2012 00:52:13 Serverpak|7828I4 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:13 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/IBM/x3250M2/7828I4/shared/bin|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of 7828I4 args [error_message_file]|<:INFO>
11/09/2012 00:52:13 Serverpak|7828I4 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:13 Serverpak|7828I4 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:13 Serverpak|HSSI_API ../../server_implementation/IBM/x3250M2/7828I4/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of 7835I3 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:13 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/IBM/x3650M2/7835I3/shared/bin self detection|<:INFO>
11/09/2012 00:52:13 Serverpak|In runtime of 7835I3 args [serverDetect]|<:INFO>
11/09/2012 00:52:14 Serverpak|In runtime of x3650M2 args [serverDetect]|<:INFO>
11/09/2012 00:52:14 Serverpak|In runtime of IBM args [serverDetect]|<:INFO>
11/09/2012 00:52:14 Serverpak|In runtime of IBM args [Vendor]|<:INFO>
11/09/2012 00:52:14 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:14 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:14 Serverpak|IBM shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:14 Serverpak|DEBUG:IBM and  VMware, Inc. don't match|<:INFO>
11/09/2012 00:52:14 Serverpak|IBM shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:14 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:14 Serverpak|x3650M2 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:14 Serverpak|7835I3 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:14 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/IBM/x3650M2/7835I3/shared/bin|<:INFO>
11/09/2012 00:52:14 Serverpak|In runtime of 7835I3 args [error_message_file]|<:INFO>
11/09/2012 00:52:14 Serverpak|7835I3 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:14 Serverpak|7835I3 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:14 Serverpak|HSSI_API ../../server_implementation/IBM/x3650M2/7835I3/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:14 Serverpak|In runtime of 7845I3 args [detect_and_validate]|<:INFO>
11/09/2012 00:52:14 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/IBM/x3650M2/7845I3/shared/bin self detection|<:INFO>
11/09/2012 00:52:14 Serverpak|In runtime of 7845I3 args [serverDetect]|<:INFO>
11/09/2012 00:52:15 Serverpak|DEBUG:IBM and  VMware, Inc. don't match|<:INFO>
11/09/2012 00:52:15 Serverpak|IBM shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:15 Serverpak|DEBUG: failure in super serverDetect|<:INFO>
11/09/2012 00:52:15 Serverpak|x3650M2 shared_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:15 Serverpak|7845I3 api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:15 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/IBM/x3650M2/7845I3/shared/bin|<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of 7845I3 args [error_message_file]|<:INFO>
11/09/2012 00:52:15 Serverpak|7845I3 api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:15 Serverpak|7845I3 api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:15 Serverpak|HSSI_API ../../server_implementation/IBM/x3650M2/7845I3/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of 7845I3PLUS args [detect_and_validate]|<:INFO>
11/09/2012 00:52:15 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/IBM/x3650M2/7845I3PLUS/shared/bin self detection|<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of 7845I3PLUS args [serverDetect]|<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of x3650M2 args [serverDetect]|<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of IBM args [serverDetect]|<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of IBM args [Vendor]|<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:15 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:15 Serverpak|IBM shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:15 Serverpak|7845I3PLUS api_implementation.sh serverDetect returns (2)|<:INFO>
11/09/2012 00:52:15 Serverpak|INFO: This service didn't pass detection of /mnt/source/Cisco/hssi/server_implementation/IBM/x3650M2/7845I3PLUS/shared/bin|<:INFO>
11/09/2012 00:52:15 Serverpak|In runtime of 7845I3PLUS args [error_message_file]|<:INFO>
11/09/2012 00:52:15 Serverpak|7845I3PLUS api_implementation.sh error_message_file returns (0)|<:INFO>
11/09/2012 00:52:15 Serverpak|7845I3PLUS api_implementation.sh detect_and_validate returns (2)|<:INFO>
11/09/2012 00:52:15 Serverpak|HSSI_API ../../server_implementation/IBM/x3650M2/7845I3PLUS/shared/bin/api_implementation.sh returned 2 and errors= |<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of HAL args [detect_and_validate]|<:INFO>
11/09/2012 00:52:16 Serverpak|../../server_implementation/KVM/HAL/shared/bin/api_implementation.sh hal check returned 1 - HAL|<:INFO>
11/09/2012 00:52:16 Serverpak|HAL api_implementation.sh detect_and_validate returns (1)|<:INFO>
11/09/2012 00:52:16 Serverpak|HSSI_API ../../server_implementation/KVM/HAL/shared/bin/api_implementation.sh returned 1 and errors= |<:INFO>
11/09/2012 00:52:16 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> hardware_detection_failure_paths = ../../server_implementation/KVM/HAL/shared/bin/api_implementation.sh|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of supported args [detect_and_validate]|<:INFO>
11/09/2012 00:52:16 Serverpak|In /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin self detection|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of supported args [serverDetect]|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of VMWARE args [serverDetect]|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of VMWARE args [expected_manufacturer]|<:INFO>
11/09/2012 00:52:16 Serverpak|VMWARE shared_implementation.sh expected_manufacturer returns (0)|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of VMWARE args [Vendor]|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:16 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:16 Serverpak|VMWARE shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:16 Serverpak|DEBUG: we have a manufacturer match: VMware|<:INFO>
11/09/2012 00:52:16 Serverpak|DEBUG: |<:INFO>
11/09/2012 00:52:16 Serverpak|VMWARE shared_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 00:52:16 Serverpak|supported api_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 00:52:16 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server as self - do validation|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of supported args [serverValidate]|<:INFO>
11/09/2012 00:52:16 Serverpak|Validating CPU info|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of supported args [expected_cpu_count]|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of VMWARE args [expected_cpu_count]|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of server_implementation args [expected_cpu_count]|<:INFO>
11/09/2012 00:52:16 Serverpak|server_implementation shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 00:52:16 Serverpak|VMWARE shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 00:52:16 Serverpak|supported api_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of supported args [expected_cpu_speed]|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of VMWARE args [expected_cpu_speed]|<:INFO>
11/09/2012 00:52:16 Serverpak|In runtime of server_implementation args [expected_cpu_speed]|<:INFO>
11/09/2012 00:52:17 Serverpak|server_implementation shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 00:52:17 Serverpak|VMWARE shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 00:52:17 Serverpak|supported api_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of VMWARE args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of server_implementation args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 00:52:17 Serverpak|DEBUG: validation Error |<:INFO>
11/09/2012 00:52:17 Serverpak|server_implementation shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 00:52:17 Serverpak|VMWARE shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 00:52:17 Serverpak|CPU validation Completed - Validating Disk|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [expected_disk_count]|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of VMWARE args [expected_disk_count]|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of server_implementation args [expected_disk_count]|<:INFO>
11/09/2012 00:52:17 Serverpak|server_implementation shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 00:52:17 Serverpak|VMWARE shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 00:52:17 Serverpak|supported api_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [expected_min_disk_size]|<:INFO>
11/09/2012 00:52:17 Serverpak|supported api_implementation.sh expected_min_disk_size returns (0)|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [expected_disk_units]|<:INFO>
11/09/2012 00:52:17 Serverpak|supported api_implementation.sh expected_disk_units returns (0)|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [validatePhysicalDisk_Count_Size_Units 72 GB]|<:INFO>
11/09/2012 00:52:17 Serverpak|VMware overload of validatePhysicalDisk_count exectuing.|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [getNumberOfDisks]|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [required_min_disk_count]|<:INFO>
11/09/2012 00:52:17 Serverpak|supported api_implementation.sh required_min_disk_count returns (0)|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [required_disk1_location]|<:INFO>
11/09/2012 00:52:17 Serverpak|supported api_implementation.sh required_disk1_location returns (0)|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of supported args [required_disk1_size]|<:INFO>
11/09/2012 00:52:17 Serverpak|In runtime of VMWARE args [required_disk1_size]|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of server_implementation args [required_disk1_size]|<:INFO>
11/09/2012 00:52:18 Serverpak|server_implementation shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 00:52:18 Serverpak|VMWARE shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of supported args [required_disk1_units]|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of VMWARE args [required_disk1_units]|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of server_implementation args [required_disk1_units]|<:INFO>
11/09/2012 00:52:18 Serverpak|server_implementation shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 00:52:18 Serverpak|VMWARE shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of supported args [alternate_min_disk_count]|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh alternate_min_disk_count returns (0)|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of supported args [alternate_disk1_location]|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh alternate_disk1_location returns (0)|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh getNumberOfDisks returns (1)|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh validatePhysicalDisk_Count_Size_Units 72 GB returns (0)|<:INFO>
11/09/2012 00:52:18 Serverpak|Disk validation Completed - Validating Memory|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of supported args [expected_min_memory]|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh expected_min_memory returns (0)|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of supported args [expected_memory_units]|<:INFO>
11/09/2012 00:52:18 Serverpak|supported api_implementation.sh expected_memory_units returns (0)|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of VMWARE args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of server_implementation args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 00:52:18 Serverpak|DEBUG: MISMATCHED UNITS a=MB e=GB|<:INFO>
11/09/2012 00:52:18 Serverpak|DEBUG: MISMATCHED UNITS converted old=1 GB new=1024 MB|<:INFO>
11/09/2012 00:52:18 Serverpak|DEBUG: MEMORY COMPARISON result is 1 with a=4096 e=1024|<:INFO>
11/09/2012 00:52:18 Serverpak|DEBUG: we have a capacity match: 1024 MB|<:INFO>
11/09/2012 00:52:18 Serverpak|server_implementation shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 00:52:18 Serverpak|VMWARE shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 00:52:18 Serverpak|In runtime of supported args [expected_max_memory]|<:INFO>
11/09/2012 00:52:19 Serverpak|In runtime of VMWARE args [expected_max_memory]|<:INFO>
11/09/2012 00:52:19 Serverpak|In runtime of server_implementation args [expected_max_memory]|<:INFO>
11/09/2012 00:52:19 Serverpak|server_implementation shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 00:52:19 Serverpak|VMWARE shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 00:52:19 Serverpak|supported api_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 00:52:19 Serverpak|Max Memory validation bypassed... no maximum specified|<:INFO>
11/09/2012 00:52:19 Serverpak|supported api_implementation.sh serverValidate returns (0)|<:INFO>
11/09/2012 00:52:19 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server validated as supported|<:INFO>
11/09/2012 00:52:19 Serverpak|supported api_implementation.sh detect_and_validate returns (0)|<:INFO>
11/09/2012 00:52:19 Serverpak|HSSI_API ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh returned 0 and errors= |<:INFO>
11/09/2012 00:52:19 Serverpak|In runtime of supported args [HWModel]|<:INFO>
11/09/2012 00:52:19 Serverpak|supported api_implementation.sh HWModel returns (0)|<:INFO>
11/09/2012 00:52:19 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> hardware_implementation_paths = ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh|<:INFO>
11/09/2012 00:52:19 Serverpak|HSSI_API VALIDATE_DECTECT ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh path|<:INFO>
11/09/2012 00:52:19 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> HWModel = VMware|<:INFO>
11/09/2012 00:52:19 Serverpak|IN INITIALIZE model = VMware statefile=  /tmp/hssi_api_state_file|<:INFO>
11/09/2012 00:52:19 Serverpak|DEBUG: Current Directory=/mnt/source/Cisco/hssi/shared/bin|<:INFO>
11/09/2012 00:52:19 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
11/09/2012 00:52:19 ServerApiManager|In main with args -|initialize|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:19 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:19 ServerApiManager|In main with args -|getHardwareAttribute ALL|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:19 Serverpak|In runtime of supported args [Vendor]|<:INFO>
11/09/2012 00:52:19 Serverpak|In runtime of VMWARE args [Vendor]|<:INFO>
11/09/2012 00:52:19 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 00:52:19 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:19 Serverpak|VMWARE shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:19 Serverpak|supported api_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 00:52:19 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> Vendor = VMware, Inc.|<:INFO>
11/09/2012 00:52:19 Serverpak|[VMware] retrieved from cache for key -[HWModel]-|<:INFO>
11/09/2012 00:52:19 Serverpak|In runtime of supported args [CPUCount]|<:INFO>
11/09/2012 00:52:19 Serverpak|In runtime of VMWARE args [CPUCount]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of server_implementation args [CPUCount]|<:INFO>
11/09/2012 00:52:20 Serverpak|server_implementation shared_implementation.sh CPUCount returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|VMWARE shared_implementation.sh CPUCount returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|supported api_implementation.sh CPUCount returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> CPUCount = 1|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of supported args [CPUType]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of VMWARE args [CPUType]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of server_implementation args [CPUType]|<:INFO>
11/09/2012 00:52:20 Serverpak|server_implementation shared_implementation.sh CPUType returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|VMWARE shared_implementation.sh CPUType returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|supported api_implementation.sh CPUType returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> CPUType = Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of supported args [getHardwareAttribute CPUSpeedInMHz]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of supported args [CPUSpeedInMHz]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of VMWARE args [CPUSpeedInMHz]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of server_implementation args [CPUSpeedInMHz]|<:INFO>
11/09/2012 00:52:20 Serverpak|server_implementation shared_implementation.sh CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|VMWARE shared_implementation.sh CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|supported api_implementation.sh CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|supported api_implementation.sh getHardwareAttribute CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 00:52:20 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> CPUSpeed = 3300|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of supported args [MemUnits]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of VMWARE args [MemUnits]|<:INFO>
11/09/2012 00:52:20 Serverpak|In runtime of server_implementation args [MemUnits]|<:INFO>
11/09/2012 00:52:21 Serverpak|server_implementation shared_implementation.sh MemUnits returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|VMWARE shared_implementation.sh MemUnits returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|supported api_implementation.sh MemUnits returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of supported args [getHardwareAttribute MEMSize]|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of supported args [MEMSize]|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of VMWARE args [MEMSize]|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of server_implementation args [MEMSize]|<:INFO>
11/09/2012 00:52:21 Serverpak|server_implementation shared_implementation.sh MEMSize returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|VMWARE shared_implementation.sh MEMSize returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|supported api_implementation.sh MEMSize returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|supported api_implementation.sh getHardwareAttribute MEMSize returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> MEMSize = 4096|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of supported args [BIOSVer]|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of VMWARE args [BIOSVer]|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of server_implementation args [BIOSVer]|<:INFO>
11/09/2012 00:52:21 Serverpak|server_implementation shared_implementation.sh BIOSVer returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|VMWARE shared_implementation.sh BIOSVer returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|supported api_implementation.sh BIOSVer returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> BIOSVer = PhoenixTechnologiesLTD 6.00 07/02/2012|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of supported args [ObjectId]|<:INFO>
11/09/2012 00:52:21 Serverpak|supported api_implementation.sh ObjectId returns (0)|<:INFO>
11/09/2012 00:52:21 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> ObjectId = VMware|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of supported args [OSVersion]|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of VMWARE args [OSVersion]|<:INFO>
11/09/2012 00:52:21 Serverpak|In runtime of server_implementation args [OSVersion]|<:INFO>
11/09/2012 00:52:22 Serverpak|server_implementation shared_implementation.sh OSVersion returns (0)|<:INFO>
11/09/2012 00:52:22 Serverpak|VMWARE shared_implementation.sh OSVersion returns (0)|<:INFO>
11/09/2012 00:52:22 Serverpak|supported api_implementation.sh OSVersion returns (0)|<:INFO>
11/09/2012 00:52:22 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> OSVersion = UCOS 4.0.0.0-16|<:INFO>
11/09/2012 00:52:22 Serverpak|In runtime of supported args [SerialNumber]|<:INFO>
11/09/2012 00:52:22 Serverpak|In runtime of VMWARE args [SerialNumber]|<:INFO>
11/09/2012 00:52:22 Serverpak|In runtime of server_implementation args [SerialNumber]|<:INFO>
11/09/2012 00:52:22 Serverpak|server_implementation shared_implementation.sh SerialNumber returns (0)|<:INFO>
11/09/2012 00:52:22 Serverpak|VMWARE shared_implementation.sh SerialNumber returns (0)|<:INFO>
11/09/2012 00:52:22 Serverpak|supported api_implementation.sh SerialNumber returns (0)|<:INFO>
11/09/2012 00:52:22 Serverpak|HSSI set_inDataFile_forKey_value /tmp/hssi_api_state_file -> SerialNumber = VMware-56 4d 5e 36 15 b7 ac 11-67 ac ed 0b 26 2f 9e f1|<:INFO>
11/09/2012 00:52:22 ServerApiManager||Method: getHardwareAttribute args: ALL|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) Getting Hardware info: Detecting Server Hardware - this can take several minutes|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) VMware: passed detection validation|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) Vendor=VMware, Inc.|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) HWModel=VMware|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) CPUCount=1|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) CPUType=Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) CPUSpeed=3300|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) MEMSize=4096|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) BIOSVer=PhoenixTechnologiesLTD 6.00 07/02/2012|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) ObjectId=VMware|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) OSVersion=UCOS 4.0.0.0-16|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|(CAPTURE) SerialNumber=VMware-56 4d 5e 36 15 b7 ac 11-67 ac ed 0b 26 2f 9e f1|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|Initializing the hardware API|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|Initializing the history log API|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|Initialize metering|<:DEBUG>
11/09/2012 00:52:22 upgrade_manager.sh|Copying /mnt/source/Cisco/base_scripts/progmeter to /common/download/7.1.5.30000-1/base_scripts/progmeter|<:DEBUG>
11/09/2012 00:52:26 upgrade_manager.sh|Upgrade from 7.1.2.21900-5 allowed|<:DEBUG>
11/09/2012 00:52:26 upgrade_manager.sh| new version is 7.1.5.30000-1|<:INFO>
11/09/2012 00:52:26 upgrade_manager.sh|Not a restricted to unrestricted upgrade|<:INFO>
11/09/2012 00:52:26 upgrade_manager.sh|Checking free space for the upgrade|<:INFO>
11/09/2012 00:52:26 upgrade_manager.sh|Checking free space for applications|<:INFO>
11/09/2012 00:52:27 upgrade_manager.sh|(CAPTURE)   Free space : 33918226432|<:DEBUG>
11/09/2012 00:52:27 upgrade_manager.sh|(CAPTURE) Space needed : 6370897920|<:DEBUG>
11/09/2012 00:52:27 upgrade_manager.sh|Free space check complete|<:INFO>
11/09/2012 00:52:27 ServerApiManager|In main with args -|initialize|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:27 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:27 ServerApiManager|In main with args -|setDetailedHardwareSpecs enable|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 00:52:27 Serverpak|IN INITIALIZE model = VMware statefile=  /tmp/hssi_api_state_file|<:INFO>
11/09/2012 00:52:27 Serverpak|DEBUG: Current Directory=/mnt/source/Cisco/hssi/shared/bin|<:INFO>
11/09/2012 00:52:27 Serverpak|In runtime of supported args [setDetailedHardwareSpecs enable]|<:INFO>
11/09/2012 00:52:27 Serverpak|In runtime of VMWARE args [setDetailedHardwareSpecs enable]|<:INFO>
11/09/2012 00:52:27 Serverpak|In runtime of server_implementation args [setDetailedHardwareSpecs enable]|<:INFO>
11/09/2012 00:52:27 Serverpak|DEBUG: nothing to be setup for generic implementation|<:INFO>
11/09/2012 00:52:27 Serverpak|server_implementation shared_implementation.sh setDetailedHardwareSpecs enable returns (0)|<:INFO>
11/09/2012 00:52:27 Serverpak|VMWARE shared_implementation.sh setDetailedHardwareSpecs enable returns (0)|<:INFO>
11/09/2012 00:52:27 Serverpak|supported api_implementation.sh setDetailedHardwareSpecs enable returns (0)|<:INFO>
11/09/2012 00:52:27 ServerApiManager||Method: setDetailedHardwareSpecs args: enable|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 00:52:27 upgrade_manager.sh|About to upgrade and copy source files src_dir=/mnt/source base_path=/common/download/7.1.5.30000-1|<:DEBUG>
11/09/2012 00:52:27 upgrade_manager.sh|Copying source files to /common/rpm-archive/7.1.5.30000-1 src_dir=/mnt/source|<:INFO>
11/09/2012 01:13:13 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_bin/PlatformXmlUpg /common/rpm-archive/7.1.5.30000-1/base_bin/"|<:DEBUG>
11/09/2012 01:13:13 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/adminAccountsWrap.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:13 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/AppInstall /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:13 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/appmanager.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/auditd.conf.source /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/auditd_func /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/audit.rules.source /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/authenticateFile /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/callmanager_mid_install.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/cancel_download.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/cancel_upgrade.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/CCMInstall /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ccm-trace-spacers.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/check_comp.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/check_file_fragmentation.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/check_process.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/check_size.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/chkpatch /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/cleanup_misc.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/copfile_syslog.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/copy_and_authenticate.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/coresident_switch.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/cpulimit_script.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/create_ntp_watchdog_cron_job.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/detach_from_parent /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/display_screen /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/dump_diagnostic_functions.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/dump_diagnostic_information.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/encryptCCMPin.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/encryptCCMPassword.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/env.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/exclude_file /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/filefrag /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/file_list.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/file_test.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/filter.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/firewall.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/format_partition.py /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ftp_list.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ftp_load.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ftp_sftp_errval /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/gen_checksum_file /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_active_version.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_ccm_version.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_cuc_version.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_inactive_version.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_parent_procs_IDs.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_primary_interface_name.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get-reg-value.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_timezone_list.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/get_user_data /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/grub_swap_impl.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/grub_add.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/grub_del.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/grub_swap.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hardware_check.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hosts.allow.source /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hosts.deny.source /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hwcheck /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hw_based_install.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hw_functions.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hw_settings.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/hw_validation /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iaccount_impl /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iaccount.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iaccount.so /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/IBMjtzu.zip /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/icertificate_impl /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/icertificate.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/icertificate.so /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/icluster_data_sync_list /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/icluster_impl /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/icluster.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/icluster.so /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iftp /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ihardware.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ihardware_impl /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ihardware_legacy.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ihardware.so /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ihistory_impl /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ihistory.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ilog.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ilog.so /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ilog2.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ilog_impl /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/install_notification_registration.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/INSTALLATION_FAILED /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/InstallWizard /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/install_rpm.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iowait_monitor /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iowait_monitor.conf /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/io_monitor_controller.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ip6tables /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ipp2ipt /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ipprefs /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ipprefs_bulk.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iproduct_impl /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iproduct.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iproduct.so /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/iptables /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/isClusterNodeValid.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/isftp /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/itar /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/izip /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/joinxml.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/legacy_hw_settings.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/LicenseMac.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/list_cluster.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/locale_install.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/local_list.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/local_load.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/logrotate_wrapper /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/mfginstall.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/networkDiagnostic.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/networkFaultTolerance.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/nic_reverse /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntpRunningStatus.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntpUtilities.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_check_sub_configuration.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_check_stratum.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_check_servers_reachability.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_check_drift.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_one_shot.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_reachability.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_start.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_stop.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/ntp_validate_servers.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/parse_upgrade_log /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/patch.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/pkgorder /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/platform_blockssh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/platformConfAux.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/pmNormalizeFtp /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/pmNormalizeGeneric /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/post_install.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/post_rpm_upgrade.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/post_scripts_upgrade.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/prepare_tape.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/primNodeVerify.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/process_monitor.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/procNodeVerify.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/prodInterface.xml /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/product_blockssh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/product_sudoers /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/productConfig.xml /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/product_profile /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/profile /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/progmeter /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/rclocalmgr.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/rcsysinit.source /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/reboot.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/regenerate_all_certs.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/reggetval /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/regparse /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/removeRootAccess.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/restore_ethernet_interface.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/rtmt_logger.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sam_hw_settings.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_auto_mirror.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_cancelInstall.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_dnssetup /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_domainname /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_gethostbyname /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_hostname /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_hostsetup /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_hostupdate /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_hwdetect /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_ifconfig /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_installprefs /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_iptables /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_killInstall.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_killPartitionB_PIDs.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_language /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_ntp /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_ntpdate /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_ntpkey /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_prefs /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_raidconfig /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_set_clock.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sd_zoneinfo /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/server_api_manager.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/server_specific_install.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/set_dev_permissions /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sftp_connect_wrapper.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sftp_get_file.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sftp_list.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sftp_load.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/show_ipv6_settings.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/SIGNED_FILTER /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/size_update.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/smtp_test /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/snmpHWInfo.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/snmpUpgrade.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/spin.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/sysctlconf.source /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/systemcmd.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/terminal_io /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/tftp_upload_security.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/tzupdater.jar /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/upgrade_manager.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/upgrade_platform_certs.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/upgrade_validate_file.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/upgrade_drf.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/upgrade_install.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/upgrade_get_file.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/upgrade_monitor /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/usb_key_detect /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/validateDHCP.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/validate_ipv6_address.py /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/validateNetworking.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/verifyNetwork /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/verify_rpm_checksum.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/verify_web_connection.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/xmlfoo /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/base_scripts/xml_writer.sh /common/rpm-archive/7.1.5.30000-1/base_scripts/"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/add_performance_governor.sh /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm_post /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/dir5.20.02su2agent.rpm_pre /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/dir5.20.02su2agent.rpm_post /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:15 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/dir5.20.02su2agent.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm_pre /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm_post /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hpadu-8.26-1.noarch.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hponcfg-1.9.0-3.noarch.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hp-finish /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hp-health-8.2.6-5.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hp-ilo-8.2.6-3.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hp-OpenIPMI-8.2.6-4.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hp-snmp-agents-8.2.6-6.custom.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/hp_watchdog /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/ibm_da_install /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/ibm_dsa-2.12-rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/ibm_sw_dir_5.20.02su2_linux_i386.sh.withinstallscripts /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/ibm_sw_dir_5.20.02pfm_linux_i386.sh.withinstallscripts /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/iLO2_flash_post /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/iLO2_flash /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/lsi_mr_hhr-00.05.0503-1.rhel4.i386_06_19_09.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/mptlinux-redhat4.0-3.13.04.00-2.i686.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/net-snmp-5.1.2-13.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/performance_governor /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/snmp_conf_setup /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/hssi/install_pool/vos_ibm_da.5.20.2-1.0-rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/HWRPMS"|<:DEBUG>
11/09/2012 01:13:16 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/bin/gen_hw_cache /common/rpm-archive/7.1.5.30000-1/install/bin/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/callmanager.conf /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/callmanager_hw.dat /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/connection.conf /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/connection_hw.dat /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/copfile_rules /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/coresident.conf /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/coresident_hw.dat /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/from_version_rules /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/hw_rpm_map.txt /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/Iaccount.jar /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/Icertificate.jar /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/Icluster.jar /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/Ihardware.jar /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/Ihistory.jar /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/Iproduct.jar /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/check_root_cron_job.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/configure_core_and_syslogd.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/create_jdk_links.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/disable_services.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/disable_ntp_from_dhcp.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/fix_issue.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/initialize_logging.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/install_platform_prefs.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/install_master_rpm.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/ipmi_service.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/net-snmp_service.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/product_info.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/relocate_java.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/setup_ntp_watchdog.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/setup_java_api.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/setup_ntp.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/setup_root_access.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/smartd_service.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/swap_nic_if.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/TEMPLATE.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/temp_workaround.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/update_iptables.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/update_install_conf_unrst.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/update_install_conf.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/update_rc_sysinit.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/setup/utils.sh /common/rpm-archive/7.1.5.30000-1/install/setup/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/to_version_rules /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/upgrade-messages.properties /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/install/upgrade-messages.xml /common/rpm-archive/7.1.5.30000-1/install/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/ccm/conf/ccm_add_grp_members.cnf /common/rpm-archive/7.1.5.30000-1/.security/accounts/ccm/conf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/ccm/conf/ccm_create_user_accnt.cnf /common/rpm-archive/7.1.5.30000-1/.security/accounts/ccm/conf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/ccm/create_ccm_accounts.sh /common/rpm-archive/7.1.5.30000-1/.security/accounts/ccm/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/conf/add_grp_members.cnf /common/rpm-archive/7.1.5.30000-1/.security/accounts/conf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/conf/change_world_perms.cnf /common/rpm-archive/7.1.5.30000-1/.security/accounts/conf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/conf/create_user_accnt.cnf /common/rpm-archive/7.1.5.30000-1/.security/accounts/conf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/create_special_accounts.sh /common/rpm-archive/7.1.5.30000-1/.security/accounts/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/accounts/create_usergrp_accnt.sh /common/rpm-archive/7.1.5.30000-1/.security/accounts/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/admin/adminAccounts.sh /common/rpm-archive/7.1.5.30000-1/.security/admin/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/admin/adminAddSudo.sh /common/rpm-archive/7.1.5.30000-1/.security/admin/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/admin/adminRmSudo.sh /common/rpm-archive/7.1.5.30000-1/.security/admin/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/admin/sudoers.sh /common/rpm-archive/7.1.5.30000-1/.security/admin/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ccm/firstnode_init.sh /common/rpm-archive/7.1.5.30000-1/.security/ccm/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ccm/setccmservicedetails.sh /common/rpm-archive/7.1.5.30000-1/.security/ccm/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ccm/subsequentnode_init.sh /common/rpm-archive/7.1.5.30000-1/.security/ccm/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ccm/sudoers.sh /common/rpm-archive/7.1.5.30000-1/.security/ccm/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/ExportPrivClassPath /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/ExportPriv.class /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/generate_selfsigned_cert_pem.sh /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/generate_selfsigned_cert.sh /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/gen_keystore_pwd.sh /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/locateCertDirs.sh /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/locateX509Details.sh /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/merge_cert_conf_files.sh /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/cert/perform_cert.sh /common/rpm-archive/7.1.5.30000-1/.security/cert/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/clm/sudoers.sh /common/rpm-archive/7.1.5.30000-1/.security/clm/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/drf/drfkeys_shell.sh /common/rpm-archive/7.1.5.30000-1/.security/drf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/drf/enable_drf_clusternode.sh /common/rpm-archive/7.1.5.30000-1/.security/drf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/drf/setdrfdetails.sh /common/rpm-archive/7.1.5.30000-1/.security/drf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/drf/sudoers.sh /common/rpm-archive/7.1.5.30000-1/.security/drf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/drf/tardd.sh /common/rpm-archive/7.1.5.30000-1/.security/drf/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/3951_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/3951_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/3rdPartyPhone_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/3rdPartyPhone_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/6600_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/6600_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7902_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7902_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7905_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7905_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7910_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7910_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7911_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7911_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7912_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7912_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7920_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7920_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7921_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7921_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7931_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7931_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7935_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7935_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7936_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7936_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7937_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7941_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7941_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7942_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7942_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7945_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7945_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7960_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7960_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7970_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7970_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7975_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7975_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7985_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/7985_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/9971_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/ata_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/ata_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/ccmPatch_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/ccmPatch_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/CM_sec_patch_release.