CUCM 7.x and Unity 8.x
dalamdiz
Beginner
Beginner
I have inherited a Enterprise level phone system and I am having a hard time understanding it. Here is the issue.
A call comes in to an 800 number which is associated to an extension. The call gets passed to one person, then another, and then back to the first. I have been asked to make a change so that if both are busy, the caller will hear a played message and then the call is to be disconnected. I am at a loss as what to do to accomplish this.
4 Accepted Solutions
Thomas Dominic
Hi Jason,
You are looking at a hunt group here that does the behaviour you explained.
What you will need to do to get the new behaviour is as follows
  • Create a CTI Route Point to Unity and assign it an Extension
  • Add this extension as the third member of your hunt-group
  • In Unity create a Call Handler and Forward Routing Rule pointing to the Call Handler for the extension.
  • In the Call Handler created record the greeting, and in the next action drop down terminate the call.
This should work for you, any more details you can give as to deviations from the steps mentioned will help in a better answer.
Thomas
P.S. Please rate helpful Posts
Hi Jason
I agree with the solution provided by Thomas.
Here is how you can proceed with the solution.
===CUCM===
Under Device-->CTI Route Point-->Add New (give the Device name and other details)-->Save
When You Save it ,You'll get an option to create a DN
Create a Dummy DN No. (E.g 9999)
Forward all to Voicemail
Under Call Routing-->Royue/Hunt ...Add this CTI Route as the third memeber in the Line Group
===Unity===
Call Management-->System Call Handlers-->Add New
Give the same extension you used in the CTI Route Point (here 9999)
Edit-->Greeting-->Standard-->record the Greeting and use My personal greeting
Call Routing-->Forwarded Routing Rules--->Add New-->Display name-->Save-->Add New-->Forwarding station-->Equals--->9999(CTI Route pint extension)
I think this should help you out :-)
Vidit
P.S Please rate helpful Posts
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Jason,
Yes, this is most possible
Call Management > Call Handlers > Greetings Page > Send Caller To
After Greeting
Indicate the action that Cisco Unity performs after the greeting plays:
Take Message—Cisco Unity records a message from the caller. Click the Take Message link to view the Messages page.
Send Caller To—Cisco Unity sends the call to the destination that you select:
Call Handler—Sends the call to the call handler that you select.
Directory Handler—Sends the call to directory assistance.
Greetings Administrator—Sends the call to a conversation for changing call handler greetings over the phone.
Hang Up—Disconnects the call. Use carefully; unexpected hang-ups can appear rude to callers.
Interview Handler—Sends the call to the interview handler that you select.
Sign-In—Sends the call to the subscriber logon conversation.
Subscriber—Sends the call to the subscriber that you select.
Default: Send Caller To Hang Up.
Cheers!
Rob
Rob Huffman
Hi Jason,
I may not have explained that properly
Find the Call Handler for 4400, then go to the Greeting
page for whichever greeting you have chosen to use. Let's just
say you are using the "Standard" Greeting. On that page you will
find the "After Greeting Action" we are looking for.
Cheers!
Rob
17 Replies 17
Thomas Dominic
Hi Jason,
Thomas
Do I make these changes in the CM or in Unity? Forgive me, but I am only used to working on CME.
The first 2 steps in CM
and the last 2 in Unity
regards
Thomas
P.S. Please Rate Helpful Post
Hi Jason
===CUCM===
===Unity===
Vidit
Ok, maybe I am missing something. There is a DN already setup for this, but no CTI route. Is there a way for me to see exactly how the call is being routed?
you mean there is a DN setup in the CUCM?; what is this DN given to, if to a phone it will not help. You need to add a new dummy DN like Vidit said.
Now this new DN given to the CTI route point needs to be 3rd member of the Hunt group that currently has the other 2 phone numbers in it.
Thomas
The line (4400) is located on the 2nd button on both users phones. Does this all need to be ripped out and redone?
Thomas and Vidit,
If you configure a CTI route point with DN '9999' on the CUCM and Call Handler with extension '9999' on a Unity Connection, you do not need the 'Forward Routing Rule for extension 9999 ? The call handler will be automatically selected, when a 'CTI route point' comes in with an extension 'x' and a call handler in the unity has the same extension 'x'. I remember this is the behavior on Unity Connection.
Is it not the same with Unity ?
Guru, it works that way in Unity Connection, not sure about Unity; I guess Vidit would know, being the Unity expert here.... will need to try it out to be sure.. again upto Jason, gues he can easily try both out...
Guru,
If I understand your question, you are asking:
If I use the EXTENSION field on the Call Handler, do I need to use a ROUTING RULE in Unity?
This is the same in both Unity Connection and Unity.  If you program the extension field on a Call Handler then you do not need to use a routing rule.  You would configure the CTI Route Point to CFwd that DN to Unity and the extension will be matched in Unity...assuming the correct VM profile is assigned at the line level in CUCM on the CTI Route Point and so forth.  I actually prefer this method vs. the use of routing rules but that's just me.
Hailey
Please rate helpful posts!
Message was edited by: David Hailey To clarify, I should say that you don't need a specific (new) routing rule just for the call handler.  The default routing rules would work here.
Rob Huffman
Hi Jason,
Well, you've been getting some great help here from Thomas, Vidit, Guru and Hailey
and I've added my +5 for each of them
In your described scenario you could go a little more simply here. I would go ahead and create
a new Call Handler with the DN 4400 that can play the required Greeting and then use the
Hang-up or say Goodbye "after greeting" action.I would try to avoid the Hunt group and just use the
Forward no Answer and Forward Busy settings on the DN page for 4400 in CUCM to achieve the
"new" call routing you desire. If 4400 is on both phones then it's already ringing on each for Incoming calls
so you can just manipulate the Busy Trigger to route the call to Unity when both are busy by following the
Call Forward Busy setting to route to the Unity Pilot #.
Cheers!
Rob
Rob,
     Will what you posted, play the message and then disconnect the call without giving the caller an option to leave a message? What settings need to be modified in the call handeler in Unity?
Rob Huffman
Hi Jason,
After Greeting
Cheers!
Rob
Cisco Unity Connection Administration
8.0.2.4.0000-12
I do not have this option.
the options I have under Call Management are:
Directory Handlers
Interview Handlers
Post Greeting Recordings
Call Routing
     - Direct Routing Rules
     - Forwarded Routing Rules
