CUCM 7.1.5 - SQL Search - Media resources registration
Hi All,
Is there a way to pull registration status for media resources from the CLI Sql query?
i the goal here is to pull a list of the unregistered media resources.
Let's say that a change will happen on the CUCM environment, by RMTM i can find the number of registered Xcode, MTP and CFB. However will give only the numbers, what i need is a list of the unregistered (or registered xcode, MTP and CFB) so i can compare before and after the change.
i think if there is a SQL query that can pull the name and the resource and its status will do it, any ideas?
Best regards,
1 REPLY 1
Gordon Ross
Engager
Engager
Registration information isn't held in the SQL database, so can't be accessed via a SQL query.
Sorry,
GTG
Please rate all helpful posts.