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/CM_sec_patch_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/CM_sec_patch2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/csa_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/csa_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/devicePack_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/devicePack_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/DST_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/intDialplan_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/intDialplan_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/IPCom_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/IPCom_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/IPPhoneCommonCode_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/IPPhoneCommonCode_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/locale_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/locale_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/telepres_sip_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/telepres_sip_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionLocale_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionLocale_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionFriendly_cop2_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionFriendly_cop_dev.xml /common/rpm-archive/7.1.5.30000-1/.security/install_file_signing/xml_public_keys/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/create_ipsecuser.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/dblping_ipsec.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/disable_ipsec.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/enable_ipsec_clusternode.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/enable_ipsec.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/gen_ipsec_selfsigned.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/handshake_ipsec.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/initialize_ipsec.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/ipsecuser_shell.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/ipsec-config.txt /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/ipsec_initd /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/ipsec_init_unmonitored.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/ipsec_validate.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/iptable_ipsec.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/perform_ipsec_cert.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/setup_policies.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/set_ipsecuser_pwd.exp /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/start_ipsec.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/start_racoon.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/ipsec/stop_racoon.sh /common/rpm-archive/7.1.5.30000-1/.security/ipsec/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/post_appinstall.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/product_sd_upgrade.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/product_sd_postinstall.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/product_sd_install.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/pwrecovery/dummy /common/rpm-archive/7.1.5.30000-1/.security/pwrecovery/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/pwrecovery/sudoers.sh /common/rpm-archive/7.1.5.30000-1/.security/pwrecovery/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/secure_sd_upgrade.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/secure_sd_postinstall.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/secure_sd_install.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/setkeysdetails.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/download_windows.sh /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/generate_ssh_keys.exp /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/set_sftp_pwd.exp /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/sftp_config /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/sftp_connect.sh /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/sftp_knownhosts.exp /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/sftp_password.exp /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/ssh_PK_setup.sh /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/sftp/update_sftpuser_pwd.sh /common/rpm-archive/7.1.5.30000-1/.security/sftp/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/cleanup_files.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/harden.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/immunize.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/ip6tables /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/ipprefs.conf /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:22 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/iptables /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/logrotate_mgetty.source /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/logrotate_syslog.source /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/secure_files_permission.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/stop_services.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/unimmunize.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/update_profile.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/system/update_syslog_details.sh /common/rpm-archive/7.1.5.30000-1/.security/system/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat_sd_upgrade.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/catalina.sh.source /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/catalina.policy.source /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/context.xml.source /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/display_tomcat_cert.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/favicon.ico /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/gen_tomcat_shutdown.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/gen_tomcat_users.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/gen_tomcatkeystore_pwd.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/gen_tomcat_selfsigned.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/logging.properties.source /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/manager.xml.source /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/robots.txt /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/server.xml.source /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/sudoers.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/tomcat_security_startup.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/tomcat /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/tomcatJlauncherConfig.xml /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/tomcat_diagnostics.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/tomcat_oninit.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/tomcat_startup.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/update_catalina_policy.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/update_logging.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/update_startup.sh /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat/web.xml.source /common/rpm-archive/7.1.5.30000-1/.security/tomcat/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/tomcat_sd_install.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/update_user_pwd.exp /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./Cisco/.security/update_usr_pmd.sh /common/rpm-archive/7.1.5.30000-1/.security/"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ac-2.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-alarm-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-amc-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-auditlogd-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-authentication-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-axl-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-bps-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-capf-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-car-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ccmadmin-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ccmcip-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ccmhelp-1.1.0.0-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ccmivr-6.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ccmmib-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ccmuser-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ccm-5.0.1.0-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cdp-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cdrdlv-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cef-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cfrt-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cmi-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cmplatform-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cmtomcat-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-CTIManager-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ctlc-plugin-6.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ctlp-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-cucreports-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-dbl-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-dbms-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:35 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-devicepack-1.0.0.0-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:53 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-dhcp-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:53 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-dirsync-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:13:53 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-dna-5.0.0.2-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-em-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-encryption-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-grt-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:13 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-idp-5.0.1.0-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:13 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ipvmsd-6.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ipma-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:49 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ipvms-7.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:14:52 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-jtapi-plugin-7.1.5.10000-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:15 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-lib-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:18 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-licensing-2.0.0.0-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:18 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-locale-english_united_states-7.1.0.1-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-log4jinit-servlet-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-lpm-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-pd-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-pi-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:30 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-reporter-servlet-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:30 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-reporter-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:33 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-RIS-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:38 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-rtmt-servlet-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:16:40 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-rtmt-client-plugin-0.0.0.2-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-scheduler-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-script-5.0.1.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-security-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:31 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-soap-realtimeservice-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:31 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-soap-perfmonservice-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:31 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:31 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:31 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-srstctlclient-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:31 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-svc-web-0.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:37 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-sysapp-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:40 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-syslog-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:40 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-taps-plugin-7.0.2.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:42 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-tct-svc-0.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:45 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-tftp-1.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:45 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-tomcatstats-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:45 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-tsp-plugin-7.1.5.2-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-uxl-1.1.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-ver-7.1.5.30000-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/cm-webdialer-0.0.0.1-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/fiostats-0.99.2-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/kmod-updates-1-1.rh4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/master-7.1.5.30000-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/os-services-1.2-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-ver-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-util-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-ui-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-tzdata-2009o-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-tomcat-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-servM-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-sec-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-script-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-remotesupport-2.0.0.1-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-licensing-2.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-ipsec-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:51 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-install-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:51 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-drf-2.0.0.2-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:53 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-csa-5.2.0-296.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:56 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-common-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:56 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-cm-2.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:56 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-clm-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:58 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/APPRPMS/platform-api-3.0.0.0-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:17:58 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/acl-2.2.23-5.4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/acpid-1.0.3-2.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/activation-1.0.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ash-0.3.8-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/attr-2.4.16-3.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/at-3.1.8-82.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/audit-1.0.16-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/audit-libs-1.0.16-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/authconfig-4.6.10-7.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/basesystem-8.0-4.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/bash-3.0-19.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:03 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/bc-1.06-17.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:03 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/beecrypt-3.1.0-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:03 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/bind-libs-9.2.4-30.el4_8.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:06 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/bind-utils-9.2.4-30.el4_8.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:06 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/binutils-2.15.92.0.2-25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:08 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/bzip2-1.0.2-14.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:08 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/bzip2-libs-1.0.2-14.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:08 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/cactus-12.1.5-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/chkconfig-1.3.13.5.EL4-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/compat-libstdc++-296-2.96-132.7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/compat-db-4.1.25-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/compat-libstdc++-33-3.2.3-47.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:11 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/comps-4AS-0.20080711.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:18 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/coreutils-5.2.1-31.8.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:21 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/cpio-2.5-16.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:21 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/cracklib-2.8.9-1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:21 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/cracklib-dicts-2.8.9-1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/crontabs-1.10-7.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/curl-7.12.1-11.1.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/cyrus-sasl-md5-2.1.19-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:23 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/cyrus-sasl-2.1.19-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:26 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/db4-4.2.52-7.3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:26 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/dbus-0.22-12.EL.9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:26 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/dbus-glib-0.22-12.EL.9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:26 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/device-mapper-1.02.25-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:26 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/dhclient-3.0.1-65.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:26 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/dhcpv6_client-0.10-24_EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:26 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/dhcp-3.0.1-65.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/diffutils-2.8.1-12.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/dos2unix-3.1-21.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/dosfstools-2.8-18.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/e2fsprogs-1.35-12.17.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ecs-1.4.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/eject-2.0.13-11.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/elfutils-libelf-0.97.1-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/elfutils-0.97.1-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:28 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/elixir-4.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:38 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ethtool-6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:38 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/expat-1.95.7-4.el4_8.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:38 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/expect-5.42.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:38 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/filesystem-2.3.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:38 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/file-4.10-5.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:41 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/findutils-4.1.20-7.el4.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:41 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/fior-0.99.1-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:41 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/gawk-3.1.3-10.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:41 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/gdbm-1.8.0-24.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:41 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/gdb-6.3.0.0-1.159.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:43 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/glib2-2.4.7-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:43 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/glibc-2.3.4-2.41.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:18:48 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/glibc-common-2.3.4-2.41.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/glib-1.2.10-15.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/gmp-4.1.4-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/gnupg-1.2.6-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/gpm-1.20.1-71.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/grep-2.5.1-32.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/grub-0.95-3.8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/gzip-1.3.3-17.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/hdparm-5.7-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/hotplug-2004_04_01-7.8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/hwdata-0.146.33.EL-11.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/info-4.7-5.el4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/initscripts-7.93.33-1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/iproute-2.6.9-4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:01 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ipsec-tools-0.3.3-7.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/iptables-1.2.11-3.2.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/iptables-ipv6-1.2.11-3.2.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/iputils-20020927-21.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ipv6-kernel-update-2.6.9-78.v2.ELsmp.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:07 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/java-provides-1.0.0.2-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:09 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/jaxm-1.1.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:19:09 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/jdk-1.6.0_17-fcs.i586.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/kbd-1.12-2.el4.5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/kernel-2.6.9-78.EL.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/kernel-smp-2.6.9-78.EL.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:24 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/kernel-utils-2.4-18.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:27 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/krb5-libs-1.3.4-62.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:27 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/krb5-workstation-1.3.4-62.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:27 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/kudzu-1.1.95.23-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:27 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/less-382-4.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:27 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libacl-2.2.23-5.4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:27 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libattr-2.4.16-3.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libcap-1.10-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libgcc-3.4.6-10.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libgcrypt-1.2.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libgpg-error-1.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libidn-0.5.6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libpcap-0.8.3-12.el4_6.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libselinux-1.19.1-7.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libsepol-1.1.1-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libstdc++-3.4.6-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libtermcap-2.0.8-39.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libtool-libs-1.5.6-4.EL4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libuser-0.52.5-1.el4.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libxml2-python-2.6.16-12.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libxml2-2.6.16-12.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/libxslt-1.1.11-1.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/lm_sensors-2.8.7-2.40.5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/log4j-1.2.8-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/logrotate-3.7.1-10.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/lsof-4.72-1.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/lsscsi-0.22-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/lvm2-2.02.37-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:37 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/mail-1.0.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:37 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/MAKEDEV-3.15.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:37 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/make-3.80-7.EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:37 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/mgetty-1.1.31-14.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:37 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/mingetty-1.07-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/mkinitrd-4.2.1.13-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/mktemp-1.5-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/module-init-tools-3.1-0.pre5.3.10.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/mt-st-0.8-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ncurses-5.4-15.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/nc-1.10-22.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ndisc6-0.9.3-1.el4.rf.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/netdump-server-0.7.16-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/netdump-0.7.16-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/net-tools-1.60-39.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/newt-0.51.6-10.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/nscd-2.3.4-2.41.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/nss_ldap-253-5.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:42 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/ntp-4.2.0.a.20040617-8.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/OpenIPMI-libs-1.4.14-1.4E.20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/OpenIPMI-1.4.14-1.4E.20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/openldap-2.2.13-12.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/openssh-server-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/openssh-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/openssh-clients-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/openssl096b-0.9.6b-22.46.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/openssl-0.9.7a-43.17.el4_8.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/os-ver-4.0.0.0-33.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/pam-0.77-66.25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/pam_krb5-2.1.17-6.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/passwd-0.68-10.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:49 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/patch-2.5.4-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:49 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/pciutils-2.1.99.test8-3.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:49 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/pcre-4.5-4.el4_6.6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:49 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/pdksh-5.2.14-30.6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:49 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/perl-5.8.5-36.el4_6.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/perl-Filter-1.30-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/pgjdbc-7.3.3-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/policycoreutils-1.18.1-4.13.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/popt-1.9.1-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/preferences-1.0.1-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/procps-3.2.3-8.12.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/psmisc-21.4-4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:20:59 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/python-2.3.4-14.7.el4_8.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/PyXML-0.8.3-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/radvd-0.7.2-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/readline-4.3-13.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:04 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/redhat-logos-1.1.26-1.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:09 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/redhat-release-4AS-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/regexp-1.3-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/rootfiles-8-1.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/rpm-4.3.3-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/rpm-libs-4.3.3-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/rsync-2.6.3-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/saaj-1.3-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/schedutils-1.4.0-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:12 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/screen-4.0.2-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/sed-4.1.2-7.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/setarch-1.6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/setserial-2.17-17.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/setup-2.5.37-1.7.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/sg3_utils-1.22-3.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/shadow-utils-4.0.3-66.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:14 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/slang-1.4.9-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:17 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/snmp-mon-0.0.0.19-17.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:17 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/star-1.5a25-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:17 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/strace-4.5.16-1.el4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:17 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/struts-1.1-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/stunnel-4.05-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/sudo-1.6.7p5-30.1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/sysfsutils-1.2.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:29 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/sysklogd-1.4.1-27.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/sysreport-1.3.15-8.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/sysstat-5.0.5-19.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/SysVinit-2.85-34.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tar-1.14-12.5.1.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tcl-8.4.7-4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tcpdump-3.8.2-12.el4_6.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tcp_wrappers-7.6-37.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tcsh-6.13-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:32 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/termcap-5.4-3.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tftp-0.39-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/time-1.7-25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tmpwatch-2.9.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:34 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tomcat-6.0.20-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/traceroute-1.4a12-24.EL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/tzdata-2009o-2.el4.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/udev-039-10.22.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:39 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/unixODBC-2.2.11-1.RHEL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:42 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/unzip-5.51-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:42 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/usbutils-0.11-7.RHEL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:42 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/utempter-0.5.5-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:42 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/util-linux-2.12a-24.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:42 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/vim-common-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:44 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/vim-enhanced-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/vim-minimal-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/vixie-cron-4.1-50.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/which-2.16-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:47 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/words-3.0-3.2.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:50 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/xalan-2.7.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:53 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/xerces-2.6.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:55 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/xmlstarlet-1.0.1-1.i586.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:55 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/zip-2.3-29.EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:55 upgrade_manager.sh|Calling "cp /mnt/source/./RedHat/RPMS/zlib-1.2.1.2-1.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS"|<:DEBUG>
11/09/2012 01:21:55 upgrade_manager.sh|Copying HWRPMS to /common/rpm-archive/7.1.5.30000-1|<:INFO>
11/09/2012 01:21:55 ServerApiManager|In main with args -|initialize|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:21:55 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:21:55 ServerApiManager|In main with args -|getHwRpmList /common/rpm-archive/7.1.5.30000-1|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:21:56 Serverpak|IN INITIALIZE model = VMware statefile=  /tmp/hssi_api_state_file|<:INFO>
11/09/2012 01:21:56 Serverpak|DEBUG: Current Directory=/mnt/source/Cisco/hssi/shared/bin|<:INFO>
11/09/2012 01:21:57 Serverpak|In runtime of supported args [getHwRpmList]|<:INFO>
11/09/2012 01:21:57 Serverpak|In runtime of VMWARE args [getHwRpmList]|<:INFO>
11/09/2012 01:21:58 Serverpak|In runtime of server_implementation args [getHwRpmList]|<:INFO>
11/09/2012 01:21:58 Serverpak|server_implementation shared_implementation.sh getHwRpmList returns (1)|<:INFO>
11/09/2012 01:21:58 Serverpak|VMWARE shared_implementation.sh getHwRpmList returns (1)|<:INFO>
11/09/2012 01:21:58 Serverpak|supported api_implementation.sh getHwRpmList returns (1)|<:INFO>
11/09/2012 01:21:58 ServerApiManager||Method: getHwRpmList args: /common/rpm-archive/7.1.5.30000-1|- current mode=HSSI_Mode completed with code [1]|<:DEBUG>
11/09/2012 01:21:58 upgrade_manager.sh|rpm_list is  |<:INFO>
11/09/2012 01:21:58 upgrade_manager.sh|No H/W RPMS found to install|<:WARN>
11/09/2012 01:21:58 ServerApiManager|In main with args -|initialize|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:21:58 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:21:58 ServerApiManager|In main with args -|SRCVENDORDIR /mnt/source|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:21:58 ServerApiManager|SRCVENDORDIR called|<:DEBUG>
11/09/2012 01:21:58 ServerApiManager|SRCVENDORDIR=/mnt/source/Cisco/hssi|<:DEBUG>
11/09/2012 01:21:58 ServerApiManager||Method: SRCVENDORDIR args: /mnt/source|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:21:58 ServerApiManager|In main with args -|DESTVENDORDIR|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:21:58 ServerApiManager|DESTVENDORDIR called|<:DEBUG>
11/09/2012 01:21:58 ServerApiManager|DESTVENDORDIR = /usr/local/bin/hssi|<:DEBUG>
11/09/2012 01:21:58 ServerApiManager||Method: DESTVENDORDIR args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:21:58 upgrade_manager.sh|Copying vendor information to /common/rpm-archive/7.1.5.30000-1|<:INFO>
11/09/2012 01:21:58 upgrade_manager.sh|Src Vendor Dir=/mnt/source/Cisco/hssi: Dest vendor=/usr/local/bin/hssi: Dest Vendor Dir=/common/rpm-archive/7.1.5.30000-1/hssi: |<:DEBUG>
11/09/2012 01:21:58 ServerApiManager|In main with args -|getVendorFileList /mnt/source/Cisco/hssi|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:21:58 Serverpak|IN INITIALIZE model = VMware statefile=  /tmp/hssi_api_state_file|<:INFO>
11/09/2012 01:21:58 Serverpak|DEBUG: Current Directory=/mnt/source/Cisco/hssi/shared/bin|<:INFO>
11/09/2012 01:21:58 Serverpak|DEBUG: vendorfilelist checking that 23178 and 23178 are same |<:INFO>
11/09/2012 01:21:58 Serverpak|DEBUG: adding list of files from /mnt/source/Cisco/hssi|<:INFO>
11/09/2012 01:21:58 Serverpak|In runtime of supported args [getVendorFileList /mnt/source/Cisco/hssi]|<:INFO>
11/09/2012 01:21:58 Serverpak|In runtime of VMWARE args [HssiDefines]|<:INFO>
11/09/2012 01:21:59 Serverpak|In runtime of server_implementation args [HssiDefines]|<:INFO>
11/09/2012 01:21:59 Serverpak|server_implementation shared_implementation.sh HssiDefines returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|VMWARE shared_implementation.sh HssiDefines returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|DEBUG: GETVENDORFILELIST CALLED on supported|<:INFO>
11/09/2012 01:21:59 Serverpak|DEBUG: GETVENDORFILELIST CALLED ARGS -/mnt/source/Cisco/hssi-|<:INFO>
11/09/2012 01:21:59 Serverpak|DEBUG: GETVENDORFILELIST CALLED mylist -server_implementation/VMWARE/supported/shared/bin/api_implementation.sh
server_implementation/VMWARE/supported/shared/bin/README.TXT
server_implementation/VMWARE/supported/shared/bin/supported.data
server_implementation/VMWARE/supported/shared/bin/TRANS.TBL
server_implementation/VMWARE/supported/shared/README.TXT
server_implementation/VMWARE/supported/shared/TRANS.TBL-|<:INFO>
11/09/2012 01:21:59 Serverpak|In runtime of VMWARE args [getVendorFileList /mnt/source/Cisco/hssi]|<:INFO>
11/09/2012 01:21:59 Serverpak|DEBUG: GETVENDORFILELIST CALLED on VMWARE|<:INFO>
11/09/2012 01:21:59 Serverpak|DEBUG: GETVENDORFILELIST CALLED mylist -server_implementation/VMWARE/shared/bin/install_pool.meta
server_implementation/VMWARE/shared/bin/shared_implementation.sh
server_implementation/VMWARE/shared/bin/TRANS.TBL
server_implementation/VMWARE/shared/bin/VMWARE.data
server_implementation/VMWARE/shared/hcf/TRANS.TBL
server_implementation/VMWARE/shared/hcf/VMwareTools-4.0.0-164009.tar.gz
server_implementation/VMWARE/shared/TRANS.TBL-|<:INFO>
11/09/2012 01:21:59 Serverpak|In runtime of server_implementation args [getVendorFileList /mnt/source/Cisco/hssi]|<:INFO>
11/09/2012 01:21:59 Serverpak|DEBUG: GETVENDORFILELIST CALLED on server_implementation|<:INFO>
11/09/2012 01:21:59 Serverpak|DEBUG: GETVENDORFILELIST CALLED mylist -server_implementation/shared/bin/get_internal_USBkey.sh
server_implementation/shared/bin/hssi_bc
server_implementation/shared/bin/install_pool.meta
server_implementation/shared/bin/README.TXT
server_implementation/shared/bin/shared_implementation.sh
server_implementation/shared/bin/TRANS.TBL
server_implementation/shared/hcf/hcf_bios_setup.sh
server_implementation/shared/hcf/hcf_modules_preload.sh
server_implementation/shared/hcf/hcf_update.sh
server_implementation/shared/hcf/README.TXT
server_implementation/shared/hcf/TRANS.TBL
server_implementation/shared/README.TXT
server_implementation/shared/TRANS.TBL-|<:INFO>
11/09/2012 01:21:59 Serverpak|server_implementation shared_implementation.sh getVendorFileList /mnt/source/Cisco/hssi returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|VMWARE shared_implementation.sh getVendorFileList /mnt/source/Cisco/hssi returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|supported api_implementation.sh getVendorFileList /mnt/source/Cisco/hssi returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|In runtime of supported args [getInstallPoolMetaFiles]|<:INFO>
11/09/2012 01:21:59 Serverpak|getInstallPoolMetaFiles - No install_pool.meta file in /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin.|<:INFO>
11/09/2012 01:21:59 Serverpak|In runtime of VMWARE args [getInstallPoolMetaFiles]|<:INFO>
11/09/2012 01:21:59 Serverpak|getInstallPoolMetaFiles - Found install_pool.meta file in /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin//mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/install_pool.meta.|<:INFO>
11/09/2012 01:21:59 Serverpak|In runtime of server_implementation args [getInstallPoolMetaFiles]|<:INFO>
11/09/2012 01:21:59 Serverpak|getInstallPoolMetaFiles - Found install_pool.meta file in /mnt/source/Cisco/hssi/server_implementation/shared/bin//mnt/source/Cisco/hssi/server_implementation/shared/bin/install_pool.meta.|<:INFO>
11/09/2012 01:21:59 Serverpak|server_implementation shared_implementation.sh getInstallPoolMetaFiles returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|VMWARE shared_implementation.sh getInstallPoolMetaFiles returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|supported api_implementation.sh getInstallPoolMetaFiles returns (0)|<:INFO>
11/09/2012 01:21:59 Serverpak|Found the following metaFiles: /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/install_pool.meta
/mnt/source/Cisco/hssi/server_implementation/shared/bin/install_pool.meta|<:INFO>
11/09/2012 01:22:00 Serverpak|Found the following contents: 100    pre-reboot    net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm
110   pre-reboot     net-snmp-5.1.2-13.el4_7.2.i386.rpm
120   pre-reboot      net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm
200  post-reboot  apcupsd-3.14.0-1.el4.i386.rpm
220 pre-reboot mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm|<:INFO>
11/09/2012 01:22:00 Serverpak|HSSIAPI: getInstallPoolFiles - Found the following contents: 100    pre-reboot    net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm
11/09/2012 01:22:00 Serverpak|HSSIAPI: getInstallPoolFiles - order:100 phase:pre-reboot pack:net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm opts:|<:INFO>
11/09/2012 01:22:00 Serverpak|HSSIAPI: getInstallPoolFiles - order:110 phase:pre-reboot pack:net-snmp-5.1.2-13.el4_7.2.i386.rpm opts:|<:INFO>
11/09/2012 01:22:00 Serverpak|HSSIAPI: getInstallPoolFiles - order:120 phase:pre-reboot pack:net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm opts:|<:INFO>
11/09/2012 01:22:00 Serverpak|HSSIAPI: getInstallPoolFiles - order:200 phase:post-reboot pack:apcupsd-3.14.0-1.el4.i386.rpm opts:|<:INFO>
11/09/2012 01:22:00 Serverpak|HSSIAPI: getInstallPoolFiles - order:220 phase:pre-reboot pack:mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm opts:|<:INFO>
11/09/2012 01:22:00 Serverpak|Full Install Pool files: install_pool/net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm
install_pool/net-snmp-5.1.2-13.el4_7.2.i386.rpm
install_pool/net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm
install_pool/apcupsd-3.14.0-1.el4.i386.rpm
install_pool/apcupsd-3.14.0-1.el4.i386.rpm_post
install_pool/mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm|<:INFO>
11/09/2012 01:22:00 ServerApiManager||Method: getVendorFileList args: /mnt/source/Cisco/hssi|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/get_pid.sh, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/hssi_api.sh, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/hssi_defines.sh, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/hssi_hcf_defines.sh, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/hssi_server_defines.sh, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/hssi_warn.sh, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/README.TXT, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/bin/shared_implementation.sh, dir=shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/hcf/README.TXT, dir=shared/hcf, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared/hcf|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=shared/README.TXT, dir=shared, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/shared|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=server_implementation/VMWARE/supported/shared/bin/api_implementation.sh, dir=server_implementation/VMWARE/supported/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin|<:DEBUG>
11/09/2012 01:22:00 upgrade_manager.sh|file=server_implementation/VMWARE/supported/shared/bin/README.TXT, dir=server_implementation/VMWARE/supported/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin|<:DEBUG>
11/09/2012 01:22:05 upgrade_manager.sh|file=server_implementation/VMWARE/supported/shared/bin/supported.data, dir=server_implementation/VMWARE/supported/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin|<:DEBUG>
11/09/2012 01:22:05 upgrade_manager.sh|file=server_implementation/VMWARE/supported/shared/README.TXT, dir=server_implementation/VMWARE/supported/shared, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared|<:DEBUG>
11/09/2012 01:22:05 upgrade_manager.sh|file=server_implementation/VMWARE/shared/bin/install_pool.meta, dir=server_implementation/VMWARE/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin|<:DEBUG>
11/09/2012 01:22:05 upgrade_manager.sh|file=server_implementation/VMWARE/shared/bin/shared_implementation.sh, dir=server_implementation/VMWARE/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin|<:DEBUG>
11/09/2012 01:22:05 upgrade_manager.sh|file=server_implementation/VMWARE/shared/bin/VMWARE.data, dir=server_implementation/VMWARE/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin|<:DEBUG>
11/09/2012 01:22:05 upgrade_manager.sh|file=server_implementation/VMWARE/shared/hcf/VMwareTools-4.0.0-164009.tar.gz, dir=server_implementation/VMWARE/shared/hcf, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/hcf|<:DEBUG>
11/09/2012 01:22:30 upgrade_manager.sh|file=server_implementation/shared/bin/get_internal_USBkey.sh, dir=server_implementation/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/bin/hssi_bc, dir=server_implementation/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/bin/install_pool.meta, dir=server_implementation/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/bin/README.TXT, dir=server_implementation/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/bin/shared_implementation.sh, dir=server_implementation/shared/bin, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/hcf/hcf_bios_setup.sh, dir=server_implementation/shared/hcf, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/hcf/hcf_modules_preload.sh, dir=server_implementation/shared/hcf, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/hcf/hcf_update.sh, dir=server_implementation/shared/hcf, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/hcf/README.TXT, dir=server_implementation/shared/hcf, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=server_implementation/shared/README.TXT, dir=server_implementation/shared, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=install_pool/net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm, dir=install_pool, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/install_pool|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=install_pool/net-snmp-5.1.2-13.el4_7.2.i386.rpm, dir=install_pool, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/install_pool|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=install_pool/net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm, dir=install_pool, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/install_pool|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=install_pool/apcupsd-3.14.0-1.el4.i386.rpm, dir=install_pool, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/install_pool|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=install_pool/apcupsd-3.14.0-1.el4.i386.rpm_post, dir=install_pool, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/install_pool|<:DEBUG>
