04-24-2013 01:48 PM - edited 03-16-2019 04:59 PM
At one of our sites they have a call handler with a simple setup.
Inbound calls ring and if no answer they go to VM.
I can add a destination DN as a coverage path.
But can I make that destination DN be active via a timed schedule?
04-24-2013 01:53 PM
Sure, you can put the DN in partition that has time schedule assigned to it.
Chris
04-24-2013 02:13 PM
Hi Chris,
So for example if my call handler DN is 5500 and the destination DN for coverage path is 5501 you are saying put the destination DN 5501 in a partition with a time schedule?
04-24-2013 02:17 PM
Sure, or you can do time schdule in Unity before you even send it back to CUCM.
Chris
04-24-2013 02:37 PM
I think I need to clarify this a bit more...
So the dept with call handler 5500 receives calls normally during the day between say 8 AM until 3 PM.
From 3 PM until 5 PM they would like a coverage path.
So from 3 PM until 5 PM the dept with call handler 5501 willl be coverage for 5500.
5501 needs to otherwise be available for their own normal call flow between 8 AM and 5 PM as well.
It seems like I might need to put in place a middle man DN.
For example create 5555 that is permanently CFWDALL to 5501.
Then use 5555 as the destination DN coverage for 5500 and put 5555 in a partition with a timed schedule.
04-24-2013 03:10 PM
OK, this is ever easier.
Build a schedule in Unity defined as 8-3
Assign this schduele to the 5500 call handler
Enable Closed Transfer rule on this handler and set it to transfer to the 5501 CH
Chris
04-24-2013 03:49 PM
Right on I will start working with those features and follow up after some testing.
Thanks!
