CUCM 7.1 Timer Question
joshthek1
We just rolled out 7965 phones.  Under the Missed Calls Directory there appears to be a timer somewhere that keeps the line the missed call came in on before prompting the time and date of the missed call.  It appears to be defaulting to about six seconds.  If anyone could direct me to that timer I would greatly appreciate it.  Thanks,
josh
No, there is no way to change it.
Chris
5 Replies 5
Chris Deren
Josh,
Can you elaborate on your question, are you referring to how long the time/date is show on the bottom of the display when you go to call logs?
If so, I am pretty sure there is no way to adjust that as that is a phone firmware hard coded timer.
HTH,
Chris
Hi Chris and Josh,
I guess what Josh is trying to explain is that,
when you click on missed calls
There will be a list of number e.g. From 1001
inbetween the list and the softkeys there will be a "rolling screen" which shows
1. on which line the call came into.
2. time and date of the missed call
3. and total number of missed calls.
they keep rotating from 4 to 6 seconds..
Josh is that what you are looking for???
this is indeed what I was looking for.  Is there a way to shorten that, or is that indeed hardcoded in the firmware?
josh
Chris
OK, well at least I know : )
Thanks for the help