11/09/2012 01:22:33 upgrade_manager.sh|file=install_pool/mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm, dir=install_pool, dest_dir=/common/rpm-archive/7.1.5.30000-1/hssi/install_pool|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/get_pid.sh /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/hssi_api.sh /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/hssi_defines.sh /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/hssi_hcf_defines.sh /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/hssi_server_defines.sh /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/hssi_warn.sh /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/bin/shared_implementation.sh /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/hcf/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/shared/hcf"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/shared/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/shared"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/api_implementation.sh /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/supported.data /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/install_pool.meta /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/shared_implementation.sh /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/VMWARE.data /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/hcf/VMwareTools-4.0.0-164009.tar.gz /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/hcf"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/bin/get_internal_USBkey.sh /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/bin/hssi_bc /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/bin/install_pool.meta /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/bin/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/bin/shared_implementation.sh /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_bios_setup.sh /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_modules_preload.sh /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_update.sh /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/hcf/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/hcf"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/server_implementation/shared/README.TXT /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/hssi/install_pool"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-5.1.2-13.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/hssi/install_pool"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/hssi/install_pool"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/hssi/install_pool"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm_post /common/rpm-archive/7.1.5.30000-1/hssi/install_pool"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/hssi/install_pool/mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm /common/rpm-archive/7.1.5.30000-1/hssi/install_pool"|<:DEBUG>
11/09/2012 01:22:36 upgrade_manager.sh|copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi|<:DEBUG>
11/09/2012 01:22:36 ServerApiManager|In main with args -|initialize|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:36 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:36 ServerApiManager|In main with args -|copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi|- called file |/mnt/source/Cisco/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:36 Serverpak|IN INITIALIZE model = VMware statefile=  /tmp/hssi_api_state_file|<:INFO>
11/09/2012 01:22:36 Serverpak|DEBUG: Current Directory=/mnt/source/Cisco/hssi/shared/bin|<:INFO>
11/09/2012 01:22:36 Serverpak|DEBUG: copying links from /mnt/source/Cisco/hssi to /common/rpm-archive/7.1.5.30000-1/hssi|<:INFO>
11/09/2012 01:22:36 Serverpak|In runtime of supported args [copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi]|<:INFO>
11/09/2012 01:22:36 Serverpak|In runtime of VMWARE args [HssiDefines]|<:INFO>
11/09/2012 01:22:36 Serverpak|In runtime of server_implementation args [HssiDefines]|<:INFO>
11/09/2012 01:22:36 Serverpak|server_implementation shared_implementation.sh HssiDefines returns (0)|<:INFO>
11/09/2012 01:22:36 Serverpak|VMWARE shared_implementation.sh HssiDefines returns (0)|<:INFO>
11/09/2012 01:22:36 Serverpak|DEBUG: regenerating Vendor links from /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported to /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported|<:INFO>
11/09/2012 01:22:36 Serverpak|DEBUG: calling super from ::copyVendorLinks|<:INFO>
11/09/2012 01:22:36 Serverpak|In runtime of VMWARE args [copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi]|<:INFO>
11/09/2012 01:22:36 Serverpak|DEBUG: regenerating Vendor links from /mnt/source/Cisco/hssi/server_implementation/VMWARE to /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE|<:INFO>
11/09/2012 01:22:36 Serverpak|In runtime of server_implementation args [copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi]|<:INFO>
11/09/2012 01:22:36 Serverpak|DEBUG: regenerating Vendor links from /mnt/source/Cisco/hssi/server_implementation to /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation|<:INFO>
11/09/2012 01:22:41 Serverpak|server_implementation shared_implementation.sh copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi returns (0)|<:INFO>
11/09/2012 01:22:41 Serverpak|VMWARE shared_implementation.sh copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi returns (0)|<:INFO>
11/09/2012 01:22:41 Serverpak|supported api_implementation.sh copyVendorLinks /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi returns (0)|<:INFO>
11/09/2012 01:22:41 ServerApiManager||Method: copyVendorLinks args: /mnt/source/Cisco/hssi /common/rpm-archive/7.1.5.30000-1/hssi|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:41 upgrade_manager.sh|Cleanup mounted DVD or ISO|<:INFO>
11/09/2012 01:22:41 upgrade_manager.sh|Found mount point, /mnt/source, source filesystem /dev/hdc|<:DEBUG>
11/09/2012 01:22:41 upgrade_manager.sh|Unmount /mnt/source|<:DEBUG>
11/09/2012 01:22:41 upgrade_manager.sh|Ejecting DVD (/dev/hdc)|<:DEBUG>
11/09/2012 01:22:42 upgrade_manager.sh|Checking free space for the upgrade|<:INFO>
11/09/2012 01:22:42 upgrade_manager.sh|Free space check complete|<:INFO>
11/09/2012 01:22:42 upgrade_manager.sh|Stop iowait_monitor|<:INFO>
11/09/2012 01:22:43 upgrade_manager.sh|Start new iowait_monitor|<:INFO>
11/09/2012 01:22:43 upgrade_manager.sh|Upgrading platform|<:INFO>
11/09/2012 01:22:43 upgrade_manager.sh|/common/rpm-archive/7.1.5.30000-1/base_scripts/upgrade_os.sh|<:DEBUG>
11/09/2012 01:22:43 upgrade_manager.sh|-r-xr-xr-x  1 root root 82242 Nov  9 01:13 /common/rpm-archive/7.1.5.30000-1/base_scripts/upgrade_os.sh|<:DEBUG>
11/09/2012 01:22:43 upgrade_manager.sh|Invoking OS upgrade script|<:INFO>
11/09/2012 01:22:43 upgrade_manager.sh|/common/rpm-archive/7.1.5.30000-1/base_scripts/upgrade_os.sh basepath=/common/rpm-archive/7.1.5.30000-1|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|(CAPTURE) Parse argument basepath=/common/rpm-archive/7.1.5.30000-1|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|(CAPTURE) Initialize logging|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/check_root_cron_job.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/configure_core_and_syslogd.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/create_jdk_links.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/disable_ntp_from_dhcp.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/disable_services.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/fix_issue.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/initialize_logging.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/install_master_rpm.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/install_platform_prefs.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/ipmi_service.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/net-snmp_service.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/product_info.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/relocate_java.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/setup_java_api.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/setup_ntp.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/setup_ntp_watchdog.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/setup_root_access.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/smartd_service.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/swap_nic_if.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/TEMPLATE.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/temp_workaround.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/update_install_conf.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/update_install_conf_unrst.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/update_iptables.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/update_rc_sysinit.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Calling "source /common/rpm-archive/7.1.5.30000-1/install/setup/utils.sh"|<:DEBUG>
11/09/2012 01:22:44 upgrade_os.sh|Upgrade OS RTMTStart|<:NOTICE>
11/09/2012 01:22:44 upgrade_os.sh|Upgrade OS starting|<:INFO>
11/09/2012 01:22:44 upgrade_os.sh|ihardware API about to be sourced at /common/rpm-archive/7.1.5.30000-1/base_scripts/ihardware.sh|<:DEBUG>
11/09/2012 01:22:44 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:44 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:44 ServerApiManager|In main with args -|reset|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:45 Serverpak|In runtime of server_implementation args [definesPath]|<:INFO>
11/09/2012 01:22:45 Serverpak|server_implementation shared_implementation.sh definesPath returns (0)|<:INFO>
11/09/2012 01:22:45 Serverpak|In runtime of VMWARE args [definesPath]|<:INFO>
11/09/2012 01:22:45 Serverpak|VMWARE shared_implementation.sh definesPath returns (0)|<:INFO>
11/09/2012 01:22:46 Serverpak|In runtime of supported args [detect_and_validate]|<:INFO>
11/09/2012 01:22:46 Serverpak|In /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin self detection|<:INFO>
11/09/2012 01:22:46 Serverpak|In runtime of supported args [serverDetect]|<:INFO>
11/09/2012 01:22:46 Serverpak|In runtime of VMWARE args [serverDetect]|<:INFO>
11/09/2012 01:22:46 Serverpak|In runtime of VMWARE args [expected_manufacturer]|<:INFO>
11/09/2012 01:22:46 Serverpak|VMWARE shared_implementation.sh expected_manufacturer returns (0)|<:INFO>
11/09/2012 01:22:46 Serverpak|In runtime of VMWARE args [Vendor]|<:INFO>
11/09/2012 01:22:46 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 01:22:47 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:47 Serverpak|VMWARE shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:47 Serverpak|DEBUG: we have a manufacturer match: VMware|<:INFO>
11/09/2012 01:22:47 Serverpak|DEBUG: |<:INFO>
11/09/2012 01:22:47 Serverpak|VMWARE shared_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 01:22:47 Serverpak|supported api_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 01:22:47 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server as self - do validation|<:INFO>
11/09/2012 01:22:47 Serverpak|In runtime of supported args [serverValidate]|<:INFO>
11/09/2012 01:22:47 Serverpak|Validating CPU info|<:INFO>
11/09/2012 01:22:47 Serverpak|In runtime of supported args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:47 Serverpak|In runtime of VMWARE args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:47 Serverpak|In runtime of server_implementation args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:47 Serverpak|server_implementation shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:47 Serverpak|VMWARE shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:47 Serverpak|supported api_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of supported args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of VMWARE args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of server_implementation args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:48 Serverpak|server_implementation shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:48 Serverpak|VMWARE shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:48 Serverpak|supported api_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of VMWARE args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of server_implementation args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 01:22:48 Serverpak|DEBUG: validation Error |<:INFO>
11/09/2012 01:22:48 Serverpak|server_implementation shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 01:22:48 Serverpak|VMWARE shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 01:22:48 Serverpak|CPU validation Completed - Validating Disk|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of supported args [expected_disk_count]|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of VMWARE args [expected_disk_count]|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of server_implementation args [expected_disk_count]|<:INFO>
11/09/2012 01:22:48 Serverpak|server_implementation shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:48 Serverpak|VMWARE shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:48 Serverpak|supported api_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of supported args [expected_min_disk_size]|<:INFO>
11/09/2012 01:22:48 Serverpak|supported api_implementation.sh expected_min_disk_size returns (0)|<:INFO>
11/09/2012 01:22:48 Serverpak|In runtime of supported args [expected_disk_units]|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh expected_disk_units returns (0)|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [validatePhysicalDisk_Count_Size_Units 72 GB]|<:INFO>
11/09/2012 01:22:49 Serverpak|VMware overload of validatePhysicalDisk_count exectuing.|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [getNumberOfDisks]|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [expected_min_disk_size]|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh expected_min_disk_size returns (0)|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [expected_disk_units]|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [required_min_disk_count]|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh required_min_disk_count returns (0)|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [required_disk1_location]|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh required_disk1_location returns (0)|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [required_disk1_size]|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of VMWARE args [required_disk1_size]|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of server_implementation args [required_disk1_size]|<:INFO>
11/09/2012 01:22:49 Serverpak|server_implementation shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:49 Serverpak|VMWARE shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [required_disk1_units]|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of VMWARE args [required_disk1_units]|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of server_implementation args [required_disk1_units]|<:INFO>
11/09/2012 01:22:49 Serverpak|server_implementation shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:49 Serverpak|VMWARE shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [alternate_min_disk_count]|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh alternate_min_disk_count returns (0)|<:INFO>
11/09/2012 01:22:49 Serverpak|In runtime of supported args [alternate_disk1_location]|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh alternate_disk1_location returns (0)|<:INFO>
11/09/2012 01:22:49 Serverpak|supported api_implementation.sh getNumberOfDisks returns (1)|<:INFO>
11/09/2012 01:22:50 Serverpak|supported api_implementation.sh validatePhysicalDisk_Count_Size_Units 72 GB returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|Disk validation Completed - Validating Memory|<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of supported args [expected_min_memory]|<:INFO>
11/09/2012 01:22:50 Serverpak|supported api_implementation.sh expected_min_memory returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of supported args [expected_memory_units]|<:INFO>
11/09/2012 01:22:50 Serverpak|supported api_implementation.sh expected_memory_units returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of VMWARE args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of server_implementation args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 01:22:50 Serverpak|DEBUG: MISMATCHED UNITS a=MB e=GB|<:INFO>
11/09/2012 01:22:50 Serverpak|DEBUG: MISMATCHED UNITS converted old=1 GB new=1024 MB|<:INFO>
11/09/2012 01:22:50 Serverpak|DEBUG: MEMORY COMPARISON result is 1 with a=4096 e=1024|<:INFO>
11/09/2012 01:22:50 Serverpak|DEBUG: we have a capacity match: 1024 MB|<:INFO>
11/09/2012 01:22:50 Serverpak|server_implementation shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|VMWARE shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of supported args [expected_max_memory]|<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of VMWARE args [expected_max_memory]|<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of server_implementation args [expected_max_memory]|<:INFO>
11/09/2012 01:22:50 Serverpak|server_implementation shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:50 Serverpak|VMWARE shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:50 Serverpak|supported api_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:50 Serverpak|Max Memory validation bypassed... no maximum specified|<:INFO>
11/09/2012 01:22:50 Serverpak|supported api_implementation.sh serverValidate returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server validated as supported|<:INFO>
11/09/2012 01:22:50 Serverpak|supported api_implementation.sh detect_and_validate returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|HSSI_API ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh returned 0 and errors= |<:INFO>
11/09/2012 01:22:50 Serverpak|In runtime of supported args [HWModel]|<:INFO>
11/09/2012 01:22:50 Serverpak|supported api_implementation.sh HWModel returns (0)|<:INFO>
11/09/2012 01:22:50 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> hardware_implementation_paths = ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh|<:INFO>
11/09/2012 01:22:50 Serverpak|HSSI_API VALIDATE_DECTECT ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh path|<:INFO>
11/09/2012 01:22:50 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> HWModel = VMware|<:INFO>
11/09/2012 01:22:50 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:22:50 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:22:51 ServerApiManager||Method: reset args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:51 upgrade_os.sh|Initialize internal data|<:INFO>
11/09/2012 01:22:51 upgrade_os.sh|Initialize install.conf variable|<:DEBUG>
11/09/2012 01:22:51 upgrade_os.sh|Initialize product API|<:DEBUG>
11/09/2012 01:22:51 upgrade_os.sh|Initialize hardware API|<:DEBUG>
11/09/2012 01:22:51 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
11/09/2012 01:22:51 Serverpak|In runtime of supported args [detect_and_validate]|<:INFO>
11/09/2012 01:22:51 Serverpak|In /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin self detection|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of supported args [serverDetect]|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of VMWARE args [serverDetect]|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of VMWARE args [expected_manufacturer]|<:INFO>
11/09/2012 01:22:51 Serverpak|VMWARE shared_implementation.sh expected_manufacturer returns (0)|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of VMWARE args [Vendor]|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 01:22:51 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:51 Serverpak|VMWARE shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:51 Serverpak|DEBUG: we have a manufacturer match: VMware|<:INFO>
11/09/2012 01:22:51 Serverpak|DEBUG: |<:INFO>
11/09/2012 01:22:51 Serverpak|VMWARE shared_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 01:22:51 Serverpak|supported api_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 01:22:51 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server as self - do validation|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of supported args [serverValidate]|<:INFO>
11/09/2012 01:22:51 Serverpak|Validating CPU info|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of supported args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of VMWARE args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of server_implementation args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:51 Serverpak|server_implementation shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:51 Serverpak|VMWARE shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:51 Serverpak|supported api_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of supported args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of VMWARE args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of server_implementation args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:51 Serverpak|server_implementation shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:51 Serverpak|VMWARE shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:51 Serverpak|supported api_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:51 Serverpak|In runtime of VMWARE args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of server_implementation args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 01:22:52 Serverpak|DEBUG: validation Error |<:INFO>
11/09/2012 01:22:52 Serverpak|server_implementation shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 01:22:52 Serverpak|VMWARE shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 01:22:52 Serverpak|CPU validation Completed - Validating Disk|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [expected_disk_count]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of VMWARE args [expected_disk_count]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of server_implementation args [expected_disk_count]|<:INFO>
11/09/2012 01:22:52 Serverpak|server_implementation shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:52 Serverpak|VMWARE shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:52 Serverpak|supported api_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [expected_min_disk_size]|<:INFO>
11/09/2012 01:22:52 Serverpak|supported api_implementation.sh expected_min_disk_size returns (0)|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [expected_disk_units]|<:INFO>
11/09/2012 01:22:52 Serverpak|supported api_implementation.sh expected_disk_units returns (0)|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [validatePhysicalDisk_Count_Size_Units 72 GB]|<:INFO>
11/09/2012 01:22:52 Serverpak|VMware overload of validatePhysicalDisk_count exectuing.|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [getNumberOfDisks]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [required_min_disk_count]|<:INFO>
11/09/2012 01:22:52 Serverpak|supported api_implementation.sh required_min_disk_count returns (0)|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [required_disk1_location]|<:INFO>
11/09/2012 01:22:52 Serverpak|supported api_implementation.sh required_disk1_location returns (0)|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [required_disk1_size]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of VMWARE args [required_disk1_size]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of server_implementation args [required_disk1_size]|<:INFO>
11/09/2012 01:22:52 Serverpak|server_implementation shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:52 Serverpak|VMWARE shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:52 Serverpak|supported api_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of supported args [required_disk1_units]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of VMWARE args [required_disk1_units]|<:INFO>
11/09/2012 01:22:52 Serverpak|In runtime of server_implementation args [required_disk1_units]|<:INFO>
11/09/2012 01:22:53 Serverpak|server_implementation shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:53 Serverpak|VMWARE shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of supported args [alternate_min_disk_count]|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh alternate_min_disk_count returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of supported args [alternate_disk1_location]|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh alternate_disk1_location returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh getNumberOfDisks returns (1)|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh validatePhysicalDisk_Count_Size_Units 72 GB returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|Disk validation Completed - Validating Memory|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of supported args [expected_min_memory]|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh expected_min_memory returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of supported args [expected_memory_units]|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh expected_memory_units returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of VMWARE args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of server_implementation args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 01:22:53 Serverpak|DEBUG: MISMATCHED UNITS a=MB e=GB|<:INFO>
11/09/2012 01:22:53 Serverpak|DEBUG: MISMATCHED UNITS converted old=1 GB new=1024 MB|<:INFO>
11/09/2012 01:22:53 Serverpak|DEBUG: MEMORY COMPARISON result is 1 with a=4096 e=1024|<:INFO>
11/09/2012 01:22:53 Serverpak|DEBUG: we have a capacity match: 1024 MB|<:INFO>
11/09/2012 01:22:53 Serverpak|server_implementation shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|VMWARE shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of supported args [expected_max_memory]|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of VMWARE args [expected_max_memory]|<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of server_implementation args [expected_max_memory]|<:INFO>
11/09/2012 01:22:53 Serverpak|server_implementation shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:53 Serverpak|VMWARE shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:53 Serverpak|Max Memory validation bypassed... no maximum specified|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh serverValidate returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server validated as supported|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh detect_and_validate returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|HSSI_API ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh returned 0 and errors= |<:INFO>
11/09/2012 01:22:53 Serverpak|In runtime of supported args [HWModel]|<:INFO>
11/09/2012 01:22:53 Serverpak|supported api_implementation.sh HWModel returns (0)|<:INFO>
11/09/2012 01:22:53 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> hardware_implementation_paths = ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of supported args [HWModel]|<:INFO>
11/09/2012 01:22:54 Serverpak|supported api_implementation.sh HWModel returns (0)|<:INFO>
11/09/2012 01:22:54 Serverpak|HSSI_API VALIDATE_DECTECT ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh path|<:INFO>
11/09/2012 01:22:54 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> HWModel = VMware|<:INFO>
11/09/2012 01:22:54 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:22:54 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:22:54 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
11/09/2012 01:22:54 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:54 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:54 ServerApiManager|In main with args -|initHardwareLibrary /common/rpm-archive/7.1.5.30000-1/vendor/misc/bin/hwdetect /common/rpm-archive/7.1.5.30000-1/base_scripts/hw_validation /common/rpm-archive/7.1.5.30000-1/vendor/HWTABLE.data /partB/etc/hwprofile|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:54 ServerApiManager|Sam_reset being called|<:DEBUG>
11/09/2012 01:22:54 ServerApiManager||Method: initHardwareLibrary args: /common/rpm-archive/7.1.5.30000-1/vendor/misc/bin/hwdetect /common/rpm-archive/7.1.5.30000-1/base_scripts/hw_validation /common/rpm-archive/7.1.5.30000-1/vendor/HWTABLE.data /partB/etc/hwprofile|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:54 upgrade_os.sh|Initialize chroot variables|<:DEBUG>
11/09/2012 01:22:54 upgrade_os.sh|Initialize hardware attributes|<:DEBUG>
11/09/2012 01:22:54 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
11/09/2012 01:22:54 Serverpak|In runtime of supported args [detect_and_validate]|<:INFO>
11/09/2012 01:22:54 Serverpak|In /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin self detection|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of supported args [serverDetect]|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of VMWARE args [serverDetect]|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of VMWARE args [expected_manufacturer]|<:INFO>
11/09/2012 01:22:54 Serverpak|VMWARE shared_implementation.sh expected_manufacturer returns (0)|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of VMWARE args [Vendor]|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 01:22:54 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:54 Serverpak|VMWARE shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:54 Serverpak|DEBUG: we have a manufacturer match: VMware|<:INFO>
11/09/2012 01:22:54 Serverpak|DEBUG: |<:INFO>
11/09/2012 01:22:54 Serverpak|VMWARE shared_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 01:22:54 Serverpak|supported api_implementation.sh serverDetect returns (0)|<:INFO>
11/09/2012 01:22:54 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server as self - do validation|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of supported args [serverValidate]|<:INFO>
11/09/2012 01:22:54 Serverpak|Validating CPU info|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of supported args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of VMWARE args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of server_implementation args [expected_cpu_count]|<:INFO>
11/09/2012 01:22:54 Serverpak|server_implementation shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:54 Serverpak|VMWARE shared_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:54 Serverpak|supported api_implementation.sh expected_cpu_count returns (1)|<:INFO>
11/09/2012 01:22:54 Serverpak|In runtime of supported args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of VMWARE args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of server_implementation args [expected_cpu_speed]|<:INFO>
11/09/2012 01:22:55 Serverpak|server_implementation shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:55 Serverpak|VMWARE shared_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:55 Serverpak|supported api_implementation.sh expected_cpu_speed returns (1)|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of VMWARE args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of server_implementation args [validateCPU_Count_Speed]|<:INFO>
11/09/2012 01:22:55 Serverpak|DEBUG: validation Error |<:INFO>
11/09/2012 01:22:55 Serverpak|server_implementation shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 01:22:55 Serverpak|VMWARE shared_implementation.sh validateCPU_Count_Speed returns (0)|<:INFO>
11/09/2012 01:22:55 Serverpak|CPU validation Completed - Validating Disk|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [expected_disk_count]|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of VMWARE args [expected_disk_count]|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of server_implementation args [expected_disk_count]|<:INFO>
11/09/2012 01:22:55 Serverpak|server_implementation shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:55 Serverpak|VMWARE shared_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:55 Serverpak|supported api_implementation.sh expected_disk_count returns (1)|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [expected_min_disk_size]|<:INFO>
11/09/2012 01:22:55 Serverpak|supported api_implementation.sh expected_min_disk_size returns (0)|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [expected_disk_units]|<:INFO>
11/09/2012 01:22:55 Serverpak|supported api_implementation.sh expected_disk_units returns (0)|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [validatePhysicalDisk_Count_Size_Units 72 GB]|<:INFO>
11/09/2012 01:22:55 Serverpak|VMware overload of validatePhysicalDisk_count exectuing.|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [getNumberOfDisks]|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [required_min_disk_count]|<:INFO>
11/09/2012 01:22:55 Serverpak|supported api_implementation.sh required_min_disk_count returns (0)|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [required_disk1_location]|<:INFO>
11/09/2012 01:22:55 Serverpak|supported api_implementation.sh required_disk1_location returns (0)|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of supported args [required_disk1_size]|<:INFO>
11/09/2012 01:22:55 Serverpak|In runtime of VMWARE args [required_disk1_size]|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of server_implementation args [required_disk1_size]|<:INFO>
11/09/2012 01:22:56 Serverpak|server_implementation shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:56 Serverpak|VMWARE shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of supported args [required_disk1_units]|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of VMWARE args [required_disk1_units]|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of server_implementation args [required_disk1_units]|<:INFO>
11/09/2012 01:22:56 Serverpak|server_implementation shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:56 Serverpak|VMWARE shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of supported args [alternate_min_disk_count]|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh alternate_min_disk_count returns (0)|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of supported args [alternate_disk1_location]|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh alternate_disk1_location returns (0)|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh getNumberOfDisks returns (1)|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh validatePhysicalDisk_Count_Size_Units 72 GB returns (0)|<:INFO>
11/09/2012 01:22:56 Serverpak|Disk validation Completed - Validating Memory|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of supported args [expected_min_memory]|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh expected_min_memory returns (0)|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of supported args [expected_memory_units]|<:INFO>
11/09/2012 01:22:56 Serverpak|supported api_implementation.sh expected_memory_units returns (0)|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of VMWARE args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of server_implementation args [validateMinimumMemory_Size_Units 1 GB]|<:INFO>
11/09/2012 01:22:56 Serverpak|DEBUG: MISMATCHED UNITS a=MB e=GB|<:INFO>
11/09/2012 01:22:56 Serverpak|DEBUG: MISMATCHED UNITS converted old=1 GB new=1024 MB|<:INFO>
11/09/2012 01:22:56 Serverpak|DEBUG: MEMORY COMPARISON result is 1 with a=4096 e=1024|<:INFO>
11/09/2012 01:22:56 Serverpak|DEBUG: we have a capacity match: 1024 MB|<:INFO>
11/09/2012 01:22:56 Serverpak|server_implementation shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 01:22:56 Serverpak|VMWARE shared_implementation.sh validateMinimumMemory_Size_Units 1 GB returns (0)|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of supported args [expected_max_memory]|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of VMWARE args [expected_max_memory]|<:INFO>
11/09/2012 01:22:56 Serverpak|In runtime of server_implementation args [expected_max_memory]|<:INFO>
11/09/2012 01:22:57 Serverpak|server_implementation shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:57 Serverpak|VMWARE shared_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:57 Serverpak|supported api_implementation.sh expected_max_memory returns (1)|<:INFO>
11/09/2012 01:22:57 Serverpak|Max Memory validation bypassed... no maximum specified|<:INFO>
11/09/2012 01:22:57 Serverpak|supported api_implementation.sh serverValidate returns (0)|<:INFO>
11/09/2012 01:22:57 Serverpak|../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh detected server validated as supported|<:INFO>
11/09/2012 01:22:57 Serverpak|supported api_implementation.sh detect_and_validate returns (0)|<:INFO>
11/09/2012 01:22:57 Serverpak|HSSI_API ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh returned 0 and errors= |<:INFO>
11/09/2012 01:22:57 Serverpak|In runtime of supported args [HWModel]|<:INFO>
11/09/2012 01:22:57 Serverpak|supported api_implementation.sh HWModel returns (0)|<:INFO>
11/09/2012 01:22:57 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> hardware_implementation_paths = ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh|<:INFO>
11/09/2012 01:22:57 Serverpak|HSSI_API VALIDATE_DECTECT ../../server_implementation/VMWARE/supported/shared/bin/api_implementation.sh path|<:INFO>
11/09/2012 01:22:57 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> HWModel = VMware|<:INFO>
11/09/2012 01:22:57 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:22:57 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:22:57 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
11/09/2012 01:22:57 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:57 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:57 ServerApiManager|In main with args -|getHardwareAttribute HWModel|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:57 Serverpak|[VMware] retrieved from cache for key -[HWModel]-|<:INFO>
11/09/2012 01:22:57 ServerApiManager||Method: getHardwareAttribute args: HWModel|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:57 ServerApiManager|In main with args -|getHardwareAttribute CPUSpeed|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:57 Serverpak|In runtime of supported args [getHardwareAttribute CPUSpeedInMHz]|<:INFO>
11/09/2012 01:22:57 Serverpak|In runtime of supported args [CPUSpeedInMHz]|<:INFO>
11/09/2012 01:22:57 Serverpak|In runtime of VMWARE args [CPUSpeedInMHz]|<:INFO>
11/09/2012 01:22:57 Serverpak|In runtime of server_implementation args [CPUSpeedInMHz]|<:INFO>
11/09/2012 01:22:57 Serverpak|server_implementation shared_implementation.sh CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 01:22:57 Serverpak|VMWARE shared_implementation.sh CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 01:22:57 Serverpak|supported api_implementation.sh CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 01:22:57 Serverpak|supported api_implementation.sh getHardwareAttribute CPUSpeedInMHz returns (0)|<:INFO>
11/09/2012 01:22:57 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> CPUSpeed = 3300|<:INFO>
11/09/2012 01:22:57 ServerApiManager||Method: getHardwareAttribute args: CPUSpeed|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:58 ServerApiManager|In main with args -|getHardwareAttribute Vendor|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:58 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:22:58 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:22:58 Serverpak|In runtime of supported args [Vendor]|<:INFO>
11/09/2012 01:22:58 Serverpak|In runtime of VMWARE args [Vendor]|<:INFO>
11/09/2012 01:22:58 Serverpak|In runtime of server_implementation args [Vendor]|<:INFO>
11/09/2012 01:22:58 Serverpak|server_implementation shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:58 Serverpak|VMWARE shared_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:58 Serverpak|supported api_implementation.sh Vendor returns (0)|<:INFO>
11/09/2012 01:22:58 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> Vendor = VMware, Inc.|<:INFO>
11/09/2012 01:22:58 ServerApiManager||Method: getHardwareAttribute args: Vendor|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Initialize RPM repository variables|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Initialize mkfs label variable|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Initialize inactive partition device|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Calling /sbin/findfs LABEL=/|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Mount point / is device /dev/sda1|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Label is /, device is /dev/sda1|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Initialize internal data complete|<:INFO>
11/09/2012 01:22:58 upgrade_os.sh|Validate System RTMTStart|<:NOTICE>
11/09/2012 01:22:58 upgrade_os.sh|Validate master RPM exists|<:INFO>
11/09/2012 01:22:58 upgrade_os.sh|Validate hardware for the upgrade|<:INFO>
11/09/2012 01:22:58 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:58 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:58 ServerApiManager|In main with args -|isHardwareValid|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:58 ServerApiManager||Method: isHardwareValid args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:58 upgrade_os.sh|Validate hardware for "callmanager" deployment|<:INFO>
11/09/2012 01:22:59 ServerApiManager|In main with args -|isHardwareValidForDeployment callmanager|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:22:59 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:22:59 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:22:59 Serverpak|In runtime of supported args [getSupportedDeployments]|<:INFO>
11/09/2012 01:22:59 Serverpak|In runtime of VMWARE args [validateMinimumMemory_Size_Units 6 GB]|<:INFO>
11/09/2012 01:22:59 Serverpak|In runtime of server_implementation args [validateMinimumMemory_Size_Units 6 GB]|<:INFO>
11/09/2012 01:22:59 Serverpak|DEBUG: MISMATCHED UNITS a=MB e=GB|<:INFO>
11/09/2012 01:22:59 Serverpak|DEBUG: MISMATCHED UNITS converted old=6 GB new=6144 MB|<:INFO>
11/09/2012 01:22:59 Serverpak|DEBUG: MEMORY COMPARISON result is 2 with a=4096 e=6144|<:INFO>
11/09/2012 01:22:59 Serverpak|DEBUG: Memory Size Validation Mismatch: found [4096 MB] expecting [6144 MB]|<:INFO>
11/09/2012 01:22:59 Serverpak|server_implementation shared_implementation.sh validateMinimumMemory_Size_Units 6 GB returns (1)|<:INFO>
11/09/2012 01:22:59 Serverpak|VMWARE shared_implementation.sh validateMinimumMemory_Size_Units 6 GB returns (1)|<:INFO>
11/09/2012 01:22:59 Serverpak|supported api_implementation.sh getSupportedDeployments returns (0)|<:INFO>
11/09/2012 01:22:59 ServerApiManager||Method: isHardwareValidForDeployment args: callmanager|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:22:59 upgrade_os.sh|Validate System RTMTFinish|<:NOTICE>
11/09/2012 01:22:59 upgrade_os.sh|Pre-install processing|<:INFO>
11/09/2012 01:22:59 upgrade_os.sh|Remove inactive partition from boot loader|<:INFO>
11/09/2012 01:22:59 upgrade_os.sh|Calling "grub_del.sh --taos-logfile /common/log/install/capture.txt"|<:DEBUG>
11/09/2012 01:22:59 upgrade_os.sh|Format inactive partition|<:INFO>
11/09/2012 01:22:59 upgrade_os.sh|Calling "format_partition.py part=/partB label=/ device=/dev/sda1 pidf=/tmp/format_partition_pid resultf=/tmp/format_partition_results"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Argument part=/partB|<:DEBUG>
11/09/2012 01:23:00 format_partition|Argument label=/|<:DEBUG>
11/09/2012 01:23:00 format_partition|Argument device=/dev/sda1|<:DEBUG>
11/09/2012 01:23:00 format_partition|Argument pidf=/tmp/format_partition_pid|<:DEBUG>
11/09/2012 01:23:00 format_partition|Argument resultf=/tmp/format_partition_results|<:DEBUG>
11/09/2012 01:23:00 format_partition|Generate the pid file, /tmp/format_partition_pid|<:DEBUG>
11/09/2012 01:23:00 format_partition|Open file /tmp/tmp_file_2241|<:DEBUG>
11/09/2012 01:23:00 format_partition|Writing 2241 to /tmp/tmp_file_2241|<:DEBUG>
11/09/2012 01:23:00 format_partition|Renaming /tmp/tmp_file_2241 to /tmp/format_partition_pid|<:DEBUG>
11/09/2012 01:23:00 format_partition|Unmount partition /partB|<:INFO>
11/09/2012 01:23:00 format_partition|Unmount any mounted items on "/partB" mount points|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /proc|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /dev|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /selinux|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /proc/bus/usb|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /sys|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /dev/pts|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /common|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /dev/shm|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /grub|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /proc/sys/fs/binfmt_misc|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB/proc|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser /partB/proc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 upgrade_os.sh|Waiting for pid file, /tmp/format_partition_pid|<:DEBUG>
11/09/2012 01:23:00 upgrade_os.sh|Waiting for "format_partition.py" (2241) to complete|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB/proc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB/proc/sys/fs/binfmt_misc|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser /partB/proc/sys/fs/binfmt_misc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB/proc/sys/fs/binfmt_misc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB/partB|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser /partB/partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB/partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB/grub|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser /partB/grub > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB/grub > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB/common|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser /partB/common > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB/common > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB/sys|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser /partB/sys > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB/sys > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Checking mount point /partB/dev/pts|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser /partB/dev/pts > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB/dev/pts > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Unmount "/partB"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "fuser -k /partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Calling "umount -l /partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Unmount partition /partB complete|<:INFO>
11/09/2012 01:23:00 format_partition|Format partition /partB|<:INFO>
11/09/2012 01:23:00 format_partition|Calling "mkfs -t ext3 -L / /dev/sda1 > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:00 format_partition|Open file /tmp/mkfs_cmd_2241|<:DEBUG>
11/09/2012 01:23:00 format_partition|Create mkfs script /tmp/mkfs_cmd_2241|<:DEBUG>
11/09/2012 01:23:00 format_partition|Make /tmp/mkfs_cmd_2241 executable|<:DEBUG>
11/09/2012 01:23:00 format_partition|Execute /tmp/mkfs_cmd_2241|<:DEBUG>
11/09/2012 01:23:04 format_partition|Remove /tmp/mkfs_cmd_2241|<:DEBUG>
11/09/2012 01:23:04 format_partition|Calling "tune2fs -m 1 -C 0 -i 0 -O dir_index /dev/sda1 > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:04 format_partition|(CAPTURE) tune2fs 1.35 (28-Feb-2004)|<:DEBUG>
11/09/2012 01:23:04 format_partition|(CAPTURE) Setting current mount count to 0|<:DEBUG>
11/09/2012 01:23:04 format_partition|(CAPTURE) Setting interval between check 0 seconds|<:DEBUG>
11/09/2012 01:23:04 format_partition|(CAPTURE) Setting reserved blocks percentage to 1 (33395 blocks)|<:DEBUG>
11/09/2012 01:23:04 format_partition|Format partition /partB complete|<:INFO>
11/09/2012 01:23:04 format_partition|Remount partition /partB|<:INFO>
11/09/2012 01:23:04 format_partition|Calling "mount -l /partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
11/09/2012 01:23:04 format_partition|Remount partition /partB complete|<:INFO>
11/09/2012 01:23:04 format_partition|Generate the result file, /tmp/format_partition_results, and exit|<:DEBUG>
11/09/2012 01:23:04 format_partition|Open file /tmp/tmp_file_2241|<:DEBUG>
11/09/2012 01:23:04 format_partition|Writing 0 to /tmp/tmp_file_2241|<:DEBUG>
11/09/2012 01:23:04 format_partition|Renaming /tmp/tmp_file_2241 to /tmp/format_partition_results|<:DEBUG>
11/09/2012 01:23:04 upgrade_os.sh|"format_partition.py" (2241) is complete (0)|<:DEBUG>
11/09/2012 01:23:04 upgrade_os.sh|Clean up inactive partition log areas|<:INFO>
11/09/2012 01:23:04 upgrade_os.sh|Remove files from /var/log/inactive/|<:DEBUG>
11/09/2012 01:23:04 upgrade_os.sh|Removing immutable attribute|<:INFO>
11/09/2012 01:23:04 upgrade_os.sh|(CAPTURE) usage: chattr [-RV] [-+=AacDdijsSu] [-v version] files...|<:DEBUG>
11/09/2012 01:23:04 upgrade_os.sh|Recursive remove, initial step|<:DEBUG>
11/09/2012 01:23:04 upgrade_os.sh|Removing files up to 1000k, file count: 11|<:DEBUG>
11/09/2012 01:23:06 upgrade_os.sh|Removing files up to 2500k, file count: 1|<:DEBUG>
11/09/2012 01:23:08 upgrade_os.sh|Removing files up to 5000k, file count: 0|<:DEBUG>
11/09/2012 01:23:10 upgrade_os.sh|Removing files up to 10000k, file count: 0|<:DEBUG>
11/09/2012 01:23:12 upgrade_os.sh|Removing files up to 100000k, file count: 0|<:DEBUG>
11/09/2012 01:23:14 upgrade_os.sh|Removing files up to 1000000k, file count: 0|<:DEBUG>
11/09/2012 01:23:16 upgrade_os.sh|Removing files up to 10000000k, file count: 0|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Recursive remove, starting final step|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|File removal for /var/log/inactive/ complete|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Remove directories from /var/log/inactive/|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Clean up rpm_archive area|<:INFO>
