12-17-2013 06:05 AM - edited 03-16-2019 08:54 PM
HI ,
I had installed a CUCM 7.01 version in VM Ware worstation 10 , the installation was finished successfully . I can ping the server & i can access to the CLI .but the problem when i want to open the GUI .https://x.x.x.x:8443/ccmadmin/ the web page can not be displayed .
Can you help me please to resolve this issue .
12-17-2013 09:52 AM
Hi Zakariaa,
Please try with below link and see if it's help you out
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800e1691.shtml
Nishant Savalia
12-17-2013 11:01 AM
Hi Nishant ,
Sometime i can access to the GUI and i can browse into the grafical interface for an delay 2 or 3 min ,after that the web page disappear and i can't access to it anymore as the picture bellow :
Zakaria AZZOUZ
12-17-2013 11:09 AM
Give it a shot bouncing tomcat... service in charge of the webpage
admin: 'utils service restart Cisco Tomcat'
Case sensitive...
Please Kudos/rate if this help!
12-18-2013 03:00 AM
I think my problem is with service Cisco Tomcat , When i restarted the service i can manage GUI for an delay of 2 min ( While the service is running ) . i don't know what is the problem exactly with that service :why it is become not activated all alone .
12-18-2013 04:47 AM
Hi Zakariaa,
As pointed out initially in the post cucm version 7.x is not supported on vmware. If you are running it in the lab then the only option is to provide sufficient Disk and RAM. Also, as you already have 7.0 running it would not be a bad idea to upgrade it to version 7.1.5 ( could be a step upgrade ) as the lower versions of 7.0.x and 7.1.x have numerous Tomcat related bugs.
Manish
12-19-2013 10:29 AM
Zakariaa,
Sorry I was away. Lets get to the root of this if you like.
Try this....
'Utils service restart Cisco Tomcat'
Let it run completly, it probably will crash your service... as soon its done trying to bring it up.. run...
'utils core active list'
If you find a core with a time Stamp of few minutes before... (running the reset), you must RUN
Utils core active analize
If you get mi this output I can look in to it, please make SURE your putty or SSH client has enought buffer, this output can be big.
Cheers
