Cucm 7.X subnet mask change has no effect
arani
Hi all
The question is about changing CUCM 7.X IP subnet mask.
We are usign thi guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/ipchange/ipchg712.html#wp41994
After CUCM restart the IP subnet mask remains the same.
Ideas?
Kind regards.
Aditya Gupta
Did you tried changing the subnet mask via web-interface or the CLI ?
Also i would like to know are you using Physical Server or VMware based server  , because changing the subnet in case of VMware server would mean changing the License file.
Please find the command below to change subnet via CLI :
set network ip eth0 same-ip new-subnet-mask
I did it via web interface and via CLI.
I have a physical server.
I have used the same command.
Kind regards.