11/09/2012 01:23:18 upgrade_os.sh|Examine /common/rpm-archive/7.1.2.21900-5 for removal|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|/common/rpm-archive/RPMS, /common/rpm-archive/7.1.2.21900-5, /common/rpm-archive/7.1.5.30000-1|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Examine /common/rpm-archive/7.1.5.30000-1 for removal|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Pre-install processing complete|<:INFO>
11/09/2012 01:23:18 upgrade_os.sh|Installing the OS on the inactive partition|<:INFO>
11/09/2012 01:23:18 upgrade_os.sh|Generate RAM disk items for the OS install|<:INFO>
11/09/2012 01:23:18 upgrade_os.sh|Calling "mkdir -p  /partB/dev"|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Calling "mknod /partB/dev/null c 1 3"|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Calling "mkdir -p  /partB/etc"|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Calling "cp  /etc/fstab /partB/etc/fstab"|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Generate base_scsi file|<:INFO>
11/09/2012 01:23:18 upgrade_os.sh|Calling "mkdir -p  /partB/opt/cisco/install"|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Copying /opt/cisco/install/base_scsi to /partB/opt/cisco/install/base_scsi|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Calling "cp  /opt/cisco/install/base_scsi /partB/opt/cisco/install/base_scsi"|<:DEBUG>
11/09/2012 01:23:18 upgrade_os.sh|Auditing RPM repository for OS RPMS|<:DEBUG>
11/09/2012 01:23:18 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:18 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:18 ServerApiManager|In main with args -|get_rpm comps-4AS-0.20080711.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:18 ServerApiManager|Found comps-4AS-0.20080711.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:18 ServerApiManager||Method: get_rpm args: comps-4AS-0.20080711.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm hwdata-0.146.33.EL-11.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found hwdata-0.146.33.EL-11.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: hwdata-0.146.33.EL-11.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm libgcc-3.4.6-10.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found libgcc-3.4.6-10.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: libgcc-3.4.6-10.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm redhat-logos-1.1.26-1.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found redhat-logos-1.1.26-1.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: redhat-logos-1.1.26-1.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm rootfiles-8-1.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found rootfiles-8-1.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: rootfiles-8-1.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm setup-2.5.37-1.7.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found setup-2.5.37-1.7.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: setup-2.5.37-1.7.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm filesystem-2.3.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found filesystem-2.3.0-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: filesystem-2.3.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm basesystem-8.0-4.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found basesystem-8.0-4.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: basesystem-8.0-4.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|In main with args -|get_rpm termcap-5.4-3.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:19 ServerApiManager|Found termcap-5.4-3.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:19 ServerApiManager||Method: get_rpm args: termcap-5.4-3.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm tzdata-2009o-2.el4.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found tzdata-2009o-2.el4.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: tzdata-2009o-2.el4.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm glibc-common-2.3.4-2.41.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found glibc-common-2.3.4-2.41.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: glibc-common-2.3.4-2.41.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm glibc-2.3.4-2.41.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found glibc-2.3.4-2.41.i686.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: glibc-2.3.4-2.41.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm audit-libs-1.0.16-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found audit-libs-1.0.16-3.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: audit-libs-1.0.16-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm beecrypt-3.1.0-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found beecrypt-3.1.0-6.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: beecrypt-3.1.0-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm bzip2-libs-1.0.2-14.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found bzip2-libs-1.0.2-14.el4_7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: bzip2-libs-1.0.2-14.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm chkconfig-1.3.13.5.EL4-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found chkconfig-1.3.13.5.EL4-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: chkconfig-1.3.13.5.EL4-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm e2fsprogs-1.35-12.17.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found e2fsprogs-1.35-12.17.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: e2fsprogs-1.35-12.17.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm elfutils-libelf-0.97.1-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|Found elfutils-libelf-0.97.1-5.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager||Method: get_rpm args: elfutils-libelf-0.97.1-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:20 ServerApiManager|In main with args -|get_rpm ethtool-6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found ethtool-6-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: ethtool-6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm expat-1.95.7-4.el4_8.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found expat-1.95.7-4.el4_8.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: expat-1.95.7-4.el4_8.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm gdbm-1.8.0-24.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found gdbm-1.8.0-24.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: gdbm-1.8.0-24.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm glib-1.2.10-15.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found glib-1.2.10-15.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: glib-1.2.10-15.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm glib2-2.4.7-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found glib2-2.4.7-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: glib2-2.4.7-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm hdparm-5.7-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found hdparm-5.7-2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: hdparm-5.7-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm libattr-2.4.16-3.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found libattr-2.4.16-3.1.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: libattr-2.4.16-3.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm libacl-2.2.23-5.4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found libacl-2.2.23-5.4.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: libacl-2.2.23-5.4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm libcap-1.10-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found libcap-1.10-20.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: libcap-1.10-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm libgpg-error-1.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found libgpg-error-1.0-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: libgpg-error-1.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|In main with args -|get_rpm libgcrypt-1.2.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:21 ServerApiManager|Found libgcrypt-1.2.0-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:21 ServerApiManager||Method: get_rpm args: libgcrypt-1.2.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm libselinux-1.19.1-7.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found libselinux-1.19.1-7.4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: libselinux-1.19.1-7.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm device-mapper-1.02.25-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found device-mapper-1.02.25-2.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: device-mapper-1.02.25-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm libsepol-1.1.1-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found libsepol-1.1.1-2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: libsepol-1.1.1-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm libstdc++-3.4.6-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found libstdc++-3.4.6-9.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: libstdc++-3.4.6-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm db4-4.2.52-7.3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found db4-4.2.52-7.3.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: db4-4.2.52-7.3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm gmp-4.1.4-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found gmp-4.1.4-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: gmp-4.1.4-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm libtermcap-2.0.8-39.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found libtermcap-2.0.8-39.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: libtermcap-2.0.8-39.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm lsscsi-0.22-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found lsscsi-0.22-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: lsscsi-0.22-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm mingetty-1.07-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found mingetty-1.07-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: mingetty-1.07-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm mktemp-1.5-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|Found mktemp-1.5-20.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager||Method: get_rpm args: mktemp-1.5-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:22 ServerApiManager|In main with args -|get_rpm bash-3.0-19.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found bash-3.0-19.7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: bash-3.0-19.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm audit-1.0.16-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found audit-1.0.16-3.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: audit-1.0.16-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm iproute-2.6.9-4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found iproute-2.6.9-4.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: iproute-2.6.9-4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm ncurses-5.4-15.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found ncurses-5.4-15.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: ncurses-5.4-15.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm less-382-4.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found less-382-4.rhel4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: less-382-4.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm net-tools-1.60-39.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found net-tools-1.60-39.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: net-tools-1.60-39.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm OpenIPMI-libs-1.4.14-1.4E.20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found OpenIPMI-libs-1.4.14-1.4E.20.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: OpenIPMI-libs-1.4.14-1.4E.20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm pcre-4.5-4.el4_6.6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found pcre-4.5-4.el4_6.6.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: pcre-4.5-4.el4_6.6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm perl-5.8.5-36.el4_6.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found perl-5.8.5-36.el4_6.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: perl-5.8.5-36.el4_6.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|In main with args -|get_rpm perl-Filter-1.30-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:23 ServerApiManager|Found perl-Filter-1.30-6.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:23 ServerApiManager||Method: get_rpm args: perl-Filter-1.30-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm popt-1.9.1-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found popt-1.9.1-26_nonptl.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: popt-1.9.1-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm psmisc-21.4-4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found psmisc-21.4-4.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: psmisc-21.4-4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm redhat-release-4AS-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found redhat-release-4AS-8.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: redhat-release-4AS-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm setserial-2.17-17.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found setserial-2.17-17.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: setserial-2.17-17.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm slang-1.4.9-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found slang-1.4.9-8.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: slang-1.4.9-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm newt-0.51.6-10.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found newt-0.51.6-10.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: newt-0.51.6-10.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm sysfsutils-1.2.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found sysfsutils-1.2.0-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: sysfsutils-1.2.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm iputils-20020927-21.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found iputils-20020927-21.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: iputils-20020927-21.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm usbutils-0.11-7.RHEL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found usbutils-0.11-7.RHEL4.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: usbutils-0.11-7.RHEL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm vim-minimal-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found vim-minimal-6.3.046-1.el4_7.5z.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: vim-minimal-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|In main with args -|get_rpm words-3.0-3.2.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:24 ServerApiManager|Found words-3.0-3.2.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:24 ServerApiManager||Method: get_rpm args: words-3.0-3.2.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm zlib-1.2.1.2-1.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found zlib-1.2.1.2-1.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: zlib-1.2.1.2-1.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm file-4.10-5.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found file-4.10-5.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: file-4.10-5.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm info-4.7-5.el4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found info-4.7-5.el4.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: info-4.7-5.el4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm cpio-2.5-16.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found cpio-2.5-16.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: cpio-2.5-16.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm diffutils-2.8.1-12.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found diffutils-2.8.1-12.1.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: diffutils-2.8.1-12.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm findutils-4.1.20-7.el4.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found findutils-4.1.20-7.el4.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: findutils-4.1.20-7.el4.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm gawk-3.1.3-10.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found gawk-3.1.3-10.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: gawk-3.1.3-10.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm grep-2.5.1-32.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found grep-2.5.1-32.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: grep-2.5.1-32.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm coreutils-5.2.1-31.8.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|Found coreutils-5.2.1-31.8.el4_7.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager||Method: get_rpm args: coreutils-5.2.1-31.8.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:25 ServerApiManager|In main with args -|get_rpm ash-0.3.8-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found ash-0.3.8-20.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: ash-0.3.8-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm grub-0.95-3.8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found grub-0.95-3.8.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: grub-0.95-3.8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm gzip-1.3.3-17.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found gzip-1.3.3-17.rhel4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: gzip-1.3.3-17.rhel4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm krb5-libs-1.3.4-62.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found krb5-libs-1.3.4-62.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: krb5-libs-1.3.4-62.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm libidn-0.5.6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found libidn-0.5.6-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: libidn-0.5.6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm module-init-tools-3.1-0.pre5.3.10.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found module-init-tools-3.1-0.pre5.3.10.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: module-init-tools-3.1-0.pre5.3.10.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm openssl-0.9.7a-43.17.el4_8.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found openssl-0.9.7a-43.17.el4_8.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: openssl-0.9.7a-43.17.el4_8.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm OpenIPMI-1.4.14-1.4E.20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found OpenIPMI-1.4.14-1.4E.20.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: OpenIPMI-1.4.14-1.4E.20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm procps-3.2.3-8.12.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found procps-3.2.3-8.12.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: procps-3.2.3-8.12.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm readline-4.3-13.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found readline-4.3-13.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: readline-4.3-13.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm lvm2-2.02.37-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found lvm2-2.02.37-3.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: lvm2-2.02.37-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|In main with args -|get_rpm python-2.3.4-14.7.el4_8.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:26 ServerApiManager|Found python-2.3.4-14.7.el4_8.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:26 ServerApiManager||Method: get_rpm args: python-2.3.4-14.7.el4_8.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm PyXML-0.8.3-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found PyXML-0.8.3-6.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: PyXML-0.8.3-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm rpm-libs-4.3.3-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found rpm-libs-4.3.3-26_nonptl.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: rpm-libs-4.3.3-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm sed-4.1.2-7.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found sed-4.1.2-7.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: sed-4.1.2-7.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm shadow-utils-4.0.3-66.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found shadow-utils-4.0.3-66.RHEL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: shadow-utils-4.0.3-66.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm dbus-0.22-12.EL.9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found dbus-0.22-12.EL.9.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: dbus-0.22-12.EL.9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm dbus-glib-0.22-12.EL.9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found dbus-glib-0.22-12.EL.9.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: dbus-glib-0.22-12.EL.9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm MAKEDEV-3.15.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found MAKEDEV-3.15.2-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: MAKEDEV-3.15.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm rpm-4.3.3-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found rpm-4.3.3-26_nonptl.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: rpm-4.3.3-26_nonptl.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm sysklogd-1.4.1-27.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found sysklogd-1.4.1-27.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: sysklogd-1.4.1-27.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm tar-1.14-12.5.1.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|Found tar-1.14-12.5.1.RHEL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager||Method: get_rpm args: tar-1.14-12.5.1.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:27 ServerApiManager|In main with args -|get_rpm cracklib-2.8.9-1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found cracklib-2.8.9-1.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: cracklib-2.8.9-1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm cracklib-dicts-2.8.9-1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found cracklib-dicts-2.8.9-1.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: cracklib-dicts-2.8.9-1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm pam-0.77-66.25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found pam-0.77-66.25.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: pam-0.77-66.25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm authconfig-4.6.10-7.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found authconfig-4.6.10-7.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: authconfig-4.6.10-7.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm kudzu-1.1.95.23-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found kudzu-1.1.95.23-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: kudzu-1.1.95.23-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm SysVinit-2.85-34.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found SysVinit-2.85-34.4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: SysVinit-2.85-34.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm util-linux-2.12a-24.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found util-linux-2.12a-24.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: util-linux-2.12a-24.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm hotplug-2004_04_01-7.8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found hotplug-2004_04_01-7.8.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: hotplug-2004_04_01-7.8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm udev-039-10.22.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found udev-039-10.22.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: udev-039-10.22.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|In main with args -|get_rpm initscripts-7.93.33-1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:28 ServerApiManager|Found initscripts-7.93.33-1.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:28 ServerApiManager||Method: get_rpm args: initscripts-7.93.33-1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm acpid-1.0.3-2.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found acpid-1.0.3-2.el4_7.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: acpid-1.0.3-2.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm cyrus-sasl-2.1.19-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found cyrus-sasl-2.1.19-14.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: cyrus-sasl-2.1.19-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm cyrus-sasl-md5-2.1.19-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found cyrus-sasl-md5-2.1.19-14.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: cyrus-sasl-md5-2.1.19-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm kbd-1.12-2.el4.5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found kbd-1.12-2.el4.5.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: kbd-1.12-2.el4.5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm kernel-utils-2.4-18.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found kernel-utils-2.4-18.1.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: kernel-utils-2.4-18.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm lm_sensors-2.8.7-2.40.5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found lm_sensors-2.8.7-2.40.5.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: lm_sensors-2.8.7-2.40.5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm mkinitrd-4.2.1.13-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found mkinitrd-4.2.1.13-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: mkinitrd-4.2.1.13-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm kernel-2.6.9-78.EL.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found kernel-2.6.9-78.EL.i686.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: kernel-2.6.9-78.EL.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm kernel-smp-2.6.9-78.EL.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found kernel-smp-2.6.9-78.EL.i686.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: kernel-smp-2.6.9-78.EL.i686.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm ipv6-kernel-update-2.6.9-78.v2.ELsmp.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found ipv6-kernel-update-2.6.9-78.v2.ELsmp.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: ipv6-kernel-update-2.6.9-78.v2.ELsmp.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|In main with args -|get_rpm openldap-2.2.13-12.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:29 ServerApiManager|Found openldap-2.2.13-12.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:29 ServerApiManager||Method: get_rpm args: openldap-2.2.13-12.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|get_rpm libuser-0.52.5-1.el4.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|Found libuser-0.52.5-1.el4.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: get_rpm args: libuser-0.52.5-1.el4.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|get_rpm passwd-0.68-10.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|Found passwd-0.68-10.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: get_rpm args: passwd-0.68-10.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|get_rpm which-2.16-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|Found which-2.16-4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: get_rpm args: which-2.16-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|get_rpm preferences-1.0.1-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|Found preferences-1.0.1-8.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: get_rpm args: preferences-1.0.1-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|get_rpm compat-db-4.1.25-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|Found compat-db-4.1.25-9.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: get_rpm args: compat-db-4.1.25-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|get_rpm compat-libstdc++-296-2.96-132.7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|Found compat-libstdc++-296-2.96-132.7.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: get_rpm args: compat-libstdc++-296-2.96-132.7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|In main with args -|get_rpm compat-libstdc++-33-3.2.3-47.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:30 ServerApiManager|Found compat-libstdc++-33-3.2.3-47.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:30 ServerApiManager||Method: get_rpm args: compat-libstdc++-33-3.2.3-47.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm dos2unix-3.1-21.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found dos2unix-3.1-21.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: dos2unix-3.1-21.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm dosfstools-2.8-18.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found dosfstools-2.8-18.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: dosfstools-2.8-18.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm eject-2.0.13-11.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found eject-2.0.13-11.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: eject-2.0.13-11.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm elfutils-0.97.1-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found elfutils-0.97.1-5.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: elfutils-0.97.1-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm attr-2.4.16-3.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found attr-2.4.16-3.1.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: attr-2.4.16-3.1.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm acl-2.2.23-5.4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found acl-2.2.23-5.4.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: acl-2.2.23-5.4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm libtool-libs-1.5.6-4.EL4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found libtool-libs-1.5.6-4.EL4.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: libtool-libs-1.5.6-4.EL4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm lsof-4.72-1.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found lsof-4.72-1.4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: lsof-4.72-1.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm bzip2-1.0.2-14.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found bzip2-1.0.2-14.el4_7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: bzip2-1.0.2-14.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm crontabs-1.10-7.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|Found crontabs-1.10-7.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager||Method: get_rpm args: crontabs-1.10-7.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:31 ServerApiManager|In main with args -|get_rpm fior-0.99.1-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found fior-0.99.1-2.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: fior-0.99.1-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm java-provides-1.0.0.2-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found java-provides-1.0.0.2-0.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: java-provides-1.0.0.2-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm mt-st-0.8-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found mt-st-0.8-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: mt-st-0.8-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm nc-1.10-22.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found nc-1.10-22.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: nc-1.10-22.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm openssl096b-0.9.6b-22.46.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found openssl096b-0.9.6b-22.46.el4_7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: openssl096b-0.9.6b-22.46.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm os-ver-4.0.0.0-33.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found os-ver-4.0.0.0-33.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: os-ver-4.0.0.0-33.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm patch-2.5.4-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found patch-2.5.4-20.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: patch-2.5.4-20.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm ndisc6-0.9.3-1.el4.rf.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found ndisc6-0.9.3-1.el4.rf.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: ndisc6-0.9.3-1.el4.rf.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm logrotate-3.7.1-10.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found logrotate-3.7.1-10.RHEL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: logrotate-3.7.1-10.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm rsync-2.6.3-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|Found rsync-2.6.3-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager||Method: get_rpm args: rsync-2.6.3-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:32 ServerApiManager|In main with args -|get_rpm schedutils-1.4.0-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found schedutils-1.4.0-2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: schedutils-1.4.0-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm setarch-1.6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found setarch-1.6-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: setarch-1.6-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm sg3_utils-1.22-3.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found sg3_utils-1.22-3.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: sg3_utils-1.22-3.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm snmp-mon-0.0.0.19-17.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found snmp-mon-0.0.0.19-17.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: snmp-mon-0.0.0.19-17.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm star-1.5a25-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found star-1.5a25-8.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: star-1.5a25-8.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm strace-4.5.16-1.el4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found strace-4.5.16-1.el4.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: strace-4.5.16-1.el4.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm tcl-8.4.7-4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found tcl-8.4.7-4.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: tcl-8.4.7-4.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm expect-5.42.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found expect-5.42.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: expect-5.42.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm tcp_wrappers-7.6-37.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found tcp_wrappers-7.6-37.4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: tcp_wrappers-7.6-37.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|In main with args -|get_rpm tmpwatch-2.9.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:33 ServerApiManager|Found tmpwatch-2.9.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:33 ServerApiManager||Method: get_rpm args: tmpwatch-2.9.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm traceroute-1.4a12-24.EL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found traceroute-1.4a12-24.EL4.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: traceroute-1.4a12-24.EL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm unzip-5.51-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found unzip-5.51-10.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: unzip-5.51-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm zip-2.3-29.EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found zip-2.3-29.EL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: zip-2.3-29.EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm binutils-2.15.92.0.2-25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found binutils-2.15.92.0.2-25.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: binutils-2.15.92.0.2-25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm gdb-6.3.0.0-1.159.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found gdb-6.3.0.0-1.159.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: gdb-6.3.0.0-1.159.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm gpm-1.20.1-71.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found gpm-1.20.1-71.RHEL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: gpm-1.20.1-71.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm libxml2-2.6.16-12.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found libxml2-2.6.16-12.7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: libxml2-2.6.16-12.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm libxslt-1.1.11-1.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found libxslt-1.1.11-1.el4_7.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: libxslt-1.1.11-1.el4_7.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|In main with args -|get_rpm make-3.80-7.EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:34 ServerApiManager|Found make-3.80-7.EL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:34 ServerApiManager||Method: get_rpm args: make-3.80-7.EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm mgetty-1.1.31-14.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found mgetty-1.1.31-14.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: mgetty-1.1.31-14.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm bind-libs-9.2.4-30.el4_8.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found bind-libs-9.2.4-30.el4_8.4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: bind-libs-9.2.4-30.el4_8.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm bind-utils-9.2.4-30.el4_8.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found bind-utils-9.2.4-30.el4_8.4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: bind-utils-9.2.4-30.el4_8.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm curl-7.12.1-11.1.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found curl-7.12.1-11.1.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: curl-7.12.1-11.1.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm pdksh-5.2.14-30.6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found pdksh-5.2.14-30.6.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: pdksh-5.2.14-30.6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm bc-1.06-17.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found bc-1.06-17.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: bc-1.06-17.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm libxml2-python-2.6.16-12.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found libxml2-python-2.6.16-12.7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: libxml2-python-2.6.16-12.7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm jdk-1.6.0_17-fcs.i586.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found jdk-1.6.0_17-fcs.i586.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: jdk-1.6.0_17-fcs.i586.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm nscd-2.3.4-2.41.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found nscd-2.3.4-2.41.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: nscd-2.3.4-2.41.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|In main with args -|get_rpm ntp-4.2.0.a.20040617-8.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:35 ServerApiManager|Found ntp-4.2.0.a.20040617-8.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:35 ServerApiManager||Method: get_rpm args: ntp-4.2.0.a.20040617-8.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm stunnel-4.05-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found stunnel-4.05-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: stunnel-4.05-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm sysreport-1.3.15-8.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found sysreport-1.3.15-8.noarch.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: sysreport-1.3.15-8.noarch.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm tcsh-6.13-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found tcsh-6.13-10.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: tcsh-6.13-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm tftp-0.39-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found tftp-0.39-3.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: tftp-0.39-3.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm time-1.7-25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found time-1.7-25.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: time-1.7-25.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm tomcat-6.0.20-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found tomcat-6.0.20-0.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: tomcat-6.0.20-0.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm activation-1.0.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found activation-1.0.0-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: activation-1.0.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm cactus-12.1.5-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found cactus-12.1.5-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: cactus-12.1.5-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm ecs-1.4.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found ecs-1.4.2-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: ecs-1.4.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|In main with args -|get_rpm elixir-4.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:36 ServerApiManager|Found elixir-4.2-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:36 ServerApiManager||Method: get_rpm args: elixir-4.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm jaxm-1.1.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found jaxm-1.1.2-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: jaxm-1.1.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm log4j-1.2.8-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found log4j-1.2.8-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: log4j-1.2.8-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm mail-1.0.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found mail-1.0.0-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: mail-1.0.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm pgjdbc-7.3.3-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found pgjdbc-7.3.3-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: pgjdbc-7.3.3-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm regexp-1.3-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found regexp-1.3-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: regexp-1.3-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm saaj-1.3-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found saaj-1.3-4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: saaj-1.3-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm struts-1.1-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found struts-1.1-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: struts-1.1-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm unixODBC-2.2.11-1.RHEL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found unixODBC-2.2.11-1.RHEL4.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: unixODBC-2.2.11-1.RHEL4.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm utempter-0.5.5-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found utempter-0.5.5-5.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: utempter-0.5.5-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm vim-common-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found vim-common-6.3.046-1.el4_7.5z.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: vim-common-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|In main with args -|get_rpm vim-enhanced-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:37 ServerApiManager|Found vim-enhanced-6.3.046-1.el4_7.5z.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:37 ServerApiManager||Method: get_rpm args: vim-enhanced-6.3.046-1.el4_7.5z.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm xalan-2.7.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found xalan-2.7.0-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: xalan-2.7.0-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm xerces-2.6.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found xerces-2.6.2-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: xerces-2.6.2-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm xmlstarlet-1.0.1-1.i586.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found xmlstarlet-1.0.1-1.i586.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: xmlstarlet-1.0.1-1.i586.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm at-3.1.8-82.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found at-3.1.8-82.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: at-3.1.8-82.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm pam_krb5-2.1.17-6.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found pam_krb5-2.1.17-6.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: pam_krb5-2.1.17-6.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm policycoreutils-1.18.1-4.13.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found policycoreutils-1.18.1-4.13.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: policycoreutils-1.18.1-4.13.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm screen-4.0.2-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found screen-4.0.2-5.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: screen-4.0.2-5.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm sudo-1.6.7p5-30.1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found sudo-1.6.7p5-30.1.3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: sudo-1.6.7p5-30.1.3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm krb5-workstation-1.3.4-62.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found krb5-workstation-1.3.4-62.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: krb5-workstation-1.3.4-62.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|In main with args -|get_rpm dhclient-3.0.1-65.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:38 ServerApiManager|Found dhclient-3.0.1-65.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:38 ServerApiManager||Method: get_rpm args: dhclient-3.0.1-65.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm dhcpv6_client-0.10-24_EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found dhcpv6_client-0.10-24_EL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: dhcpv6_client-0.10-24_EL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm ipsec-tools-0.3.3-7.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found ipsec-tools-0.3.3-7.el4_7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: ipsec-tools-0.3.3-7.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm dhcp-3.0.1-65.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found dhcp-3.0.1-65.el4_8.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: dhcp-3.0.1-65.el4_8.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm iptables-1.2.11-3.2.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found iptables-1.2.11-3.2.RHEL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: iptables-1.2.11-3.2.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm iptables-ipv6-1.2.11-3.2.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found iptables-ipv6-1.2.11-3.2.RHEL4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: iptables-ipv6-1.2.11-3.2.RHEL4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm libpcap-0.8.3-12.el4_6.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found libpcap-0.8.3-12.el4_6.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: libpcap-0.8.3-12.el4_6.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm gnupg-1.2.6-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found gnupg-1.2.6-9.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: gnupg-1.2.6-9.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm nss_ldap-253-5.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found nss_ldap-253-5.el4_7.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: nss_ldap-253-5.el4_7.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm openssh-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found openssh-3.9p1-11.el4_7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: openssh-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm openssh-clients-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|Found openssh-clients-3.9p1-11.el4_7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager||Method: get_rpm args: openssh-clients-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:39 ServerApiManager|In main with args -|get_rpm netdump-0.7.16-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found netdump-0.7.16-14.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: netdump-0.7.16-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|get_rpm openssh-server-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found openssh-server-3.9p1-11.el4_7.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: openssh-server-3.9p1-11.el4_7.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|get_rpm netdump-server-0.7.16-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found netdump-server-0.7.16-14.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: netdump-server-0.7.16-14.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|get_rpm pciutils-2.1.99.test8-3.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found pciutils-2.1.99.test8-3.4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: pciutils-2.1.99.test8-3.4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|get_rpm radvd-0.7.2-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found radvd-0.7.2-10.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: radvd-0.7.2-10.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|get_rpm tcpdump-3.8.2-12.el4_6.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found tcpdump-3.8.2-12.el4_6.1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: tcpdump-3.8.2-12.el4_6.1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|get_rpm vixie-cron-4.1-50.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found vixie-cron-4.1-50.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: vixie-cron-4.1-50.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|In main with args -|get_rpm sysstat-5.0.5-19.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:23:40 ServerApiManager|Found sysstat-5.0.5-19.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:23:40 ServerApiManager||Method: get_rpm args: sysstat-5.0.5-19.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:23:40 upgrade_os.sh|Install the OS RPMS|<:INFO>
