Hi community,
I want to configure ccmuser-authentication to our openLDAP-directory. The synchronisation works perfect, but the authentication fails. I had tested some attribute types of the attribute "userPassword" and see, that authentication only works, if the password is SHA-encrypted.
Unfortunately there are all user passwords md5-encrypted in our LDAP. The only option may be, that every user set his password again and we save it as a SHA-key... which is not very awesome.
Is there any documentation, possible (hidden) setting or workaround to get our CUCM using MD5?
Thanks a lot for your hints.
Greetings,
Chris