11/09/2012 01:23:41 install_rpm.sh|[1/217]: comps-4AS-0.20080711.i386.rpm|<:DEBUG>
11/09/2012 01:23:43 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/comps-4AS-0.20080711.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:43 install_rpm.sh|[2/217]: hwdata-0.146.33.EL-11.noarch.rpm|<:DEBUG>
11/09/2012 01:23:43 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/hwdata-0.146.33.EL-11.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:43 install_rpm.sh|[3/217]: libgcc-3.4.6-10.i386.rpm|<:DEBUG>
11/09/2012 01:23:43 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libgcc-3.4.6-10.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:43 install_rpm.sh|[4/217]: redhat-logos-1.1.26-1.noarch.rpm|<:DEBUG>
11/09/2012 01:23:44 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/redhat-logos-1.1.26-1.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:44 install_rpm.sh|[5/217]: rootfiles-8-1.noarch.rpm|<:DEBUG>
11/09/2012 01:23:44 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/rootfiles-8-1.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:44 install_rpm.sh|[6/217]: setup-2.5.37-1.7.noarch.rpm|<:DEBUG>
11/09/2012 01:23:44 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/setup-2.5.37-1.7.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:44 install_rpm.sh|[7/217]: filesystem-2.3.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:23:45 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/filesystem-2.3.0-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:45 install_rpm.sh|[8/217]: basesystem-8.0-4.noarch.rpm|<:DEBUG>
11/09/2012 01:23:45 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/basesystem-8.0-4.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:45 install_rpm.sh|[9/217]: termcap-5.4-3.noarch.rpm|<:DEBUG>
11/09/2012 01:23:45 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/termcap-5.4-3.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:45 install_rpm.sh|[10/217]: tzdata-2009o-2.el4.noarch.rpm|<:DEBUG>
11/09/2012 01:23:46 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tzdata-2009o-2.el4.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:46 install_rpm.sh|[11/217]: glibc-common-2.3.4-2.41.i386.rpm|<:DEBUG>
11/09/2012 01:23:54 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/glibc-common-2.3.4-2.41.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:54 install_rpm.sh|[12/217]: glibc-2.3.4-2.41.i686.rpm|<:DEBUG>
11/09/2012 01:23:55 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/glibc-2.3.4-2.41.i686.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:55 install_rpm.sh|[13/217]: audit-libs-1.0.16-3.el4.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|Installing audit-libs-1.0.16-3.el4.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/glibc-2.3.4-2.41.i686.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/audit-libs-1.0.16-3.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|[14/217]: beecrypt-3.1.0-6.i386.rpm|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/beecrypt-3.1.0-6.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|[15/217]: bzip2-libs-1.0.2-14.el4_7.i386.rpm|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/bzip2-libs-1.0.2-14.el4_7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|[16/217]: chkconfig-1.3.13.5.EL4-1.i386.rpm|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/chkconfig-1.3.13.5.EL4-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:56 install_rpm.sh|[17/217]: e2fsprogs-1.35-12.17.el4.i386.rpm|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/e2fsprogs-1.35-12.17.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|[18/217]: elfutils-libelf-0.97.1-5.i386.rpm|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/elfutils-libelf-0.97.1-5.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|[19/217]: ethtool-6-1.i386.rpm|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/ethtool-6-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|[20/217]: expat-1.95.7-4.el4_8.2.i386.rpm|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/expat-1.95.7-4.el4_8.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|[21/217]: gdbm-1.8.0-24.i386.rpm|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/gdbm-1.8.0-24.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:57 install_rpm.sh|[22/217]: glib-1.2.10-15.i386.rpm|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/glib-1.2.10-15.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|[23/217]: glib2-2.4.7-1.i386.rpm|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/glib2-2.4.7-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|[24/217]: hdparm-5.7-2.i386.rpm|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/hdparm-5.7-2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|[25/217]: libattr-2.4.16-3.1.el4.i386.rpm|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libattr-2.4.16-3.1.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|[26/217]: libacl-2.2.23-5.4.el4.i386.rpm|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libacl-2.2.23-5.4.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:58 install_rpm.sh|[27/217]: libcap-1.10-20.i386.rpm|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libcap-1.10-20.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|[28/217]: libgpg-error-1.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libgpg-error-1.0-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|[29/217]: libgcrypt-1.2.0-3.i386.rpm|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libgcrypt-1.2.0-3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|[30/217]: libselinux-1.19.1-7.4.i386.rpm|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libselinux-1.19.1-7.4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|[31/217]: device-mapper-1.02.25-2.el4.i386.rpm|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/device-mapper-1.02.25-2.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|[32/217]: libsepol-1.1.1-2.i386.rpm|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libsepol-1.1.1-2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:23:59 install_rpm.sh|[33/217]: libstdc++-3.4.6-9.i386.rpm|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libstdc++-3.4.6-9.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|[34/217]: db4-4.2.52-7.3.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/db4-4.2.52-7.3.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|[35/217]: gmp-4.1.4-3.i386.rpm|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/gmp-4.1.4-3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|[36/217]: libtermcap-2.0.8-39.i386.rpm|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libtermcap-2.0.8-39.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:00 install_rpm.sh|[37/217]: lsscsi-0.22-1.i386.rpm|<:DEBUG>
11/09/2012 01:24:01 install_rpm.sh|[38/217]: mingetty-1.07-3.i386.rpm|<:DEBUG>
11/09/2012 01:24:01 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/mingetty-1.07-3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:01 install_rpm.sh|[39/217]: mktemp-1.5-20.i386.rpm|<:DEBUG>
11/09/2012 01:24:01 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/mktemp-1.5-20.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:01 install_rpm.sh|[40/217]: bash-3.0-19.7.i386.rpm|<:DEBUG>
11/09/2012 01:24:02 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/bash-3.0-19.7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:02 install_rpm.sh|[41/217]: audit-1.0.16-3.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:02 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/audit-1.0.16-3.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:02 install_rpm.sh|[42/217]: iproute-2.6.9-4.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:02 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/iproute-2.6.9-4.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:02 install_rpm.sh|[43/217]: ncurses-5.4-15.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:03 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/ncurses-5.4-15.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:03 install_rpm.sh|[44/217]: less-382-4.rhel4.i386.rpm|<:DEBUG>
11/09/2012 01:24:03 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/less-382-4.rhel4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:03 install_rpm.sh|[45/217]: net-tools-1.60-39.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:03 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/net-tools-1.60-39.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:03 install_rpm.sh|[46/217]: OpenIPMI-libs-1.4.14-1.4E.20.i386.rpm|<:DEBUG>
11/09/2012 01:24:04 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/OpenIPMI-libs-1.4.14-1.4E.20.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:04 install_rpm.sh|[47/217]: pcre-4.5-4.el4_6.6.i386.rpm|<:DEBUG>
11/09/2012 01:24:04 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/pcre-4.5-4.el4_6.6.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:04 install_rpm.sh|[48/217]: perl-5.8.5-36.el4_6.3.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:04 install_rpm.sh|Installing perl-5.8.5-36.el4_6.3.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/pcre-4.5-4.el4_6.6.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/perl-5.8.5-36.el4_6.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|[49/217]: perl-Filter-1.30-6.i386.rpm|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/perl-Filter-1.30-6.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|[50/217]: popt-1.9.1-26_nonptl.i386.rpm|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/popt-1.9.1-26_nonptl.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|[51/217]: psmisc-21.4-4.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/psmisc-21.4-4.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:07 install_rpm.sh|[52/217]: redhat-release-4AS-8.i386.rpm|<:DEBUG>
11/09/2012 01:24:08 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/redhat-release-4AS-8.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:08 install_rpm.sh|[53/217]: setserial-2.17-17.i386.rpm|<:DEBUG>
11/09/2012 01:24:08 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/setserial-2.17-17.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:08 install_rpm.sh|[54/217]: slang-1.4.9-8.i386.rpm|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/slang-1.4.9-8.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|[55/217]: newt-0.51.6-10.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/newt-0.51.6-10.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|[56/217]: sysfsutils-1.2.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/sysfsutils-1.2.0-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|[57/217]: iputils-20020927-21.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/iputils-20020927-21.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:09 install_rpm.sh|[58/217]: usbutils-0.11-7.RHEL4.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/usbutils-0.11-7.RHEL4.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|[59/217]: vim-minimal-6.3.046-1.el4_7.5z.i386.rpm|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/vim-minimal-6.3.046-1.el4_7.5z.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|[60/217]: words-3.0-3.2.noarch.rpm|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/words-3.0-3.2.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|[61/217]: zlib-1.2.1.2-1.2.i386.rpm|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/zlib-1.2.1.2-1.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:10 install_rpm.sh|[62/217]: file-4.10-5.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/file-4.10-5.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|[63/217]: info-4.7-5.el4.2.i386.rpm|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/info-4.7-5.el4.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|[64/217]: cpio-2.5-16.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/cpio-2.5-16.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|[65/217]: diffutils-2.8.1-12.1.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/diffutils-2.8.1-12.1.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:11 install_rpm.sh|[66/217]: findutils-4.1.20-7.el4.3.i386.rpm|<:DEBUG>
11/09/2012 01:24:12 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/findutils-4.1.20-7.el4.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:12 install_rpm.sh|[67/217]: gawk-3.1.3-10.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:12 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/gawk-3.1.3-10.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:12 install_rpm.sh|[68/217]: grep-2.5.1-32.3.i386.rpm|<:DEBUG>
11/09/2012 01:24:13 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/grep-2.5.1-32.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:13 install_rpm.sh|[69/217]: coreutils-5.2.1-31.8.el4_7.1.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:13 install_rpm.sh|Installing coreutils-5.2.1-31.8.el4_7.1.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:14 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/grep-2.5.1-32.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:14 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/coreutils-5.2.1-31.8.el4_7.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:14 install_rpm.sh|[70/217]: ash-0.3.8-20.i386.rpm|<:DEBUG>
11/09/2012 01:24:14 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/ash-0.3.8-20.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:14 install_rpm.sh|[71/217]: grub-0.95-3.8.i386.rpm|<:DEBUG>
11/09/2012 01:24:15 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/grub-0.95-3.8.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:15 install_rpm.sh|[72/217]: gzip-1.3.3-17.rhel4.i386.rpm|<:DEBUG>
11/09/2012 01:24:15 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/gzip-1.3.3-17.rhel4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:15 install_rpm.sh|[73/217]: krb5-libs-1.3.4-62.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:16 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/krb5-libs-1.3.4-62.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:16 install_rpm.sh|[74/217]: libidn-0.5.6-1.i386.rpm|<:DEBUG>
11/09/2012 01:24:16 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libidn-0.5.6-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:16 install_rpm.sh|[75/217]: module-init-tools-3.1-0.pre5.3.10.i386.rpm|<:DEBUG>
11/09/2012 01:24:16 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/module-init-tools-3.1-0.pre5.3.10.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:16 install_rpm.sh|[76/217]: openssl-0.9.7a-43.17.el4_8.3.i386.rpm|<:DEBUG>
11/09/2012 01:24:17 install_rpm.sh|[77/217]: OpenIPMI-1.4.14-1.4E.20.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:17 install_rpm.sh|Installing OpenIPMI-1.4.14-1.4E.20.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:18 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/OpenIPMI-1.4.14-1.4E.20.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:18 install_rpm.sh|[78/217]: procps-3.2.3-8.12.i386.rpm|<:DEBUG>
11/09/2012 01:24:18 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/procps-3.2.3-8.12.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:18 install_rpm.sh|[79/217]: readline-4.3-13.i386.rpm|<:DEBUG>
11/09/2012 01:24:18 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/readline-4.3-13.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:18 install_rpm.sh|[80/217]: lvm2-2.02.37-3.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:26 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/lvm2-2.02.37-3.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:26 install_rpm.sh|[81/217]: python-2.3.4-14.7.el4_8.2.i386.rpm|<:DEBUG>
11/09/2012 01:24:28 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/python-2.3.4-14.7.el4_8.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:28 install_rpm.sh|[82/217]: PyXML-0.8.3-6.i386.rpm|<:DEBUG>
11/09/2012 01:24:29 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/PyXML-0.8.3-6.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:29 install_rpm.sh|[83/217]: rpm-libs-4.3.3-26_nonptl.i386.rpm|<:DEBUG>
11/09/2012 01:24:29 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/rpm-libs-4.3.3-26_nonptl.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:29 install_rpm.sh|[84/217]: sed-4.1.2-7.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:29 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/sed-4.1.2-7.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:29 install_rpm.sh|[85/217]: shadow-utils-4.0.3-66.RHEL4.i386.rpm|<:DEBUG>
11/09/2012 01:24:29 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/shadow-utils-4.0.3-66.RHEL4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:30 install_rpm.sh|[86/217]: dbus-0.22-12.EL.9.i386.rpm|<:DEBUG>
11/09/2012 01:24:30 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/dbus-0.22-12.EL.9.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:30 install_rpm.sh|[87/217]: dbus-glib-0.22-12.EL.9.i386.rpm|<:DEBUG>
11/09/2012 01:24:30 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/dbus-glib-0.22-12.EL.9.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:30 install_rpm.sh|[88/217]: MAKEDEV-3.15.2-3.i386.rpm|<:DEBUG>
11/09/2012 01:24:30 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/MAKEDEV-3.15.2-3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:30 install_rpm.sh|[89/217]: rpm-4.3.3-26_nonptl.i386.rpm|<:DEBUG>
11/09/2012 01:24:31 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/rpm-4.3.3-26_nonptl.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:31 install_rpm.sh|[90/217]: sysklogd-1.4.1-27.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:31 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/sysklogd-1.4.1-27.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:31 install_rpm.sh|[91/217]: tar-1.14-12.5.1.RHEL4.i386.rpm|<:DEBUG>
11/09/2012 01:24:32 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tar-1.14-12.5.1.RHEL4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:32 install_rpm.sh|[92/217]: cracklib-2.8.9-1.3.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:32 install_rpm.sh|Installing cracklib-2.8.9-1.3.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:32 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/cracklib-2.8.9-1.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:32 install_rpm.sh|[93/217]: cracklib-dicts-2.8.9-1.3.i386.rpm|<:DEBUG>
11/09/2012 01:24:33 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/cracklib-dicts-2.8.9-1.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:33 install_rpm.sh|[94/217]: pam-0.77-66.25.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:33 install_rpm.sh|Installing pam-0.77-66.25.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/cracklib-dicts-2.8.9-1.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/pam-0.77-66.25.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|[95/217]: authconfig-4.6.10-7.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/authconfig-4.6.10-7.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|[96/217]: kudzu-1.1.95.23-1.i386.rpm|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|kudzu rpm failed to install: trying nodeps(rc=1)|<:INFO>
11/09/2012 01:24:34 install_rpm.sh|Installing kudzu-1.1.95.23-1.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/kudzu-1.1.95.23-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|(CAPTURE) error: Failed dependencies:|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|(CAPTURE)  hal >= 0.2.96 is needed by kudzu-1.1.95.23-1.i386|<:DEBUG>
11/09/2012 01:24:34 install_rpm.sh|[97/217]: SysVinit-2.85-34.4.i386.rpm|<:DEBUG>
11/09/2012 01:24:35 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/SysVinit-2.85-34.4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:35 install_rpm.sh|[98/217]: util-linux-2.12a-24.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:36 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/util-linux-2.12a-24.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:36 install_rpm.sh|[99/217]: hotplug-2004_04_01-7.8.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:36 install_rpm.sh|Installing hotplug-2004_04_01-7.8.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:37 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/util-linux-2.12a-24.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:37 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/hotplug-2004_04_01-7.8.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:37 install_rpm.sh|[100/217]: udev-039-10.22.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:37 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/udev-039-10.22.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:37 install_rpm.sh|[101/217]: initscripts-7.93.33-1.el4.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:37 install_rpm.sh|Installing initscripts-7.93.33-1.el4.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:38 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/udev-039-10.22.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:38 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/initscripts-7.93.33-1.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:38 install_rpm.sh|[102/217]: acpid-1.0.3-2.el4_7.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:38 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/acpid-1.0.3-2.el4_7.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:38 install_rpm.sh|[103/217]: cyrus-sasl-2.1.19-14.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:38 install_rpm.sh|Installing cyrus-sasl-2.1.19-14.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:39 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/acpid-1.0.3-2.el4_7.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:39 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/cyrus-sasl-2.1.19-14.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:39 install_rpm.sh|[104/217]: cyrus-sasl-md5-2.1.19-14.i386.rpm|<:DEBUG>
11/09/2012 01:24:39 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/cyrus-sasl-md5-2.1.19-14.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:39 install_rpm.sh|[105/217]: kbd-1.12-2.el4.5.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:24:39 install_rpm.sh|Installing kbd-1.12-2.el4.5.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:40 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/cyrus-sasl-md5-2.1.19-14.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:40 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/kbd-1.12-2.el4.5.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:40 install_rpm.sh|[106/217]: kernel-utils-2.4-18.1.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:40 install_rpm.sh|[107/217]: lm_sensors-2.8.7-2.40.5.i386.rpm|<:DEBUG>
11/09/2012 01:24:41 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/lm_sensors-2.8.7-2.40.5.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:41 install_rpm.sh|[108/217]: mkinitrd-4.2.1.13-1.i386.rpm|<:DEBUG>
11/09/2012 01:24:41 install_rpm.sh|mkinitrd rpm failed to install: trying nodeps(rc=1)|<:INFO>
11/09/2012 01:24:41 install_rpm.sh|Installing mkinitrd-4.2.1.13-1.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:24:41 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/mkinitrd-4.2.1.13-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:41 install_rpm.sh|(CAPTURE) error: Failed dependencies:|<:DEBUG>
11/09/2012 01:24:41 install_rpm.sh|(CAPTURE)  /usr/bin/which is needed by mkinitrd-4.2.1.13-1.i386|<:DEBUG>
11/09/2012 01:24:41 install_rpm.sh|[109/217]: kernel-2.6.9-78.EL.i686.rpm|<:DEBUG>
11/09/2012 01:24:45 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/kernel-2.6.9-78.EL.i686.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:45 install_rpm.sh|[110/217]: kernel-smp-2.6.9-78.EL.i686.rpm|<:DEBUG>
11/09/2012 01:24:49 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/kernel-smp-2.6.9-78.EL.i686.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:49 install_rpm.sh|[111/217]: ipv6-kernel-update-2.6.9-78.v2.ELsmp.i386.rpm|<:DEBUG>
11/09/2012 01:24:49 install_rpm.sh|[112/217]: openldap-2.2.13-12.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:50 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/openldap-2.2.13-12.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:50 install_rpm.sh|[113/217]: libuser-0.52.5-1.el4.3.i386.rpm|<:DEBUG>
11/09/2012 01:24:50 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libuser-0.52.5-1.el4.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:50 install_rpm.sh|[114/217]: passwd-0.68-10.1.i386.rpm|<:DEBUG>
11/09/2012 01:24:50 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/passwd-0.68-10.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:50 install_rpm.sh|[115/217]: which-2.16-4.i386.rpm|<:DEBUG>
11/09/2012 01:24:51 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/which-2.16-4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:51 install_rpm.sh|[116/217]: preferences-1.0.1-8.i386.rpm|<:DEBUG>
11/09/2012 01:24:51 install_rpm.sh|[117/217]: compat-db-4.1.25-9.i386.rpm|<:DEBUG>
11/09/2012 01:24:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/compat-db-4.1.25-9.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:57 install_rpm.sh|[118/217]: compat-libstdc++-296-2.96-132.7.2.i386.rpm|<:DEBUG>
11/09/2012 01:24:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/compat-libstdc++-296-2.96-132.7.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:57 install_rpm.sh|[119/217]: compat-libstdc++-33-3.2.3-47.3.i386.rpm|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/compat-libstdc++-33-3.2.3-47.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|[120/217]: dos2unix-3.1-21.2.i386.rpm|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/dos2unix-3.1-21.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|[121/217]: dosfstools-2.8-18.i386.rpm|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/dosfstools-2.8-18.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|[122/217]: eject-2.0.13-11.i386.rpm|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/eject-2.0.13-11.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|[123/217]: elfutils-0.97.1-5.i386.rpm|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/elfutils-0.97.1-5.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:58 install_rpm.sh|[124/217]: attr-2.4.16-3.1.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/attr-2.4.16-3.1.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:59 install_rpm.sh|[125/217]: acl-2.2.23-5.4.el4.i386.rpm|<:DEBUG>
11/09/2012 01:24:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/acl-2.2.23-5.4.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:59 install_rpm.sh|[126/217]: libtool-libs-1.5.6-4.EL4.2.i386.rpm|<:DEBUG>
11/09/2012 01:24:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libtool-libs-1.5.6-4.EL4.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:24:59 install_rpm.sh|[127/217]: lsof-4.72-1.4.i386.rpm|<:DEBUG>
11/09/2012 01:25:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/lsof-4.72-1.4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:00 install_rpm.sh|[128/217]: bzip2-1.0.2-14.el4_7.i386.rpm|<:DEBUG>
11/09/2012 01:25:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/bzip2-1.0.2-14.el4_7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:00 install_rpm.sh|[129/217]: crontabs-1.10-7.noarch.rpm|<:DEBUG>
11/09/2012 01:25:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/crontabs-1.10-7.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:00 install_rpm.sh|[130/217]: fior-0.99.1-2.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:00 install_rpm.sh|[131/217]: java-provides-1.0.0.2-0.i386.rpm|<:DEBUG>
11/09/2012 01:25:02 install_rpm.sh|[132/217]: mt-st-0.8-1.i386.rpm|<:DEBUG>
11/09/2012 01:25:02 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/mt-st-0.8-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:02 install_rpm.sh|[133/217]: nc-1.10-22.i386.rpm|<:DEBUG>
11/09/2012 01:25:02 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/nc-1.10-22.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:02 install_rpm.sh|[134/217]: openssl096b-0.9.6b-22.46.el4_7.i386.rpm|<:DEBUG>
11/09/2012 01:25:03 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/openssl096b-0.9.6b-22.46.el4_7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:03 install_rpm.sh|[135/217]: os-ver-4.0.0.0-33.i386.rpm|<:DEBUG>
11/09/2012 01:25:03 install_rpm.sh|[136/217]: patch-2.5.4-20.i386.rpm|<:DEBUG>
11/09/2012 01:25:03 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/patch-2.5.4-20.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:03 install_rpm.sh|[137/217]: ndisc6-0.9.3-1.el4.rf.i386.rpm|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/ndisc6-0.9.3-1.el4.rf.i386.rpm: V3 DSA signature: NOKEY, key ID 6b8d79e6|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|[138/217]: logrotate-3.7.1-10.RHEL4.i386.rpm|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/logrotate-3.7.1-10.RHEL4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|[139/217]: rsync-2.6.3-1.i386.rpm|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/rsync-2.6.3-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|[140/217]: schedutils-1.4.0-2.i386.rpm|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/schedutils-1.4.0-2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|[141/217]: setarch-1.6-1.i386.rpm|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/setarch-1.6-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|[142/217]: sg3_utils-1.22-3.1.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:25:04 install_rpm.sh|Installing sg3_utils-1.22-3.1.i386.rpm with --nodeps|<:DEBUG>
11/09/2012 01:25:05 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/setarch-1.6-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:05 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/sg3_utils-1.22-3.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:05 install_rpm.sh|[143/217]: snmp-mon-0.0.0.19-17.i386.rpm|<:DEBUG>
11/09/2012 01:25:06 install_rpm.sh|(CAPTURE) warning: user tomcat does not exist - using root|<:DEBUG>
11/09/2012 01:25:06 install_rpm.sh|(CAPTURE) warning: group tomcat does not exist - using root|<:DEBUG>
11/09/2012 01:25:06 install_rpm.sh|[144/217]: star-1.5a25-8.i386.rpm|<:DEBUG>
11/09/2012 01:25:07 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/star-1.5a25-8.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:07 install_rpm.sh|[145/217]: strace-4.5.16-1.el4.2.i386.rpm|<:DEBUG>
11/09/2012 01:25:07 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/strace-4.5.16-1.el4.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:07 install_rpm.sh|[146/217]: tcl-8.4.7-4.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:08 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tcl-8.4.7-4.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:08 install_rpm.sh|[147/217]: expect-5.42.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:25:08 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/expect-5.42.1-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:08 install_rpm.sh|[148/217]: tcp_wrappers-7.6-37.4.i386.rpm|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tcp_wrappers-7.6-37.4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|[149/217]: tmpwatch-2.9.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tmpwatch-2.9.1-1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|[150/217]: traceroute-1.4a12-24.EL4.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/traceroute-1.4a12-24.EL4.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|[151/217]: unzip-5.51-10.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/unzip-5.51-10.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|[152/217]: zip-2.3-29.EL4.i386.rpm|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/zip-2.3-29.EL4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:09 install_rpm.sh|[153/217]: binutils-2.15.92.0.2-25.i386.rpm|<:DEBUG>
11/09/2012 01:25:10 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/binutils-2.15.92.0.2-25.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:10 install_rpm.sh|[154/217]: gdb-6.3.0.0-1.159.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:11 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/gdb-6.3.0.0-1.159.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:11 install_rpm.sh|[155/217]: gpm-1.20.1-71.RHEL4.i386.rpm|<:DEBUG>
11/09/2012 01:25:11 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/gpm-1.20.1-71.RHEL4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:11 install_rpm.sh|[156/217]: libxml2-2.6.16-12.7.i386.rpm|<:DEBUG>
11/09/2012 01:25:12 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libxml2-2.6.16-12.7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:12 install_rpm.sh|[157/217]: libxslt-1.1.11-1.el4_7.2.i386.rpm|<:DEBUG>
11/09/2012 01:25:13 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libxslt-1.1.11-1.el4_7.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:13 install_rpm.sh|[158/217]: make-3.80-7.EL4.i386.rpm|<:DEBUG>
11/09/2012 01:25:13 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/make-3.80-7.EL4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:13 install_rpm.sh|[159/217]: mgetty-1.1.31-14.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:14 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/mgetty-1.1.31-14.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:14 install_rpm.sh|[160/217]: bind-libs-9.2.4-30.el4_8.4.i386.rpm|<:DEBUG>
11/09/2012 01:25:14 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/bind-libs-9.2.4-30.el4_8.4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:14 install_rpm.sh|[161/217]: bind-utils-9.2.4-30.el4_8.4.i386.rpm|<:DEBUG>
11/09/2012 01:25:15 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/bind-utils-9.2.4-30.el4_8.4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:15 install_rpm.sh|[162/217]: curl-7.12.1-11.1.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:15 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/curl-7.12.1-11.1.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:15 install_rpm.sh|[163/217]: pdksh-5.2.14-30.6.i386.rpm|<:DEBUG>
11/09/2012 01:25:16 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/pdksh-5.2.14-30.6.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:16 install_rpm.sh|[164/217]: bc-1.06-17.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:16 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/bc-1.06-17.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:16 install_rpm.sh|[165/217]: libxml2-python-2.6.16-12.7.i386.rpm|<:DEBUG>
11/09/2012 01:25:16 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libxml2-python-2.6.16-12.7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:16 install_rpm.sh|[166/217]: jdk-1.6.0_17-fcs.i586.rpm|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE) Unpacking JAR files...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  rt.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  jsse.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  charsets.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  tools.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  localedata.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  plugin.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  javaws.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE)  deploy.jar...|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|[167/217]: nscd-2.3.4-2.41.i386.rpm|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/nscd-2.3.4-2.41.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:35 install_rpm.sh|[168/217]: ntp-4.2.0.a.20040617-8.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:36 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/ntp-4.2.0.a.20040617-8.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:36 install_rpm.sh|[169/217]: stunnel-4.05-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:36 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/stunnel-4.05-3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:36 install_rpm.sh|[170/217]: sysreport-1.3.15-8.noarch.rpm|<:DEBUG>
11/09/2012 01:25:37 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/sysreport-1.3.15-8.noarch.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:37 install_rpm.sh|[171/217]: tcsh-6.13-10.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:37 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tcsh-6.13-10.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:37 install_rpm.sh|[172/217]: tftp-0.39-3.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:37 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tftp-0.39-3.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:37 install_rpm.sh|[173/217]: time-1.7-25.i386.rpm|<:DEBUG>
11/09/2012 01:25:38 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/time-1.7-25.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:38 install_rpm.sh|[174/217]: tomcat-6.0.20-0.i386.rpm|<:DEBUG>
11/09/2012 01:25:39 install_rpm.sh|(CAPTURE) /bin/chown: `tomcat:tomcat': invalid user|<:DEBUG>
11/09/2012 01:25:39 install_rpm.sh|[175/217]: activation-1.0.0-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:39 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/activation.jar' to `/usr/local/thirdparty/java/activation.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:39 install_rpm.sh|[176/217]: cactus-12.1.5-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:41 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/cactus' to `/usr/local/thirdparty/java/cactus': No such file or directory|<:DEBUG>
11/09/2012 01:25:41 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-logging.jar' to `/usr/local/thirdparty/java/cactus/lib/commons-logging-1.0.3.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:41 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/cactus.jar' to `/usr/local/thirdparty/java/cactus/lib/cactus-1.5.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:41 install_rpm.sh|[177/217]: ecs-1.4.2-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:41 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/ecs.jar' to `/usr/local/thirdparty/java/ecs.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:41 install_rpm.sh|[178/217]: elixir-4.2-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:42 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/common/lib/elxrt.jar' to `/usr/local/thirdparty/java/elxrt.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:42 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/common/lib/itext.jar' to `/usr/local/thirdparty/java/itext.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:42 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/common/lib/license.jar' to `/usr/local/thirdparty/java/license.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:42 install_rpm.sh|[179/217]: jaxm-1.1.2-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:43 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/jaxm' to `/usr/local/thirdparty/java/jaxm': No such file or directory|<:DEBUG>
11/09/2012 01:25:43 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/jaxm-api.jar' to `/usr/local/thirdparty/java/jaxm/lib/jaxm-api.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:43 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/jaxm-runtime.jar' to `/usr/local/thirdparty/java/jaxm/lib/jaxm-runtime.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:43 install_rpm.sh|[180/217]: log4j-1.2.8-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:43 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/common/lib/log4j.jar' to `/usr/local/thirdparty/java/log4j.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:43 install_rpm.sh|[181/217]: mail-1.0.0-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/mail.jar' to `/usr/local/thirdparty/java/mail.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|[182/217]: pgjdbc-7.3.3-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/common/lib/pgjdbc.jar' to `/usr/local/thirdparty/java/pgjdbc.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|[183/217]: regexp-1.3-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/regexp.jar' to `/usr/local/thirdparty/java/regexp.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|[184/217]: saaj-1.3-4.i386.rpm|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/saaj-api.jar' to `/usr/local/thirdparty/java/saaj-api.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/saaj-impl.jar' to `/usr/local/thirdparty/java/saaj-impl.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/common/endorsed/saaj-api.jar' to `/usr/local/thirdparty/java/saaj-api.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:44 install_rpm.sh|[185/217]: struts-1.1-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/struts' to `/usr/local/thirdparty/java/struts/': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-beanutils.jar' to `/usr/local/thirdparty/java/struts/lib/commons-beanutils.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-collections.jar' to `/usr/local/thirdparty/java/struts/lib/commons-collections.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-digester.jar' to `/usr/local/thirdparty/java/struts/lib/commons-digester.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-fileupload.jar' to `/usr/local/thirdparty/java/struts/lib/commons-fileupload.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-lang.jar' to `/usr/local/thirdparty/java/struts/lib/commons-lang.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-logging.jar' to `/usr/local/thirdparty/java/struts/lib/commons-logging.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/commons-validator.jar' to `/usr/local/thirdparty/java/struts/lib/commons-validator.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/struts.jar' to `/usr/local/thirdparty/java/struts/lib/struts.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|[186/217]: unixODBC-2.2.11-1.RHEL4.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/unixODBC-2.2.11-1.RHEL4.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:46 install_rpm.sh|[187/217]: utempter-0.5.5-5.i386.rpm|<:DEBUG>
11/09/2012 01:25:47 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/utempter-0.5.5-5.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:47 install_rpm.sh|[188/217]: vim-common-6.3.046-1.el4_7.5z.i386.rpm|<:DEBUG>
11/09/2012 01:25:48 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/vim-common-6.3.046-1.el4_7.5z.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:48 install_rpm.sh|[189/217]: vim-enhanced-6.3.046-1.el4_7.5z.i386.rpm|<:DEBUG>
11/09/2012 01:25:48 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/vim-enhanced-6.3.046-1.el4_7.5z.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:48 install_rpm.sh|[190/217]: xalan-2.7.0-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:49 install_rpm.sh|(CAPTURE) cp: cannot create regular file `/usr/local/thirdparty/jakarta-tomcat/common/endorsed': No such file or directory|<:DEBUG>
11/09/2012 01:25:49 install_rpm.sh|(CAPTURE) chown: `tomcat:tomcat': invalid user|<:DEBUG>
11/09/2012 01:25:49 install_rpm.sh|[191/217]: xerces-2.6.2-3.i386.rpm|<:DEBUG>
11/09/2012 01:25:49 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/xercesImpl.jar' to `/usr/local/thirdparty/java/xercesImpl.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:49 install_rpm.sh|(CAPTURE) ln: creating symbolic link `/usr/local/thirdparty/jakarta-tomcat/shared/lib/xml-apis.jar' to `/usr/local/thirdparty/java/xml-apis.jar': No such file or directory|<:DEBUG>
11/09/2012 01:25:49 install_rpm.sh|[192/217]: xmlstarlet-1.0.1-1.i586.rpm|<:DEBUG>
11/09/2012 01:25:49 install_rpm.sh|[193/217]: at-3.1.8-82.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:50 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/at-3.1.8-82.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:50 install_rpm.sh|[194/217]: pam_krb5-2.1.17-6.el4.i386.rpm|<:DEBUG>
11/09/2012 01:25:50 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/pam_krb5-2.1.17-6.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:50 install_rpm.sh|[195/217]: policycoreutils-1.18.1-4.13.i386.rpm|<:DEBUG>
11/09/2012 01:25:50 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/policycoreutils-1.18.1-4.13.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:50 install_rpm.sh|[196/217]: screen-4.0.2-5.i386.rpm|<:DEBUG>
11/09/2012 01:25:51 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/screen-4.0.2-5.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:51 install_rpm.sh|[197/217]: sudo-1.6.7p5-30.1.3.i386.rpm|<:DEBUG>
11/09/2012 01:25:51 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/sudo-1.6.7p5-30.1.3.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:51 install_rpm.sh|[198/217]: krb5-workstation-1.3.4-62.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:52 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/krb5-workstation-1.3.4-62.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:52 install_rpm.sh|[199/217]: dhclient-3.0.1-65.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:52 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/dhclient-3.0.1-65.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:52 install_rpm.sh|[200/217]: dhcpv6_client-0.10-24_EL4.i386.rpm|<:DEBUG>
11/09/2012 01:25:53 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/dhcpv6_client-0.10-24_EL4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:53 install_rpm.sh|[201/217]: ipsec-tools-0.3.3-7.el4_7.i386.rpm|<:DEBUG>
11/09/2012 01:25:53 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/ipsec-tools-0.3.3-7.el4_7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:53 install_rpm.sh|[202/217]: dhcp-3.0.1-65.el4_8.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:54 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/dhcp-3.0.1-65.el4_8.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:54 install_rpm.sh|[203/217]: iptables-1.2.11-3.2.RHEL4.i386.rpm|<:DEBUG>
11/09/2012 01:25:55 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/iptables-1.2.11-3.2.RHEL4.i386.rpm: V3 DSA signature: NOKEY, key ID 897da07a|<:DEBUG>
11/09/2012 01:25:55 install_rpm.sh|[204/217]: iptables-ipv6-1.2.11-3.2.RHEL4.i386.rpm|<:DEBUG>
11/09/2012 01:25:56 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/iptables-ipv6-1.2.11-3.2.RHEL4.i386.rpm: V3 DSA signature: NOKEY, key ID 897da07a|<:DEBUG>
11/09/2012 01:25:56 install_rpm.sh|[205/217]: libpcap-0.8.3-12.el4_6.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:56 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/libpcap-0.8.3-12.el4_6.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:56 install_rpm.sh|[206/217]: gnupg-1.2.6-9.i386.rpm|<:DEBUG>
11/09/2012 01:25:57 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/gnupg-1.2.6-9.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:57 install_rpm.sh|[207/217]: nss_ldap-253-5.el4_7.1.i386.rpm|<:DEBUG>
11/09/2012 01:25:58 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/nss_ldap-253-5.el4_7.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:58 install_rpm.sh|[208/217]: openssh-3.9p1-11.el4_7.i386.rpm|<:DEBUG>
11/09/2012 01:25:59 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/openssh-3.9p1-11.el4_7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:25:59 install_rpm.sh|[209/217]: openssh-clients-3.9p1-11.el4_7.i386.rpm|<:DEBUG>
11/09/2012 01:26:00 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/openssh-clients-3.9p1-11.el4_7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:00 install_rpm.sh|[210/217]: netdump-0.7.16-14.i386.rpm (suppressing output)|<:DEBUG>
11/09/2012 01:26:00 install_rpm.sh|Installing netdump-0.7.16-14.i386.rpm with --nodeps (suppressing output)|<:DEBUG>
11/09/2012 01:26:00 install_rpm.sh|[211/217]: openssh-server-3.9p1-11.el4_7.i386.rpm|<:DEBUG>
11/09/2012 01:26:01 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/openssh-server-3.9p1-11.el4_7.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:01 install_rpm.sh|[212/217]: netdump-server-0.7.16-14.i386.rpm|<:DEBUG>
11/09/2012 01:26:01 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/netdump-server-0.7.16-14.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:01 install_rpm.sh|[213/217]: pciutils-2.1.99.test8-3.4.i386.rpm|<:DEBUG>
11/09/2012 01:26:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/pciutils-2.1.99.test8-3.4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:09 install_rpm.sh|[214/217]: radvd-0.7.2-10.el4.i386.rpm|<:DEBUG>
11/09/2012 01:26:09 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/radvd-0.7.2-10.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:09 install_rpm.sh|[215/217]: tcpdump-3.8.2-12.el4_6.1.i386.rpm|<:DEBUG>
11/09/2012 01:26:10 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/tcpdump-3.8.2-12.el4_6.1.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:10 install_rpm.sh|[216/217]: vixie-cron-4.1-50.el4.i386.rpm|<:DEBUG>
11/09/2012 01:26:10 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/vixie-cron-4.1-50.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:10 install_rpm.sh|[217/217]: sysstat-5.0.5-19.el4.i386.rpm|<:DEBUG>
11/09/2012 01:26:11 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/7.1.5.30000-1/RPMS/sysstat-5.0.5-19.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
11/09/2012 01:26:11 upgrade_os.sh|Generating /etc/modprobe.conf|<:INFO>
11/09/2012 01:26:11 upgrade_os.sh|Creating /partB/etc/modprobe.conf from /etc/modprobe.conf|<:DEBUG>
11/09/2012 01:26:11 upgrade_os.sh|Generate fstab for the inactive partition|<:INFO>
11/09/2012 01:26:11 upgrade_os.sh|Swapping / and /partB in /partB/etc/fstab|<:DEBUG>
11/09/2012 01:26:11 upgrade_os.sh|Calling "cp  /tmp/fstab /partB/etc/fstab"|<:DEBUG>
11/09/2012 01:26:11 upgrade_os.sh|Make the initrd image for the new OS on the inactive partition|<:INFO>
11/09/2012 01:26:11 upgrade_os.sh|mkinitrd /boot/initrd-2.6.9-78.ELsmp.img 2.6.9-78.ELsmp|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Generating needed devices on the inactive partition|<:INFO>
11/09/2012 01:26:15 upgrade_os.sh|Installing OS complete.|<:INFO>
11/09/2012 01:26:15 upgrade_os.sh|Post-install processing|<:INFO>
11/09/2012 01:26:15 upgrade_os.sh|Create directories on inactive partition|<:INFO>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p -m755 /partB/partB"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p -m755 /partB/grub"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p -m755 /partB/common"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p -m755 /partB/proc"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p -m755 /partB/sys"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p  /partB/usr/local/thirdparty"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p  /partB/usr/local/thirdparty/java"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p  /partB/mnt/floppy"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p  /partB/mnt/usb"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p  /partB/mnt/scratch"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "mkdir -p  /partB/mnt/source"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Setup password information on inactive partition|<:INFO>
11/09/2012 01:26:15 upgrade_os.sh|Calling "cp  /etc/shadow /partB/etc/shadow"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "cp  /etc/gshadow /partB/etc/gshadow"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "cp  /etc/pam.d/system-auth /partB/etc/pam.d/system-auth"|<:DEBUG>
11/09/2012 01:26:15 upgrade_os.sh|Calling "chroot /partB pwconv"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Mounting common partitions on inactive partition|<:INFO>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mount  / /partB/partB"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mount  /grub /partB/grub"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mount  /common /partB/common"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mount  /proc /partB/proc"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mount  /sys /partB/sys"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Setup APIs for Python support|<:INFO>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp  /common/rpm-archive/7.1.5.30000-1/base_scripts/iaccount.so /partB/usr/lib/python2.3"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp  /common/rpm-archive/7.1.5.30000-1/base_scripts/icertificate.so /partB/usr/lib/python2.3"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp  /common/rpm-archive/7.1.5.30000-1/base_scripts/icluster.so /partB/usr/lib/python2.3"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp  /common/rpm-archive/7.1.5.30000-1/base_scripts/ihardware.so /partB/usr/lib/python2.3"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp  /common/rpm-archive/7.1.5.30000-1/base_scripts/ilog.so /partB/usr/lib/python2.3"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp  /common/rpm-archive/7.1.5.30000-1/base_scripts/iproduct.so /partB/usr/lib/python2.3"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Copy install files to the inactive partition|<:INFO>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mkdir -p  /partB/etc/opt/cisco/install"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp -r /common/rpm-archive/7.1.5.30000-1/install/* /partB/etc/opt/cisco/install"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp  /common/rpm-archive/7.1.5.30000-1/install.conf /partB/etc/opt/cisco"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Setup APIs for Java support|<:INFO>
11/09/2012 01:26:16 upgrade_os.sh|Calling mkdir -p /partB/usr/local/platform/jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling mkdir -p /partB/usr/local/thirdparty/jakarta-tomcat/lib|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling cp -r /common/rpm-archive/7.1.5.30000-1/install/Iaccount.jar /partB/usr/local/platform/jar/Iaccount.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling ln -s /usr/local/platform/jar/Iaccount.jar /partB/usr/local/thirdparty/jakarta-tomcat/lib/Iaccount.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling cp -r /common/rpm-archive/7.1.5.30000-1/install/Icertificate.jar /partB/usr/local/platform/jar/Icertificate.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling ln -s /usr/local/platform/jar/Icertificate.jar /partB/usr/local/thirdparty/jakarta-tomcat/lib/Icertificate.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling cp -r /common/rpm-archive/7.1.5.30000-1/install/Icluster.jar /partB/usr/local/platform/jar/Icluster.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling ln -s /usr/local/platform/jar/Icluster.jar /partB/usr/local/thirdparty/jakarta-tomcat/lib/Icluster.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling cp -r /common/rpm-archive/7.1.5.30000-1/install/Ihardware.jar /partB/usr/local/platform/jar/Ihardware.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling ln -s /usr/local/platform/jar/Ihardware.jar /partB/usr/local/thirdparty/jakarta-tomcat/lib/Ihardware.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling cp -r /common/rpm-archive/7.1.5.30000-1/install/Ihistory.jar /partB/usr/local/platform/jar/Ihistory.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling ln -s /usr/local/platform/jar/Ihistory.jar /partB/usr/local/thirdparty/jakarta-tomcat/lib/Ihistory.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling cp -r /common/rpm-archive/7.1.5.30000-1/install/Iproduct.jar /partB/usr/local/platform/jar/Iproduct.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling ln -s /usr/local/platform/jar/Iproduct.jar /partB/usr/local/thirdparty/jakarta-tomcat/lib/Iproduct.jar|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Disabling root access|<:INFO>
11/09/2012 01:26:16 upgrade_os.sh|Setting up soft links for the log directories|<:INFO>
11/09/2012 01:26:16 upgrade_os.sh|Creating /partB/var/log/install link|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Creating /partB/var/log/active and /partB/var/log/inactive links|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mkdir -p  /partB/dev/pts"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Copy all scripts to the inactive partition|<:INFO>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mkdir -p  /partB/usr/local/bin"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "mkdir -p  /partB/root"|<:DEBUG>
11/09/2012 01:26:16 upgrade_os.sh|Calling "cp -r /common/rpm-archive/7.1.5.30000-1/base_scripts /partB/usr/local/bin"|<:DEBUG>
11/09/2012 01:26:17 upgrade_os.sh|Calling "cp -r /common/rpm-archive/7.1.5.30000-1/base_bin /partB/usr/local/bin"|<:DEBUG>
11/09/2012 01:26:17 upgrade_os.sh|Calling "cp -r /common/rpm-archive/7.1.5.30000-1/.security /partB/root"|<:DEBUG>
11/09/2012 01:26:18 upgrade_os.sh|Updating system information|<:INFO>
11/09/2012 01:26:18 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:18 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:18 ServerApiManager|In main with args -|upgradeSataDrivers /common/rpm-archive/7.1.5.30000-1 /common/log/install/capture.txt|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:18 ServerApiManager||Method: upgradeSataDrivers args: /common/rpm-archive/7.1.5.30000-1 /common/log/install/capture.txt|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:18 ServerApiManager|In main with args -|upgradeServeRAIDDriver /common/rpm-archive/7.1.5.30000-1|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:18 ServerApiManager||Method: upgradeServeRAIDDriver args: /common/rpm-archive/7.1.5.30000-1|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:18 upgrade_os.sh|Calling "cp -r /partB/usr/java/default /partB/usr/local/thirdparty/java/"|<:DEBUG>
11/09/2012 01:26:18 upgrade_os.sh|Calling "cp -r /partB/usr/java/jdk1.6.0_17 /partB/usr/local/thirdparty/java/"|<:DEBUG>
11/09/2012 01:26:24 upgrade_os.sh|Calling "cp -r /partB/usr/java/latest /partB/usr/local/thirdparty/java/"|<:DEBUG>
11/09/2012 01:26:24 upgrade_os.sh|Create java jdk links|<:INFO>
11/09/2012 01:26:24 upgrade_os.sh|Determine jdk RPM version on /partB|<:DEBUG>
11/09/2012 01:26:25 upgrade_os.sh|jdk RPM version is jdk1.6.0_17|<:DEBUG>
11/09/2012 01:26:25 upgrade_os.sh|Create legacy j2sdk link to jdk1.6.0_17|<:DEBUG>
11/09/2012 01:26:25 upgrade_os.sh|Create jdk link to jdk1.6.0_17|<:DEBUG>
11/09/2012 01:26:25 upgrade_os.sh|Configuring for core files|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Configuring syslogd|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Setting up the timezone|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Setting up environment profile|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Migrating ssh keys|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Migrating clock configuration|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Calling "cp -f /etc/sysconfig/clock /partB/etc/sysconfig/clock"|<:DEBUG>
11/09/2012 01:26:25 upgrade_os.sh|Migrating language configuration|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Calling "cp -f /etc/sysconfig/i18n /partB//etc/sysconfig/i18n"|<:DEBUG>
11/09/2012 01:26:25 upgrade_os.sh|Run platform upgrade scripts|<:INFO>
11/09/2012 01:26:25 upgrade_os.sh|Calling "/common/rpm-archive/7.1.5.30000-1/base_scripts/env.sh chroot /partB /common/rpm-archive/7.1.5.30000-1/.security/secure_sd_upgrade.sh"|<:DEBUG>
11/09/2012 01:26:25 create_special_accounts.sh|Creating important user accounts/groups RTMTStart|<:NOTICE>
11/09/2012 01:26:25 create_special_accounts.sh|Create sftpuser group and account|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created sftpuser group|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created sftpuser account|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Create .ssh and the config file|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Create platform group and account|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created platform group|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created platform account|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Create tomcat group and account|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created tomcat group|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created tomcat account|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Create administrator group|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created administrator group|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Create drfkeys group|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Successfully created drfkeys group|<:INFO>
11/09/2012 01:26:27 create_special_accounts.sh|Create pwrecovery account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created pwrecovery account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully updated sudoers file for pwrecovery|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create servmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created servmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create clm account  UID set to 590|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created clm account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create drf account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created drf account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create licmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created licmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create enotify account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created enotify account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create certmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created certmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create ipsecmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created ipsecmgr account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create drfuser account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created drfuser account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Create drfkeys account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Successfully created drfkeys account|<:INFO>
11/09/2012 01:26:28 create_special_accounts.sh|Creating important user accounts/groups RTMTFinish|<:NOTICE>
11/09/2012 01:26:28 create_special_accounts.sh|Create ccmbase group and account|<:INFO>
11/09/2012 01:26:29 create_special_accounts.sh|Successfully created ccmbase group|<:INFO>
11/09/2012 01:26:29 create_special_accounts.sh|Successfully created ccmservice account|<:INFO>
11/09/2012 01:26:29 create_special_accounts.sh|Create .ssh and the config file|<:INFO>
11/09/2012 01:26:29 sudoers.sh|Add tomcat SFTP script execution to /etc/sudoers|<:DEBUG>
11/09/2012 01:26:29 sudoers.sh|Tomcat config setup RTMTStart|<:NOTICE>
11/09/2012 01:26:29 sudoers.sh|Add tomcat password change script execution to /etc/sudoers|<:DEBUG>
11/09/2012 01:26:29 sudoers.sh|Add tomcat Upgrade script execution to /etc/sudoers|<:DEBUG>
11/09/2012 01:26:29 sudoers.sh|Add tomcat admin script execution to /etc/sudoers|<:DEBUG>
11/09/2012 01:26:29 sudoers.sh|Add tomcat certificate management script execution to /etc/sudoers|<:DEBUG>
11/09/2012 01:26:29 sudoers.sh|Add tomcat IPsec management script execution to /etc/sudoers|<:DEBUG>
11/09/2012 01:26:29 sudoers.sh|Tomcat config setup RTMTFinish|<:NOTICE>
11/09/2012 01:26:29 harden.sh|Disabling various keys/functions RTMTStart|<:NOTICE>
11/09/2012 01:26:29 harden.sh|Disabled CTRL-ALT-DELETE|<:INFO>
11/09/2012 01:26:29 harden.sh|/etc/ssh/sshd_config has a line for X11Forwarding|<:DEBUG>
11/09/2012 01:26:29 harden.sh|/etc/ssh/sshd_config has a line for GSSAPIAuthentication|<:DEBUG>
11/09/2012 01:26:29 harden.sh|Following line added in /etc/ssh/sshd_config|<:DEBUG>
11/09/2012 01:26:29 harden.sh|AllowTcpForwarding no|<:DEBUG>
11/09/2012 01:26:29 harden.sh|DenyUsers pwrecovery informix|<:DEBUG>
11/09/2012 01:26:29 harden.sh|Restricted single terminal for root|<:INFO>
11/09/2012 01:26:29 harden.sh|Disallow su to root|<:INFO>
11/09/2012 01:26:29 harden.sh|/etc/login.defs exists in the active partition. Copying the PASS_MIN_LEN to maintain password complexity over upgrades|<:INFO>
11/09/2012 01:26:30 harden.sh|Acquired the required value from the active side: -6-|<:INFO>
11/09/2012 01:26:30 harden.sh|Changed minimum password length to 6|<:INFO>
11/09/2012 01:26:30 harden.sh|/etc/login.defs exists in the active partition. Copying the PASS_MAX_DAYS to maintain password maximum age over upgrades|<:INFO>
11/09/2012 01:26:30 harden.sh|Acquired the required value from the active side: -99999-|<:INFO>
11/09/2012 01:26:30 harden.sh|Changed maximum password days to 99999|<:INFO>
11/09/2012 01:26:31 harden.sh|Modified LoginGraceTime to be LoginGraceTime 600|<:DEBUG>
11/09/2012 01:26:31 harden.sh|Modified SSH Protocol to be Protocol 2|<:DEBUG>
11/09/2012 01:26:31 harden.sh|/etc/ssh/sshd_config has access rights of -rw-r--r--|<:DEBUG>
11/09/2012 01:26:31 harden.sh|Disabling various keys/functions RTMTFinish|<:NOTICE>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) /common/rpm-archive/7.1.5.30000-1/.security/secure_sd_upgrade.sh: line 15: CCMSERVICE_SUDOERS: command not found|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) No login time warning message file|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Create special accounts|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Migrate special account information|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Migrating informix user password|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated sudoers file for pwrecovery|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated sudoers file for tomcat|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated sudoers file for drf|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated sudoers file for ccmservice|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Add cluster manager (clm) script execution to /etc/sudoers|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated sudoers file for clm|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Perform general hardening|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) usermod: user postgres does not exist|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully performed general hardening|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) chown: `drfuser:drfuser': invalid group|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) chmod: cannot access `/var/log/active/tomcat/logs': No such file or directory|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Generate tomcat shutdown pwd|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successful in generating tomcat shutdown pwd|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Generating tomcat shutdown password for server.xml|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successful in generating tomcat shutdown password for server.xml|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated server.xml|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Updated /usr/local/thirdparty/jakarta-tomcat/conf/server.xml with keystoreFile details|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated log configuration for tomcat|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Regenerate tomcat user|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successful in regenerating tomcat user|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Regenerate tomcat user password|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successful in regenerating tomcat users password|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Generating tomcat user and password for tomcat-users.xml|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) chown: `tomcat:tomcatmgr': invalid group|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successful in generating tomcat user and password for tomcat-users.xml|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated manager.xml|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|(CAPTURE) Successfully updated tomcat-users|<:DEBUG>
11/09/2012 01:26:31 upgrade_os.sh|Calling "/common/rpm-archive/7.1.5.30000-1/base_scripts/env.sh chroot /partB /common/rpm-archive/7.1.5.30000-1/.security/product_sd_install.sh upgrade"|<:DEBUG>
11/09/2012 01:26:31 product_sd_install.sh|Operation Mode: upgrade|<:DEBUG>
11/09/2012 01:26:31 product_sd_install.sh|Installed products: CallManager|<:DEBUG>
11/09/2012 01:26:31 create_ccm_accounts.sh|CCM Account creation RTMTStart|<:NOTICE>
11/09/2012 01:26:31 create_ccm_accounts.sh|Create CCM account and group information|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Create other CCM accounts RTMTStart|<:NOTICE>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Create application accounts.|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|*******************************************************|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Group platform already exists|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Account already exists for : servmgr|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Successfully added servmgr to group sftpuser|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Successfully added sftpuser to group platform|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|User servmgr added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Account already exists for : drf|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Successfully added drf to group sftpuser|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|User drf added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Group ccmbase already exists|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Create account : ccmbase|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Created account: ccmbase|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Successfully added ccmbase to group sftpuser|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Successfully added sftpuser to group ccmbase|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|User ccmbase added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Create account : cdp|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Created account: cdp|<:INFO>
11/09/2012 01:26:31 create_usergrp_accnt.sh|Successfully added cdp to group sftpuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Successfully added sftpuser to group ccmbase|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|User cdp added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|*******************************************************|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : database|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: database|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Successfully added database to group sftpuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|User database added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : certbase|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: certbase|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Successfully added certbase to group sftpuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|User certbase added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : ctftp|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: ctftp|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Successfully added ctftp to group sftpuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|User ctftp added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : lpm|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: lpm|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|User lpm added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created group: certuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : certuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: certuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created group: tomcatmgr|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : tomcatmgr|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: tomcatmgr|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created group: ccmsyslog|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : ccmsyslog|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: ccmsyslog|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created group: dbuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : dbuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: dbuser|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created group: dbccm|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : dbccm|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: dbccm|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created group: dbtftp|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Create account : dbtftp|<:INFO>
11/09/2012 01:26:32 create_usergrp_accnt.sh|Created account: dbtftp|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|*******************************************************|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbcmi|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbcmi|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbcmi|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbipvms|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbipvms|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbipvms|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbacserver|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbacserver|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbacserver|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbmon|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbmon|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbmon|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbent|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbent|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbent|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbcti|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbcti|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbcti|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbris|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbris|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbris|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbcapf|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbcapf|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbcapf|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dblpm|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dblpm|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dblpm|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbmibagt|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbmibagt|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbmibagt|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbipma|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbipma|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbipma|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created group: dbcef|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Create account : dbcef|<:INFO>
11/09/2012 01:26:33 create_usergrp_accnt.sh|Created account: dbcef|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|*******************************************************|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbbps|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbbps|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbbps|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbamc|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbamc|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbemweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbemweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbemweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbcarsch|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbcarsch|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbcarsch|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbadminweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbadminweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbadminweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbaxlweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbaxlweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbaxlweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbcarweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbcarweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbcarweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbdblweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbdblweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbdblweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbserviceweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbserviceweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbserviceweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbncsweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbncsweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbncsweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created group: dbpdweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Create account : dbpdweb|<:INFO>
11/09/2012 01:26:34 create_usergrp_accnt.sh|Created account: dbpdweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbrolesecurity|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbrolesecurity|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbrolesecurity|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|*******************************************************|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbrealmweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbrealmweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbrealmweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbrtmtweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbrtmtweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbrtmtweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbwebdialerweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbwebdialerweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbwebdialerweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbsoapweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbsoapweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbsoapweb|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbcdrondemand|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbcdrondemand|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbcdrondemand|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbcdragent|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbcdragent|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbcdragent|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbcdrrep|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbcdrrep|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbcdrrep|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbctlprovider|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbctlprovider|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbctlprovider|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbcsa|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbcsa|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbcsa|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbtomcat|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbtomcat|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbdhcp|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbdhcp|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbdhcp|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbdna|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbdna|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created account: dbdna|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Created group: dbdirsync|<:INFO>
11/09/2012 01:26:35 create_usergrp_accnt.sh|Create account : dbdirsync|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbdirsync|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|*******************************************************|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbdrfmaster|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbdrfmaster|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbdrfmaster|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbdrflocal|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbdrflocal|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbdrflocal|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbemapp|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbemapp|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbemapp|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dblicense|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dblicense|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dblicense|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbrtmt|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbrtmt|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbrtmt|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbtaps|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbtaps|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbtaps|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbtracecoll|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbtracecoll|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbtracecoll|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbipphone|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbipphone|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbipphone|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbcli|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbcli|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbcli|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbims|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbims|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbims|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dbuserweb|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dbuserweb|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dbuserweb|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created group: dblog4j|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Create account : dblog4j|<:INFO>
11/09/2012 01:26:36 create_usergrp_accnt.sh|Created account: dblog4j|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|*******************************************************|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created group: dbcuc|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Create account : dbcuc|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created account: dbcuc|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created group: dbsyslog|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Create account : dbsyslog|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created account: dbsyslog|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created group: dbccmivr|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Create account : dbccmivr|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created account: dbccmivr|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created group: dbdbl|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Create account : dbdbl|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created account: dbdbl|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created group: dbidp|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Create account : dbidp|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created group: dbcipc|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Create account : dbcipc|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created account: dbcipc|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created group: dbauditlog|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Create account : dbauditlog|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Created account: dbauditlog|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|******************************************|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Successfully created application accounts.|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Adding group members.|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|****************************************************|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Adding Members: tomcat to group: ccmbase|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Adding tomcat to group ccmbase|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Creating directory /var/log/active/cm, if not already present|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Setting group permissions to 777 on /var/log/active/cm|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|SFTP IN is SET :appending WX to group permissions|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|SFTP OUT is SET :appending RX to group permissions|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Adding sftpuser to group ccmbase|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Creating directory /var/log/active/platform/log, if not already present|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Setting group permissions to 777 on /var/log/active/platform/log|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/platform/log|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/trace, if not already present|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/cm/trace|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/trace|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/log, if not already present|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/cm/log|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/log|<:INFO>
11/09/2012 01:26:37 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/report, if not already present|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/cm/report|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/report|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Creating directory /usr/local/cm, if not already present|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Setting group permissions to 775 on /usr/local/cm|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Creating directory /usr/local/cm/bin, if not already present|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Setting group permissions to 775 on /usr/local/cm/bin|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/bin|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Creating directory /usr/local/cm/conf, if not already present|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Setting group permissions to 777 on /usr/local/cm/conf|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/conf|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|****************************************************|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding Members: ctftp to group: ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding ctftp to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/tftpdata, if not already present|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Setting group permissions to 644 on /var/log/active/cm/tftpdata|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/tftpdata|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding Members: ccmbase,cdp,servmgr,ccmservice, database, informix, certbase, ctftp, lpm, drf, licmgr, certmgr to group: tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding ccmbase to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding cdp to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding servmgr to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding ccmservice to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding database to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding informix to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding certbase to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding ctftp to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding lpm to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding drf to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding licmgr to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding certmgr to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Creating directory /usr/local/thirdparty/jakarta-tomcat, if not already present|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Setting group permissions to 777 on /usr/local/thirdparty/jakarta-tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|SFTP IN is SET :appending WX to group permissions|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|SFTP OUT is SET :appending RX to group permissions|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding sftpuser to group tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/thirdparty/jakarta-tomcat|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding Members: informix,dbuser,dbccm,dbtftp,dbcmi,dbipvms,dbacserver, dbmon,dbent, dbcti, dbris, dbcapf, dblpm,dbmibagt,dbipma,dbcef,dbbps, dbamc, dbemweb, dbcarsch,dbadminweb, dbaxlweb,dbcarweb,dbdblweb,dbserviceweb,dbncsweb,dbpdweb, dbrolesecurity,dbrealmweb,dbrtmtweb,dbwebdialerweb,dbsoapweb,dbcdrondemand,dbcdragent,dbcdrrep, dbctlprovider,dbcsa,dbtomcat, dbdhcp,dbdna,dbdirsync,dbdrfmaster,dbdrflocal,dbemapp, dblicense, dbrtmt,dbtaps,dbtracecoll,dbipphone,dbcli,dbims,dbuserweb,dblog4j,dbcuc,dbsyslog,dbccmivr,dbdbl,dbidp,dbcipc,dbauditlog to group: ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding informix to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbuser to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbccm to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbtftp to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbcmi to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbipvms to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbacserver to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbmon to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbent to group ccmbase|<:INFO>
11/09/2012 01:26:38 create_usergrp_accnt.sh|Adding dbcti to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbris to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbcapf to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dblpm to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbmibagt to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbipma to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbcef to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbbps to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbamc to group ccmbase|<:INFO>
11/09/2012 01:26:39 create_usergrp_accnt.sh|Adding dbemweb to group ccmbase|<:INFO>
11/09/2012 01:26:40 create_usergrp_accnt.sh|Adding dbcarsch to group ccmbase|<:INFO>
11/09/2012 01:26:43 create_usergrp_accnt.sh|Adding dbadminweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbaxlweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbcarweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbdblweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbserviceweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbncsweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbpdweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbrolesecurity to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbrealmweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbrtmtweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbwebdialerweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbsoapweb to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbcdrondemand to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbcdragent to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbcdrrep to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbctlprovider to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbcsa to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbtomcat to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbdhcp to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbdna to group ccmbase|<:INFO>
11/09/2012 01:26:44 create_usergrp_accnt.sh|Adding dbdirsync to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbdrfmaster to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbdrflocal to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbemapp to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dblicense to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbrtmt to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbtaps to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbtracecoll to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbipphone to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbcli to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbims to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding web to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dblog4j to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbcuc to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbsyslog to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding ivr to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbdbl to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbidp to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbcipc to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding dbauditlog to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Creating directory /usr/local/cm, if not already present|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Setting group permissions to 775 on /usr/local/cm|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|SFTP IN is SET :appending WX to group permissions|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|SFTP OUT is SET :appending RX to group permissions|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding sftpuser to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|****************************************************|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding Members: servmgr,drf, licmgr, enotify, certmgr to group: ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding servmgr to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding drf to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding licmgr to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding enotify to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding certmgr to group ccmbase|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding Members: certbase,ccmbase to group: certuser|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding certbase to group certuser|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding ccmbase to group certuser|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Creating directory /usr/local/cm/.security/certs, if not already present|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Setting group permissions to 770 on /usr/local/cm/.security/certs|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/.security/certs|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Creating directory /usr/local/cm/.security/keys, if not already present|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Setting group permissions to 770 on /usr/local/cm/.security/keys|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/.security/keys|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding Members: servmgr to group: tomcatmgr|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding servmgr to group tomcatmgr|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding Members: lpm,tomcat,drf,licmgr, ccmservice,sftpuser to group: ccmsyslog|<:INFO>
11/09/2012 01:26:45 create_usergrp_accnt.sh|Adding lpm to group ccmsyslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding tomcat to group ccmsyslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding drf to group ccmsyslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding licmgr to group ccmsyslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding ccmservice to group ccmsyslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding sftpuser to group ccmsyslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh||<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Creating directory /var/log/active/syslog, if not already present|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/syslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/syslog|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|****************************************************|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding Members: ccmbase,cdp,ccmservice,database,certbase,ctftp,lpm,informix to group: platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding ccmbase to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding cdp to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding ccmservice to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding database to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding certbase to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding ctftp to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding lpm to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding informix to group platform|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding Members: licmgr to group: sftpuser|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding licmgr to group sftpuser|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding Members: lpm,tomcat,ccmservice,sftpuser to group: informix|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding lpm to group informix|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding tomcat to group informix|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding ccmservice to group informix|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Adding sftpuser to group informix|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|*********************************************|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Successfully added group members|<:INFO>
11/09/2012 01:26:46 create_usergrp_accnt.sh|Changing world permissions on directories|<:INFO>
11/09/2012 01:26:46 create_ccm_accounts.sh|Successfully created CCM account and group information|<:INFO>
11/09/2012 01:26:46 create_ccm_accounts.sh|CCM Account creation RTMTFinish|<:NOTICE>
11/09/2012 01:26:46 product_sd_install.sh|Copy /root/.security/tomcat/catalina.policy.source to /usr/local/thirdparty/jakarta-tomcat/conf/catalina.policy|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Copy /root/.security/tomcat/catalina.sh.source to /usr/local/thirdparty/jakarta-tomcat/bin/catalina.sh|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Copy /root/.security/tomcat/tomcat_security_startup.sh to /home/tomcat|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Copy /root/.security/tomcat/tomcat_diagnostics.sh to /home/tomcat|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|mkdir -p /var/log/active/syslog|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|chmod 770 /var/log/active/syslog|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/boot.log|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/CallManager|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/cron|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/maillog|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/messages|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/secure|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/spooler|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/.|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|touch /var/log/active/syslog/..|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|chown -R root:ccmsyslog /var/log/active/syslog|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|total 12
drwxrwxrwx  6 ccmbase ccmbase   4096 Nov  9 01:26 cm
drwxr-xr-x  3 root    root      4096 Nov  9 01:26 platform
drwxrwx---  2 root    ccmsyslog 4096 Nov  9 01:26 syslog
total 12
drwxrwx---  2 root ccmsyslog 4096 Nov  9 01:26 .
drwxrwxrwt  5 root root      4096 Nov  9 01:26 ..
-rw-r--r--  1 root ccmsyslog    0 Nov  9 01:26 boot.log
-rw-r--r--  1 root ccmsyslog    0 Nov  9 01:26 CallManager
-rw-r--r--  1 root ccmsyslog    0 Nov  9 01:26 cron
-rw-r--r--  1 root ccmsyslog    0 Nov  9 01:26 maillog
-rw-r--r--  1 root ccmsyslog    0 Nov  9 01:26 messages
-rw-r--r--  1 root ccmsyslog    0 Nov  9 01:26 secure
-rw-r--r--  1 root ccmsyslog    0 Nov  9 01:26 spooler|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Calling /root/.security/system/upgrade_syslog_details.sh|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Updating logrotate information for syslog files|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Updating logrotate information for mgetty files|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Modified Log Level to be debug 2|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Adding logrotate_wrapper to /etc/cron.hourly|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Update syslog.conf for /var/log/active/platform/log/authenticateFile.log log file|<:DEBUG>
11/09/2012 01:26:46 set_dev_permissions|device=ttyS*|<:DEBUG>
11/09/2012 01:26:46 set_dev_permissions|group=ccmbase|<:DEBUG>
11/09/2012 01:26:46 set_dev_permissions|perms=0660|<:DEBUG>
11/09/2012 01:26:46 set_dev_permissions|Updating /etc/udev/permissions.d/40-cisco.permissions for ttyS*|<:DEBUG>
11/09/2012 01:26:46 set_dev_permissions|Updating /etc/udev/permissions.d/40-cisco.permissions for ttyUSB*|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Create /etc/sysctl.conf|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Create /etc/ld.so.conf|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Setting kernel tunables|<:DEBUG>
11/09/2012 01:26:46 product_sd_install.sh|Changing ipconntrack_max for ccm from (131072) to (131072)|<:DEBUG>
11/09/2012 01:26:47 product_sd_install.sh|Setting up auditd|<:INFO>
11/09/2012 01:26:47 product_sd_install.sh|Creating vos audit directory|<:INFO>
11/09/2012 01:26:47 product_sd_install.sh|Activating setgid on auditd|<:INFO>
11/09/2012 01:26:47 product_sd_install.sh|Copying auditd configuation to /etc|<:INFO>
11/09/2012 01:26:47 product_sd_install.sh|Copying hosts.allow and hosts.deny to /etc during auditd setup|<:INFO>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) groupadd: group platform exists|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) groupadd: group ccmbase exists|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: ccmbase: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: cdp: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: database: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: certbase: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: ctftp: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: lpm: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: certuser: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: tomcatmgr: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: ccmsyslog: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbuser: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbccm: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbtftp: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcmi: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbipvms: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbacserver: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbmon: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbent: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcti: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbris: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcapf: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dblpm: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbmibagt: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbipma: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcef: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbbps: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbamc: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbemweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcarsch: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbadminweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbaxlweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcarweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbdblweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbserviceweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbncsweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbpdweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbrolesecurity: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbrealmweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbrtmtweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbwebdialerweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbsoapweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcdrondemand: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcdragent: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcdrrep: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbctlprovider: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcsa: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbtomcat: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbdhcp: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbdna: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbdirsync: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbdrfmaster: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbdrflocal: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbemapp: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dblicense: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbrtmt: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbtaps: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbtracecoll: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbipphone: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcli: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbims: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbuserweb: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dblog4j: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcuc: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbsyslog: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbccmivr: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbdbl: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbidp: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbcipc: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: dbauditlog: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: web: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) usermod: user web does not exist|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) id: ivr: No such user|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) usermod: user ivr does not exist|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) Directing syslog to /var/log/active/syslog|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) Redirecting /dev/console to /dev/null|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) Unsetting syslog flush after every write|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) Unsetting syslog flush after every write to jakarta-tomcat logs|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) Changed permission on syslog.conf to 640|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) Add "options ip_conntrace hashsize=16384" to /etc/modprobe.conf|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|Calling "/common/rpm-archive/7.1.5.30000-1/base_scripts/env.sh chroot /partB /common/rpm-archive/7.1.5.30000-1/.security/tomcat_sd_install.sh upgrade"|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Operation Mode: upgrade|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Reset tomcat log directory|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Set tomcat permissions and ownerships|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Set permissions /var/log/active/tomcat/logs during install|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|BEGIN Setting permissions tomcat directory and files during install|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|END Setting permissions tomcat directory and files during install|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Setup Cisco ICON|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Setup robots.txt file|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Setup accessible tomcat symbolic links|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Remove unnecessary webapps|<:DEBUG>
11/09/2012 01:26:47 tomcat_sd_install.sh|Hardening permission of tomcat config files|<:INFO>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) chmod: cannot access `/usr/local/thirdparty/jakarta-tomcat/shared': No such file or directory|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|(CAPTURE) chmod: cannot access `/usr/local/thirdparty/jakarta-tomcat/conf/server.xml.ORIG': No such file or directory|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|Install chkpatch service|<:INFO>
11/09/2012 01:26:47 upgrade_os.sh|Calling "mkdir -p  /partB/usr/local/os-services/patches/scripts"|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|Calling "cp  /partB/usr/local/bin/base_scripts/chkpatch /partB/etc/rc.d/init.d"|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|Calling "/sbin/chkconfig --add chkpatch"|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|Calling "/sbin/chkconfig --level 345 chkpatch on"|<:DEBUG>
11/09/2012 01:26:47 upgrade_os.sh|Updating JRE TZ version|<:INFO>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) java.home: /usr/local/thirdparty/java/jdk1.6.0_17/jre|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) java.vendor: Sun Microsystems Inc.|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) java.version: 1.6.0_17|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) JRE time zone data version: tzdata2009m|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) Embedded time zone data version: tzdata2009p|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) Extracting files... done.|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) Renaming directories... done.|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) Validating the new time zone data... done.|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|(CAPTURE) Time zone data update is complete.|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|JRE TZ version updated successfully|<:INFO>
11/09/2012 01:26:48 upgrade_os.sh|Set up the serial console|<:INFO>
11/09/2012 01:26:48 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:48 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:48 ServerApiManager|In main with args -|DellInit chroot /partB|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:48 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:26:48 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:26:48 ServerApiManager||Method: DellInit args: chroot /partB|- current mode=HSSI_Mode completed with code [1]|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|Move disk config file to platform config directory|<:INFO>
11/09/2012 01:26:48 upgrade_os.sh|Calling "cp  /usr/local/platform/conf/disk_config.txt /partB/usr/local/platform/conf"|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|Update /partB/etc/rc.d/rc.sysinit|<:INFO>
11/09/2012 01:26:48 upgrade_os.sh|Replacing /partB/etc/rc.d/rc.sysinit|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|SWAP_NIF_IF hwmodel=VMware|<:DEBUG>
11/09/2012 01:26:48 upgrade_os.sh|Installing master RPM(s)|<:INFO>
11/09/2012 01:26:49 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:49 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:49 ServerApiManager|In main with args -|upgradeHwRpmsAndDevs /common/rpm-archive/7.1.5.30000-1|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:49 ServerApiManager|SAM_UPGRADE_HW_RPMS_AND_DEVS being called with [pre-boot /partB]|<:DEBUG>
11/09/2012 01:26:49 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:26:49 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:26:49 Serverpak|DEBUG: getting all the install pool meta data files|<:INFO>
11/09/2012 01:26:49 Serverpak|In runtime of supported args [getInstallPoolMetaFiles pre-reboot /partB]|<:INFO>
11/09/2012 01:26:49 Serverpak|getInstallPoolMetaFiles - No install_pool.meta file in /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/supported/shared/bin.|<:INFO>
11/09/2012 01:26:49 Serverpak|In runtime of VMWARE args [getInstallPoolMetaFiles pre-reboot /partB]|<:INFO>
11/09/2012 01:26:49 Serverpak|getInstallPoolMetaFiles - Found install_pool.meta file in /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin//common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin/install_pool.meta.|<:INFO>
11/09/2012 01:26:49 Serverpak|In runtime of server_implementation args [getInstallPoolMetaFiles pre-reboot /partB]|<:INFO>
11/09/2012 01:26:49 Serverpak|getInstallPoolMetaFiles - Found install_pool.meta file in /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin//common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin/install_pool.meta.|<:INFO>
11/09/2012 01:26:49 Serverpak|server_implementation shared_implementation.sh getInstallPoolMetaFiles pre-reboot /partB returns (0)|<:INFO>
11/09/2012 01:26:49 Serverpak|VMWARE shared_implementation.sh getInstallPoolMetaFiles pre-reboot /partB returns (0)|<:INFO>
11/09/2012 01:26:49 Serverpak|supported api_implementation.sh getInstallPoolMetaFiles pre-reboot /partB returns (0)|<:INFO>
11/09/2012 01:26:49 Serverpak|Found the following metaFiles: /common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/VMWARE/shared/bin/install_pool.meta
/common/rpm-archive/7.1.5.30000-1/hssi/server_implementation/shared/bin/install_pool.meta|<:INFO>
11/09/2012 01:26:49 Serverpak|Found the following contents: 100    pre-reboot    net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm
110   pre-reboot     net-snmp-5.1.2-13.el4_7.2.i386.rpm
120   pre-reboot      net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm
220 pre-reboot mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm|<:INFO>
11/09/2012 01:26:49 Serverpak|Found the following contents: |<:INFO>
11/09/2012 01:26:49 Serverpak|100    pre-reboot    net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm
11/09/2012 01:26:49 Serverpak|order:100 phase:pre-reboot pack:net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm opts:|<:INFO>
11/09/2012 01:26:49 Serverpak|Found net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm with extn: rpm rc=|<:INFO>
11/09/2012 01:26:49 Serverpak|rpm --root=/partB -ivh  ../../install_pool/net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm|<:INFO>
11/09/2012 01:26:49 Serverpak|warning: ../../install_pool/net-snmp-libs-5.1.2-13.el4_7.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e
Preparing...                ##################################################
net-snmp-libs               ##################################################|<:INFO>
11/09/2012 01:26:49 Serverpak|order:110 phase:pre-reboot pack:net-snmp-5.1.2-13.el4_7.2.i386.rpm opts:|<:INFO>
11/09/2012 01:26:49 Serverpak|Found net-snmp-5.1.2-13.el4_7.2.i386.rpm with extn: rpm rc=|<:INFO>
11/09/2012 01:26:49 Serverpak|rpm --root=/partB -ivh  ../../install_pool/net-snmp-5.1.2-13.el4_7.2.i386.rpm|<:INFO>
11/09/2012 01:26:51 Serverpak|warning: ../../install_pool/net-snmp-5.1.2-13.el4_7.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e
net-snmp                    ##################################################|<:INFO>
11/09/2012 01:26:51 Serverpak|order:120 phase:pre-reboot pack:net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm opts:|<:INFO>
11/09/2012 01:26:51 Serverpak|Found net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm with extn: rpm rc=|<:INFO>
11/09/2012 01:26:51 Serverpak|rpm --root=/partB -ivh  ../../install_pool/net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm|<:INFO>
11/09/2012 01:26:52 Serverpak|warning: ../../install_pool/net-snmp-utils-5.1.2-13.el4_7.2.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e
net-snmp-utils              ##################################################|<:INFO>
11/09/2012 01:26:52 Serverpak|order:220 phase:pre-reboot pack:mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm opts:|<:INFO>
11/09/2012 01:26:52 Serverpak|Found mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm with extn: rpm rc=|<:INFO>
11/09/2012 01:26:52 Serverpak|rpm --root=/partB -ivh  ../../install_pool/mptlinux-4.0-3.18.00.00-1.custom.rhel4.i686.rpm|<:INFO>
11/09/2012 01:26:56 Serverpak|Preparing...                ##################################################
mptlinux-4.0                ##################################################|<:INFO>
11/09/2012 01:26:56 ServerApiManager||Method: upgradeHwRpmsAndDevs args: /common/rpm-archive/7.1.5.30000-1|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:56 upgrade_os.sh|Install platform RPMS|<:INFO>
11/09/2012 01:26:56 upgrade_os.sh|-rw-r--r--  1 root root 201 Nov  9 00:05 /etc/hosts, #This file was generated by the /etc/hosts cluster manager.
#It is automatically updated as nodes are added, changed, removed from the cluster.
127.0.0.1 localhost
::1 localhost
10.20.30.10  MLPLTPUB|<:DEBUG>
11/09/2012 01:26:56 upgrade_os.sh|, |<:DEBUG>
11/09/2012 01:26:56 upgrade_os.sh|Host name is MLPLTPUB|<:DEBUG>
11/09/2012 01:26:56 upgrade_os.sh|Audit RPM platform-install-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:57 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|In main with args -|get_rpm platform-install-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|Found platform-install-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager||Method: get_rpm args: platform-install-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:57 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-install-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:57 upgrade_os.sh|Audit RPM platform-ver-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|In main with args -|get_rpm platform-ver-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|Found platform-ver-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager||Method: get_rpm args: platform-ver-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:57 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-ver-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:57 upgrade_os.sh|Audit RPM platform-script-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|In main with args -|get_rpm platform-script-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|Found platform-script-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager||Method: get_rpm args: platform-script-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:57 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-script-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:57 upgrade_os.sh|Audit RPM platform-ui-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|In main with args -|get_rpm platform-ui-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:57 ServerApiManager|Found platform-ui-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:26:57 ServerApiManager||Method: get_rpm args: platform-ui-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:57 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-ui-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:58 upgrade_os.sh|Audit RPM platform-common-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:58 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:58 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:59 ServerApiManager|In main with args -|get_rpm platform-common-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:59 ServerApiManager|Found platform-common-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:26:59 ServerApiManager||Method: get_rpm args: platform-common-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:59 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-common-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:59 upgrade_os.sh|Audit RPM platform-licensing-2.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:26:59 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:59 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:59 ServerApiManager|In main with args -|get_rpm platform-licensing-2.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:26:59 ServerApiManager|Found platform-licensing-2.0.0.0-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:26:59 ServerApiManager||Method: get_rpm args: platform-licensing-2.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:26:59 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-licensing-2.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:00 upgrade_os.sh|Audit RPM platform-drf-2.0.0.2-2.i386.rpm|<:DEBUG>
11/09/2012 01:27:00 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:00 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:00 ServerApiManager|In main with args -|get_rpm platform-drf-2.0.0.2-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:00 ServerApiManager|Found platform-drf-2.0.0.2-2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:00 ServerApiManager||Method: get_rpm args: platform-drf-2.0.0.2-2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:00 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-drf-2.0.0.2-2.i386.rpm|<:DEBUG>
11/09/2012 01:27:01 upgrade_os.sh|(CAPTURE) IP preferences file updated successfully.|<:DEBUG>
11/09/2012 01:27:01 upgrade_os.sh|Audit RPM platform-remotesupport-2.0.0.1-3.i386.rpm|<:DEBUG>
11/09/2012 01:27:01 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:01 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:01 ServerApiManager|In main with args -|get_rpm platform-remotesupport-2.0.0.1-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:01 ServerApiManager|Found platform-remotesupport-2.0.0.1-3.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:01 ServerApiManager||Method: get_rpm args: platform-remotesupport-2.0.0.1-3.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:01 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-remotesupport-2.0.0.1-3.i386.rpm|<:DEBUG>
11/09/2012 01:27:02 upgrade_os.sh|Audit RPM platform-servM-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:02 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:02 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:02 ServerApiManager|In main with args -|get_rpm platform-servM-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:02 ServerApiManager|Found platform-servM-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:02 ServerApiManager||Method: get_rpm args: platform-servM-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:02 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-servM-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:03 upgrade_os.sh|Audit RPM platform-tzdata-2009o-2.el4.i386.rpm|<:DEBUG>
11/09/2012 01:27:03 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:03 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:03 ServerApiManager|In main with args -|get_rpm platform-tzdata-2009o-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:03 ServerApiManager|Found platform-tzdata-2009o-2.el4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:03 ServerApiManager||Method: get_rpm args: platform-tzdata-2009o-2.el4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:03 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-tzdata-2009o-2.el4.i386.rpm|<:DEBUG>
11/09/2012 01:27:03 upgrade_os.sh|Audit RPM platform-sec-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:04 ServerApiManager|In main with args -|get_rpm platform-sec-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:04 ServerApiManager|Found platform-sec-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:04 ServerApiManager||Method: get_rpm args: platform-sec-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:04 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-sec-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:04 GEN003080|Successfully changed the permission of /etc/cron.d/sysstat|<:DEBUG>
11/09/2012 01:27:04 GEN003080|Successfully changed the permission of /etc/cron.hourly/remotesupport.cron|<:DEBUG>
11/09/2012 01:27:04 GEN003080|Successfully changed the permission of /etc/cron.daily/rpm|<:DEBUG>
11/09/2012 01:27:04 GEN003080|Successfully changed the permission of /etc/cron.daily/tmpwatch|<:DEBUG>
11/09/2012 01:27:04 GEN003080|Successfully changed the permission of /etc/cron.daily/tomcatDailyCron|<:DEBUG>
11/09/2012 01:27:04 GEN003520|/var/crash is not owned by user root.|<:INFO>
11/09/2012 01:27:04 GEN003520|/var/crash is not owned by group root.|<:INFO>
11/09/2012 01:27:04 GEN003520|/var/crash is more permissive than 700.|<:INFO>
11/09/2012 01:27:04 GEN004000|Executing GEN004000|<:INFO>
11/09/2012 01:27:04 GEN004000|Successfully change permission for /bin/traceroute|<:DEBUG>
11/09/2012 01:27:04 GEN004820|Executing GEN004820|<:INFO>
11/09/2012 01:27:04 GEN004820|Removing user ftp|<:DEBUG>
11/09/2012 01:27:04 GEN004820|Successfully deleted user ftp|<:INFO>
11/09/2012 01:27:04 GEN004820|Removing user operator|<:DEBUG>
11/09/2012 01:27:05 GEN004820|Successfully deleted user operator|<:INFO>
11/09/2012 01:27:05 GEN004820|Removing user mail|<:DEBUG>
11/09/2012 01:27:05 GEN004820|Successfully deleted user mail|<:INFO>
11/09/2012 01:27:05 GEN004820|Removing user lp|<:DEBUG>
11/09/2012 01:27:05 GEN004820|Successfully deleted user lp|<:INFO>
11/09/2012 01:27:05 GEN004820|NO ACTION - user anonymous does not exist|<:INFO>
11/09/2012 01:27:05 GEN005540|Executing GEN005540|<:INFO>
11/09/2012 01:27:05 GEN005540|/etc/ssh/sshd_config does not have a warning banner configured.|<:INFO>
11/09/2012 01:27:05 GEN005540|Added Banner line to /etc/ssh/sshd_config|<:INFO>
11/09/2012 01:27:05 LNX00320|Executing LNX00320|<:INFO>
11/09/2012 01:27:05 LNX00320|Removing  - user halt|<:INFO>
11/09/2012 01:27:05 LNX00320|Successfully removed user halt|<:INFO>
11/09/2012 01:27:05 LNX00320|Removing  - user shutdown|<:INFO>
11/09/2012 01:27:05 LNX00320|Successfully removed user shutdown|<:INFO>
11/09/2012 01:27:05 LNX00320|NO ACTION - user reboot does not exist|<:INFO>
11/09/2012 01:27:05 LNX00320|NO ACTION - user who does not exist|<:INFO>
11/09/2012 01:27:05 LNX00340|Executing LNX00340|<:INFO>
11/09/2012 01:27:05 LNX00340|Successfully removed user games|<:INFO>
11/09/2012 01:27:05 LNX00340|warning  Unable to remove group games|<:INFO>
11/09/2012 01:27:05 LNX00340|Successfully removed user news|<:INFO>
11/09/2012 01:27:05 LNX00340|warning  Unable to remove group news|<:INFO>
11/09/2012 01:27:05 LNX00340|Successfully removed user gopher|<:INFO>
11/09/2012 01:27:05 GEN000020|Addressing GEN000020|<:INFO>
11/09/2012 01:27:05 GEN000020|add line: ~~:S:wait:/sbin/sulogin to /etc/inittab|<:ERROR>
11/09/2012 01:27:05 GEN000540|Addressing GEN000540|<:INFO>
11/09/2012 01:27:05 GEN000540|Default PASS_MIN_DAYS in /etc/login.defs is less than one day|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for radvd is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for sftpuser is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for platform is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for tomcat is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for servmgr is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for clm is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for drf is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for licmgr is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for enotify is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for certmgr is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for ipsecmgr is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for drfuser is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for drfkeys is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for ccmservice is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for ccmbase is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for cdp is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for database is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for certbase is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for ctftp is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for lpm is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for certuser is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for tomcatmgr is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for ccmsyslog is locked or Alternate|<:INFO>
11/09/2012 01:27:05 GEN000540|passwd status (-S) for dbuser is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbccm is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbtftp is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcmi is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbipvms is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbacserver is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbmon is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbent is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcti is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbris is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcapf is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dblpm is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbmibagt is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbipma is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcef is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbbps is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbamc is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbemweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcarsch is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbadminweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbaxlweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcarweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbdblweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbserviceweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbncsweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbpdweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbrolesecurity is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbrealmweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbrtmtweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbwebdialerweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbsoapweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcdrondemand is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcdragent is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcdrrep is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbctlprovider is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcsa is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbtomcat is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbdhcp is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbdna is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbdirsync is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbdrfmaster is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbdrflocal is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbemapp is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dblicense is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbrtmt is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbtaps is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbtracecoll is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbipphone is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcli is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbims is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbuserweb is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dblog4j is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcuc is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbsyslog is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbccmivr is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbdbl is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbidp is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbcipc is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000540|passwd status (-S) for dbauditlog is locked or Alternate|<:INFO>
11/09/2012 01:27:06 GEN000480|Executing GEN000480|<:INFO>
11/09/2012 01:27:06 GEN000480|FAIL_DELAY is not set in /etc/login.defs|<:NOTICE>
11/09/2012 01:27:06 GEN000820|Addressing GEN000820|<:INFO>
11/09/2012 01:27:06 GEN000820|PASS_MIN_DAYS already set to 1 in /etc/login.defs|<:INFO>
11/09/2012 01:27:06 GEN000920|Addressing GEN000920|<:INFO>
11/09/2012 01:27:06 GEN000920|Changed /root permissions to 0700|<:INFO>
11/09/2012 01:27:06 GEN004640|Executing GEN004640|<:INFO>
11/09/2012 01:27:06 GEN004640|Commenting out decode line in /etc/aliases|<:INFO>
11/09/2012 01:27:06 upgrade_os.sh|Audit RPM platform-cm-2.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:06 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:06 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:06 ServerApiManager|In main with args -|get_rpm platform-cm-2.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:06 ServerApiManager|Found platform-cm-2.0.0.0-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:06 ServerApiManager||Method: get_rpm args: platform-cm-2.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:06 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-cm-2.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:07 upgrade_os.sh|Audit RPM platform-ipsec-1.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:07 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:07 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:07 ServerApiManager|In main with args -|get_rpm platform-ipsec-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:07 ServerApiManager|Found platform-ipsec-1.0.0.0-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:07 ServerApiManager||Method: get_rpm args: platform-ipsec-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:07 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-ipsec-1.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:07 upgrade_os.sh|(CAPTURE) IP preferences file updated successfully.|<:DEBUG>
11/09/2012 01:27:07 upgrade_os.sh|Audit RPM platform-csa-5.2.0-296.2.i386.rpm|<:DEBUG>
11/09/2012 01:27:08 ServerApiManager|In main with args -|get_rpm platform-csa-5.2.0-296.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:08 ServerApiManager|Found platform-csa-5.2.0-296.2.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:08 ServerApiManager||Method: get_rpm args: platform-csa-5.2.0-296.2.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:08 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-csa-5.2.0-296.2.i386.rpm|<:DEBUG>
11/09/2012 01:27:09 upgrade_os.sh|Audit RPM platform-api-3.0.0.0-6.i386.rpm|<:DEBUG>
11/09/2012 01:27:09 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:09 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:09 ServerApiManager|In main with args -|get_rpm platform-api-3.0.0.0-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:09 ServerApiManager|Found platform-api-3.0.0.0-6.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:09 ServerApiManager||Method: get_rpm args: platform-api-3.0.0.0-6.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:09 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-api-3.0.0.0-6.i386.rpm|<:DEBUG>
11/09/2012 01:27:09 upgrade_os.sh|Audit RPM platform-clm-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:09 ServerApiManager|In main with args -|get_rpm platform-clm-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:09 ServerApiManager|Found platform-clm-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:09 ServerApiManager||Method: get_rpm args: platform-clm-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:09 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-clm-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:10 upgrade_os.sh|(CAPTURE) IP preferences file updated successfully.|<:DEBUG>
11/09/2012 01:27:10 upgrade_os.sh|Audit RPM platform-util-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:10 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:10 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:10 ServerApiManager|In main with args -|get_rpm platform-util-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:10 ServerApiManager|Found platform-util-2.0.0.1-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:10 ServerApiManager||Method: get_rpm args: platform-util-2.0.0.1-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:10 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-util-2.0.0.1-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:10 upgrade_os.sh|Audit RPM os-services-1.2-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:10 ServerApiManager|In main with args -|get_rpm os-services-1.2-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:10 ServerApiManager|Found os-services-1.2-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:10 ServerApiManager||Method: get_rpm args: os-services-1.2-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:10 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/os-services-1.2-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:11 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
11/09/2012 01:27:11 Serverpak|IN INITIALIZE model = VMware statefile=  /usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:11 Serverpak|DEBUG: Current Directory=/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 01:27:11 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
11/09/2012 01:27:11 ServerApiManager|In main with args -|initialize|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:11 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:11 ServerApiManager|In main with args -|getHardwareAttribute HWModel|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:11 Serverpak|[VMware] retrieved from cache for key -[HWModel]-|<:INFO>
11/09/2012 01:27:11 ServerApiManager||Method: getHardwareAttribute args: HWModel|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:11 upgrade_os.sh|(CAPTURE) IP preferences file updated successfully.|<:DEBUG>
11/09/2012 01:27:11 upgrade_os.sh|Audit RPM fiostats-0.99.2-4.i386.rpm|<:DEBUG>
11/09/2012 01:27:11 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:11 ServerApiManager|In main with args -|get_rpm fiostats-0.99.2-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:11 ServerApiManager|Found fiostats-0.99.2-4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:11 ServerApiManager||Method: get_rpm args: fiostats-0.99.2-4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:11 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/fiostats-0.99.2-4.i386.rpm|<:DEBUG>
11/09/2012 01:27:12 upgrade_os.sh|Audit RPM platform-tomcat-1.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:12 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:12 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:12 ServerApiManager|In main with args -|get_rpm platform-tomcat-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:12 ServerApiManager|Found platform-tomcat-1.0.0.0-1.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:12 ServerApiManager||Method: get_rpm args: platform-tomcat-1.0.0.0-1.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:12 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/platform-tomcat-1.0.0.0-1.i386.rpm|<:DEBUG>
11/09/2012 01:27:12 upgrade_os.sh|Audit RPM kmod-updates-1-1.rh4.i386.rpm|<:DEBUG>
11/09/2012 01:27:12 ServerApiManager|In main with args -|get_rpm kmod-updates-1-1.rh4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:12 ServerApiManager|Found kmod-updates-1-1.rh4.i386.rpm in /common/rpm-archive/7.1.5.30000-1/RPMS|<:DEBUG>
11/09/2012 01:27:12 ServerApiManager||Method: get_rpm args: kmod-updates-1-1.rh4.i386.rpm /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/RPMS /common/rpm-archive/7.1.5.30000-1/HWRPMS /common/rpm-archive/7.1.2.21900-5/RPMS /common/rpm-archive/RPMS|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:12 upgrade_os.sh|Install /common/rpm-archive/7.1.5.30000-1/RPMS/kmod-updates-1-1.rh4.i386.rpm|<:DEBUG>
11/09/2012 01:27:12 upgrade_os.sh|Calling "chkconfig gpm off"|<:DEBUG>
11/09/2012 01:27:12 upgrade_os.sh|Calling "chroot /partB chkconfig smartd off"|<:DEBUG>
11/09/2012 01:27:13 ServerApiManager|In main with args -|getHardwareAttribute HWModel|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:13 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:13 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:27:13 Serverpak|[VMware] retrieved from cache for key -[HWModel]-|<:INFO>
11/09/2012 01:27:13 ServerApiManager||Method: getHardwareAttribute args: HWModel|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:13 upgrade_os.sh|Server model=VMware.|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|This server model does not have IPMI or is not an IBM server.|<:INFO>
11/09/2012 01:27:13 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:13 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:13 ServerApiManager|In main with args -|isPlatformVMware|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:13 Serverpak|In runtime of supported args [isPlatformVMware]|<:INFO>
11/09/2012 01:27:13 Serverpak|In runtime of VMWARE args [isPlatformVMware]|<:INFO>
11/09/2012 01:27:13 Serverpak|VMWARE shared_implementation.sh isPlatformVMware returns (0)|<:INFO>
11/09/2012 01:27:13 Serverpak|supported api_implementation.sh isPlatformVMware returns (0)|<:INFO>
11/09/2012 01:27:13 Serverpak|HSSI set_inDataFile_forKey_value /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file -> isPlatformVMware = 0|<:INFO>
11/09/2012 01:27:13 ServerApiManager||Method: isPlatformVMware args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:13 upgrade_os.sh|(CAPTURE) VMware: not calling chkconfig snmpd on|<:DEBUG>
11/09/2012 01:27:13 upgrade_os.sh|(CAPTURE) Configuring /etc/logrotate.d/snmpd to not restart weekly|<:DEBUG>
11/09/2012 01:27:13 upgrade_os.sh|(CAPTURE) Modifications /etc/logrotate.d/snmpd completed|<:DEBUG>
11/09/2012 01:27:13 upgrade_os.sh|Created /partB/etc/rc.d/init.d/ntpd.|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|Added NTPD to inittab|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|action type is add|<:DEBUG>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|running add|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null to section 11|<:DEBUG>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding "/partB/usr/local/bin/base_scripts/rclocalmgr.sh -commit_del"|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|Added /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null to rc.local.|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|Sourcing auditd scripts...|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|Attempting to migrate the state of auditd|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|Checking if auditd is enabled|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|auditd is stopped. Not starting auditd on /partB|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|Completed the migration attempt.|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|check cron for root, should be empty|<:INFO>
11/09/2012 01:27:13 upgrade_os.sh|Update rc.local|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /usr/local/bin/base_scripts/sd_domainname 2> /dev/null|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/sd_domainname 2> /dev/null to section 10|<:DEBUG>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/sd_domainname 2> /dev/null to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding rm -rf /etc/hwprofile > /dev/null 2>&1|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add rm -rf /etc/hwprofile > /dev/null 2>&1 to section 10|<:DEBUG>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add rm -rf /etc/hwprofile > /dev/null 2>&1 to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /usr/local/bin/base_scripts/sd_prefs -set ALL > /dev/null 2>&1|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/sd_prefs -set ALL > /dev/null 2>&1 to section 10|<:DEBUG>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/sd_prefs -set ALL > /dev/null 2>&1 to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:13 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /usr/local/platform/bin/clm/clm_ctl set install_configuration_complete yes > /dev/null 2>&1|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/platform/bin/clm/clm_ctl set install_configuration_complete yes > /dev/null 2>&1 to section 10|<:DEBUG>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/platform/bin/clm/clm_ctl set install_configuration_complete yes > /dev/null 2>&1 to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|action type is add|<:DEBUG>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|running add|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /usr/local/bin/base_scripts/install_notification_registration.sh|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/install_notification_registration.sh to section 10|<:DEBUG>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/install_notification_registration.sh to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:14 ServerApiManager|In main with args -|initialize|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:14 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:14 ServerApiManager|In main with args -|doRCLocalConfig /partB|- called file |/common/rpm-archive/7.1.5.30000-1/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:14 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:14 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:27:14 Serverpak|In runtime of supported args [doRCLocalConfig /partB]|<:INFO>
11/09/2012 01:27:14 Serverpak|In runtime of VMWARE args [doRCLocalConfig /partB]|<:INFO>
11/09/2012 01:27:14 Serverpak|In runtime of server_implementation args [doRCLocalConfig /partB]|<:INFO>
11/09/2012 01:27:14 Serverpak|DEBUG: nothing to be setup for generic implementation|<:INFO>
11/09/2012 01:27:14 Serverpak|server_implementation shared_implementation.sh doRCLocalConfig /partB returns (0)|<:INFO>
11/09/2012 01:27:14 Serverpak|VMWARE shared_implementation.sh doRCLocalConfig /partB returns (0)|<:INFO>
11/09/2012 01:27:14 Serverpak|supported api_implementation.sh doRCLocalConfig /partB returns (0)|<:INFO>
11/09/2012 01:27:14 ServerApiManager||Method: doRCLocalConfig args: /partB|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /usr/local/platform/bin/startcsa stop post-reboot 2> /dev/null|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/platform/bin/startcsa stop post-reboot 2> /dev/null to section 10|<:DEBUG>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/platform/bin/startcsa stop post-reboot 2> /dev/null to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /usr/local/bin/base_scripts/server_specific_install.sh post-reboot /common/rpm-archive/7.1.5.30000-1/RPMS 2> /dev/null|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/server_specific_install.sh post-reboot /common/rpm-archive/7.1.5.30000-1/RPMS 2> /dev/null to section 10|<:DEBUG>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /usr/local/bin/base_scripts/server_specific_install.sh post-reboot /common/rpm-archive/7.1.5.30000-1/RPMS 2> /dev/null to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Adding /etc/init.d/ciscosec start 2> /dev/null|<:INFO>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /etc/init.d/ciscosec start 2> /dev/null to section 10|<:DEBUG>
11/09/2012 01:27:14 /partB/usr/local/bin/base_scripts/rclocalmgr.sh|Add /etc/init.d/ciscosec start 2> /dev/null to /partB/etc/rc.d/rc.local complete|<:INFO>
11/09/2012 01:27:14 upgrade_os.sh|Applying workaround to detect duplicate IP addresses|<:INFO>
11/09/2012 01:27:15 upgrade_os.sh|PRODUCT_TARGET is CCM|<:INFO>
11/09/2012 01:27:15 upgrade_os.sh|PRODUCT_NAME is Cisco Unified Communications Manager|<:INFO>
11/09/2012 01:27:15 upgrade_os.sh|PRODUCT_VERSION is 7.1.5.30000-1|<:INFO>
11/09/2012 01:27:16 upgrade_os.sh|Inserting product vesion into /partB/usr/local/bin/base_scripts/productConfig.xml|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Migrate /var/log/active/installed_options|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Migrate network configuration files|<:INFO>
11/09/2012 01:27:16 upgrade_os.sh|Calling "mkdir -p -m755 /partB/etc/sysconfig/network-scripts"|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Migrating /etc/sysconfig/network-scripts/ifcfg-eth0 to /partB|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Calling "cp  /etc/sysconfig/network-scripts/ifcfg-eth0 /partB/etc/sysconfig/network-scripts/ifcfg-eth0"|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Migrating /etc/sysconfig/network to /partB|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Calling "cp  /etc/sysconfig/network /partB/etc/sysconfig/network"|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Migrating /etc/hosts to /partB|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Calling "cp  /etc/hosts /partB/etc/hosts"|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Migrating /etc/resolv.conf to /partB|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Calling "cp  /etc/resolv.conf /partB/etc/resolv.conf"|<:DEBUG>
11/09/2012 01:27:16 networkFaultTolerance.sh|-d|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Network Fault Tolerance not detected.|<:INFO>
11/09/2012 01:27:16 upgrade_os.sh|Migrate platform configuration file from active partition|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Migrating to version main/4.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Found /partB/usr/local/platform/conf/platformConfig.xml.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Copying /partB/usr/local/platform/conf/platformConfig.xml to /usr/local/platform/conf/platformConfig.xml prior to possible migration.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Populating from /partB/usr/local/platform/conf/platformConfig.xml.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Wrote 8365 bytes to /usr/local/platform/conf/platformConfig.xml.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Migrating from version main/4.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Timezone Tag found: America/Los_Angeles, nothing to migrate.|<:WARN>
11/09/2012 01:27:16 PlatformXmlUpg|Migrating application user name...|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Migrating NIC settings...|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|NIC Auto Negotiate enabled.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Removing unnecessary tag LocalHostNICSpeed|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Removing unnecessary tag LocalHostNICDuplex|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Removing obsolete NTP client data ...|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|First node in the cluster 'yes'|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Migrating primary node NTP data ...|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Migrating DNS data ...|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Removing transient tags.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Removing obsolete tags.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Setting version to main/4.|<:INFO>
11/09/2012 01:27:16 PlatformXmlUpg|Exit with return code 0.|<:INFO>
11/09/2012 01:27:16 upgrade_os.sh|chown tomcat:tomcat platformConfig.xml|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|chmod 664 platformConfig.xml|<:DEBUG>
11/09/2012 01:27:16 upgrade_os.sh|Syncing hardware clock with system clock|<:INFO>
11/09/2012 01:27:18 upgrade_os.sh|Calling the Install Wizard to update system information|<:INFO>
11/09/2012 01:27:18 InstallWizard|Platform Install:
installWizMain.c@@/main/cc_7_x_mainline/2|<:INFO>
11/09/2012 01:27:18 InstallWizard|option 2 - UPGRADE_SYS|<:INFO>
11/09/2012 01:27:18 InstallWizard|Running from local disk|<:INFO>
11/09/2012 01:27:18 InstallWizard|initializeGlobalData|<:INFO>
11/09/2012 01:27:18 InstallWizard|Populate country code select array with 240 entries|<:INFO>
11/09/2012 01:27:18 InstallWizard|Country code select array populated with 240 entries|<:INFO>
11/09/2012 01:27:18 ServerApiManager|In main with args -|initialize|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:18 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:18 ServerApiManager|In main with args -|hardware getNumberOfDisks|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:18 Serverpak|IN INITIALIZE model = VMware statefile=  /usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:18 Serverpak|DEBUG: Current Directory=/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [getNumberOfDisks]|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [expected_min_disk_size]|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh expected_min_disk_size returns (0)|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [expected_disk_units]|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh expected_disk_units returns (0)|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [required_min_disk_count]|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh required_min_disk_count returns (0)|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [required_disk1_location]|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh required_disk1_location returns (0)|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [required_disk1_size]|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of VMWARE args [required_disk1_size]|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of server_implementation args [required_disk1_size]|<:INFO>
11/09/2012 01:27:18 Serverpak|server_implementation shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:27:18 Serverpak|VMWARE shared_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh required_disk1_size returns (1)|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [required_disk1_units]|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of VMWARE args [required_disk1_units]|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of server_implementation args [required_disk1_units]|<:INFO>
11/09/2012 01:27:18 Serverpak|server_implementation shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:27:18 Serverpak|VMWARE shared_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh required_disk1_units returns (1)|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [alternate_min_disk_count]|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh alternate_min_disk_count returns (0)|<:INFO>
11/09/2012 01:27:18 Serverpak|In runtime of supported args [alternate_disk1_location]|<:INFO>
11/09/2012 01:27:18 Serverpak|supported api_implementation.sh alternate_disk1_location returns (0)|<:INFO>
11/09/2012 01:27:19 Serverpak|supported api_implementation.sh getNumberOfDisks returns (1)|<:INFO>
11/09/2012 01:27:19 Serverpak|HSSI set_inDataFile_forKey_value /usr/local/bin/hssi/shared/bin/hssi_api_state_file -> getNumberOfDisks = 1|<:INFO>
11/09/2012 01:27:19 ServerApiManager||Method: hardware args: getNumberOfDisks|- current mode=HSSI_Mode completed with code [1]|<:DEBUG>
11/09/2012 01:27:19 ServerApiManager|In main with args -|initialize|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:19 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:19 ServerApiManager|In main with args -|hardware isHardwareValid|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:19 Serverpak|IN INITIALIZE model = VMware statefile=  /usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:19 Serverpak|DEBUG: Current Directory=/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 01:27:19 ServerApiManager||Method: hardware args: isHardwareValid|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:19 ServerApiManager|In main with args -|hardware isPlatformVMware|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:19 Serverpak|In runtime of supported args [isPlatformVMware]|<:INFO>
11/09/2012 01:27:19 Serverpak|In runtime of VMWARE args [isPlatformVMware]|<:INFO>
11/09/2012 01:27:19 Serverpak|VMWARE shared_implementation.sh isPlatformVMware returns (0)|<:INFO>
11/09/2012 01:27:19 Serverpak|supported api_implementation.sh isPlatformVMware returns (0)|<:INFO>
11/09/2012 01:27:19 Serverpak|HSSI set_inDataFile_forKey_value /usr/local/bin/hssi/shared/bin/hssi_api_state_file -> isPlatformVMware = 0|<:INFO>
11/09/2012 01:27:19 ServerApiManager||Method: hardware args: isPlatformVMware|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:19 InstallWizard|found 455 entries from timezone translation file|<:INFO>
11/09/2012 01:27:19 InstallWizard|[line 5349] initializeTZ: getenv TZ='America/Los_Angeles'.|<:DEBUG>
11/09/2012 01:27:19 InstallWizard|[line 5356] initializeTZ: tzValue set to 'America/Los_Angeles'.|<:DEBUG>
11/09/2012 01:27:19 InstallWizard|runScript: Calling system("/usr/local/bin/base_scripts/sd_zoneinfo America/Los_Angeles >/common/log/install/capture.txt 2>&1")|<:DEBUG>
11/09/2012 01:27:19 InstallWizard|runScript: 0 = system("/usr/local/bin/base_scripts/sd_zoneinfo America/Los_Angeles >/common/log/install/capture.txt 2>&1")|<:DEBUG>
11/09/2012 01:27:19 InstallWizard|TZ = America/Los_Angeles : America/Los_Angeles|<:INFO>
11/09/2012 01:27:19 InstallWizard|Product List:|<:DEBUG>
11/09/2012 01:27:19 InstallWizard|    CallManager|<:DEBUG>
11/09/2012 01:27:19 InstallWizard|Start data population.|<:INFO>
11/09/2012 01:27:19 InstallWizard|Populating config from file /usr/local/platform/conf/platformConfig.xml|<:INFO>
11/09/2012 01:27:19 InstallWizard|openPlatformXml: Parse existing xml document /usr/local/platform/conf/platformConfig.xml.|<:INFO>
11/09/2012 01:27:19 InstallWizard|ApplUserUsername 'ccmadmin'|<:INFO>
11/09/2012 01:27:19 InstallWizard|NIC Auto Negotiate set to TRUE|<:INFO>
11/09/2012 01:27:19 InstallWizard|Host Name for this machine 'MLPLTPUB'|<:INFO>
11/09/2012 01:27:19 InstallWizard|Change MTU set to FALSE|<:INFO>
11/09/2012 01:27:19 InstallWizard|Is DHCP enabled for this machine 'no'|<:INFO>
11/09/2012 01:27:19 InstallWizard|Host IP0 addr for this node '10.20.30.10'|<:INFO>
11/09/2012 01:27:19 InstallWizard|Host IP0 mask for this node '255.255.255.0'|<:INFO>
11/09/2012 01:27:19 InstallWizard|Gateway for this node '10.20.30.1'|<:INFO>
11/09/2012 01:27:19 InstallWizard|Tag LocalHostDnsPrimary not found.|<:WARN>
11/09/2012 01:27:19 InstallWizard|Tag LocalHostDnsSecondary not found.|<:WARN>
11/09/2012 01:27:19 InstallWizard|LocalHostDnsSecondary duplicate of LocalHostDnsPrimary.  Value=.|<:WARN>
11/09/2012 01:27:19 InstallWizard|Value LocalHostDomain not found.|<:WARN>
11/09/2012 01:27:19 InstallWizard|First node in the cluster 'yes'|<:INFO>
11/09/2012 01:27:19 InstallWizard|Internal Error, File:installWizMain.c:8624, Function: populateFromPlatformXml(), VMware primary node MUST have external NTP server(s)|<:CRITICAL>
11/09/2012 01:27:19 upgrade_os.sh|System info not updated by InstallWizard on new partition (1)|<:ERROR>
11/09/2012 01:27:19 upgrade_manager.sh|Platform upgrade failed|<:ERROR>
11/09/2012 01:27:19 ServerApiManager|In main with args -|initHardwareLibrary|- called file |/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:19 ServerApiManager|Sam_reset being called|<:DEBUG>
11/09/2012 01:27:19 Serverpak|IN INITIALIZE model = VMware statefile=  /common/rpm-archive/7.1.5.30000-1/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:19 Serverpak|DEBUG: Current Directory=/common/rpm-archive/7.1.5.30000-1/hssi/shared/bin|<:INFO>
11/09/2012 01:27:19 upgrade_install.sh|Cleaning up download...|<:INFO>
11/09/2012 01:27:19 upgrade_install.sh|Removing /common/download/7.1.5.30000-1|<:INFO>
11/09/2012 01:27:19 upgrade_install.sh|Cleaning up rpm_archive...|<:INFO>
11/09/2012 01:27:19 upgrade_install.sh|Removing /common/rpm-archive/7.1.5.30000-1|<:INFO>
11/09/2012 01:27:22 upgrade_install.sh|CSA Status = 0|<:DEBUG>
11/09/2012 01:27:22 upgrade_install.sh|/etc/init.d/ciscosec start|<:INFO>
11/09/2012 01:27:24 upgrade_install.sh|(CAPTURE) Starting ciscosec:  [  OK  ]|<:DEBUG>
11/09/2012 01:27:24 upgrade_install.sh|IOWAIT monitor stopped|<:INFO>
11/09/2012 01:27:24 upgrade_install.sh|1|<:DEBUG>
11/09/2012 01:27:27 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
11/09/2012 01:27:27 Serverpak|IN INITIALIZE model = VMware statefile=  /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:27 Serverpak|DEBUG: Current Directory=/partB/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 01:27:27 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
11/09/2012 01:27:27 ServerApiManager|In main with args -|initialize|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:27 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:27 ServerApiManager|In main with args -|getHardwareAttribute HWModel|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:27 Serverpak|[VMware] retrieved from cache for key -[HWModel]-|<:INFO>
11/09/2012 01:27:27 ServerApiManager||Method: getHardwareAttribute args: HWModel|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:28 ServerApiManager|In main with args -|isHardwareValid|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:28 Serverpak|IN INITIALIZE model = VMware statefile=  /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:28 Serverpak|DEBUG: Current Directory=/partB/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 01:27:28 ServerApiManager||Method: isHardwareValid args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:28 ServerApiManager|In main with args -|initialize|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:28 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:28 ServerApiManager|In main with args -|getHardwareAttribute CPUSpeed|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:28 Serverpak|[3300] retrieved from cache for key -[CPUSpeed]-|<:INFO>
11/09/2012 01:27:28 ServerApiManager||Method: getHardwareAttribute args: CPUSpeed|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:28 ServerApiManager|In main with args -|getHardwareAttribute CPUCount|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:28 Serverpak|In runtime of server_implementation args [definesPath]|<:INFO>
11/09/2012 01:27:28 Serverpak|server_implementation shared_implementation.sh definesPath returns (0)|<:INFO>
11/09/2012 01:27:28 Serverpak|In runtime of VMWARE args [definesPath]|<:INFO>
11/09/2012 01:27:28 Serverpak|VMWARE shared_implementation.sh definesPath returns (0)|<:INFO>
11/09/2012 01:27:28 Serverpak|In runtime of supported args [CPUCount]|<:INFO>
11/09/2012 01:27:28 Serverpak|In runtime of VMWARE args [CPUCount]|<:INFO>
11/09/2012 01:27:28 Serverpak|In runtime of server_implementation args [CPUCount]|<:INFO>
11/09/2012 01:27:29 Serverpak|server_implementation shared_implementation.sh CPUCount returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|VMWARE shared_implementation.sh CPUCount returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|supported api_implementation.sh CPUCount returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|HSSI set_inDataFile_forKey_value /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file -> CPUCount = 1|<:INFO>
11/09/2012 01:27:29 ServerApiManager||Method: getHardwareAttribute args: CPUCount|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:29 ServerApiManager|In main with args -|initialize|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:29 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:29 ServerApiManager|In main with args -|getHardwareAttribute MEMSize|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:29 Serverpak|IN INITIALIZE model = VMware statefile=  /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:29 Serverpak|DEBUG: Current Directory=/partB/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 01:27:29 Serverpak|In runtime of supported args [MemUnits]|<:INFO>
11/09/2012 01:27:29 Serverpak|In runtime of VMWARE args [MemUnits]|<:INFO>
11/09/2012 01:27:29 Serverpak|In runtime of server_implementation args [MemUnits]|<:INFO>
11/09/2012 01:27:29 Serverpak|server_implementation shared_implementation.sh MemUnits returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|VMWARE shared_implementation.sh MemUnits returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|supported api_implementation.sh MemUnits returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|In runtime of supported args [getHardwareAttribute MEMSize]|<:INFO>
11/09/2012 01:27:29 Serverpak|In runtime of supported args [MEMSize]|<:INFO>
11/09/2012 01:27:29 Serverpak|In runtime of VMWARE args [MEMSize]|<:INFO>
11/09/2012 01:27:29 Serverpak|In runtime of server_implementation args [MEMSize]|<:INFO>
11/09/2012 01:27:29 Serverpak|server_implementation shared_implementation.sh MEMSize returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|VMWARE shared_implementation.sh MEMSize returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|supported api_implementation.sh MEMSize returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|supported api_implementation.sh getHardwareAttribute MEMSize returns (0)|<:INFO>
11/09/2012 01:27:29 Serverpak|HSSI set_inDataFile_forKey_value /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file -> MEMSize = 4096|<:INFO>
11/09/2012 01:27:29 ServerApiManager||Method: getHardwareAttribute args: MEMSize|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:30 ServerApiManager|In main with args -|initialize|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:30 ServerApiManager||Method: initialize args: |- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:30 ServerApiManager|In main with args -|getDiskSize 1|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:30 Serverpak|IN INITIALIZE model = VMware statefile=  /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file|<:INFO>
11/09/2012 01:27:30 Serverpak|DEBUG: Current Directory=/partB/usr/local/bin/hssi/shared/bin|<:INFO>
11/09/2012 01:27:30 Serverpak|In runtime of supported args [getDiskSize 1]|<:INFO>
11/09/2012 01:27:30 Serverpak|In runtime of supported args [disk_access]|<:INFO>
11/09/2012 01:27:30 Serverpak|supported api_implementation.sh disk_access returns (0)|<:INFO>
11/09/2012 01:27:30 Serverpak|In runtime of VMWARE args [getSDXDiskSize 1]|<:INFO>
11/09/2012 01:27:30 Serverpak|In runtime of server_implementation args [getProcDiskBlockSize sda]|<:INFO>
11/09/2012 01:27:30 Serverpak|server_implementation shared_implementation.sh getProcDiskBlockSize sda returns (0)|<:INFO>
11/09/2012 01:27:30 Serverpak|VMWARE shared_implementation.sh getSDXDiskSize 1 returns (0)|<:INFO>
11/09/2012 01:27:30 Serverpak|supported api_implementation.sh getDiskSize 1 returns (0)|<:INFO>
11/09/2012 01:27:30 Serverpak|HSSI set_inDataFile_forKey_value /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file -> getDiskSize 1 = 160|<:INFO>
11/09/2012 01:27:30 ServerApiManager||Method: getDiskSize args: 1|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
11/09/2012 01:27:30 ServerApiManager|In main with args -|getHardwareAttribute BIOSVer|- called file |/partB/usr/local/bin/base_scripts/server_api_manager.sh| - and current mode=HSSI_Mode |<:DEBUG>
11/09/2012 01:27:30 Serverpak|In runtime of supported args [BIOSVer]|<:INFO>
11/09/2012 01:27:30 Serverpak|In runtime of VMWARE args [BIOSVer]|<:INFO>
11/09/2012 01:27:30 Serverpak|In runtime of server_implementation args [BIOSVer]|<:INFO>
11/09/2012 01:27:30 Serverpak|server_implementation shared_implementation.sh BIOSVer returns (0)|<:INFO>
11/09/2012 01:27:30 Serverpak|VMWARE shared_implementation.sh BIOSVer returns (0)|<:INFO>
11/09/2012 01:27:30 Serverpak|supported api_implementation.sh BIOSVer returns (0)|<:INFO>
11/09/2012 01:27:30 Serverpak|HSSI set_inDataFile_forKey_value /partB/usr/local/bin/hssi/shared/bin/hssi_api_state_file -> BIOSVer = PhoenixTechnologiesLTD 6.00 07/02/2012|<:INFO>
11/09/2012 01:27:31 ServerApiManager||Method: getHardwareAttribute args: BIOSVer|- current mode=HSSI_Mode completed with code [0]|<:DEBUG>
found a ntp server error, setting up a NTP server now, will try again
From the output that you have posted it is apparent that you are attempting to upgrade on VMWare, there are several attempts that can be seen where the hardware validation failed for HP and IBM such as the following 11/09/2012 00:52:09 Serverpak|DEBUG: Mismatch Manufacturer: expected HP\|Hewlett-Packard found  VMware, Inc.|<:INFO>.
As you are probably aware, but just to clarify the point, CUCM 7.x is not supported on Virtualised platform, so I assume that you are upgrading for lab purposes.
Ordinarily in fresh installs of CUCM 8 for Virtualisation a valid or reachable NTP is required otherwise the installation cannot proceed.  As in your case the installation has detected no valid NTP source thus the upgrade fails:
Allan.
it indeed was ntp issue..i added a ntp server although it was not reachable since i am building this in a closed vmware env with no internet or outside connectivity .
