1215
Enthusiast
cucm 7.x web page cannot be displayed
Hi Zakariaa,
Please try with below link and see if it's help you out
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800e1691.shtml
Nishant Savalia
Regards, Nishant Savalia
Hi Nishant ,
      Sometime i can access to the GUI and i can browse into the grafical  interface for an delay 2 or 3 min ,after that the web page disappear and  i can't access to it anymore as the picture bellow :
Zakaria AZZOUZ
Give it a shot bouncing tomcat... service in charge of the webpage
admin: 'utils service restart Cisco Tomcat'
Case sensitive...
Please Kudos/rate if this help!
   I think my problem is with service Cisco Tomcat , When i restarted the service i can manage GUI for an delay of 2 min ( While the service is running ) . i don't know what is the problem exactly with that service :why it is become not activated all alone .
Hi Zakariaa,
As pointed out initially in the post cucm version 7.x is not supported on vmware. If you are running it in the lab then the only option is to provide sufficient Disk and RAM. Also, as you already have 7.0 running it would not be a bad idea to upgrade it to version 7.1.5 ( could be a step upgrade ) as the lower versions of 7.0.x and 7.1.x have numerous Tomcat related bugs.
Manish
Highlighted
Zakariaa,
Sorry I was away. Lets get to the root of this if you like.
Try this....
'Utils service restart Cisco Tomcat'
Let it run completly, it probably will crash your service... as soon its done trying to bring it up.. run...
'utils core active list'
If you find a core with a time Stamp of few minutes before... (running the reset), you must RUN
Utils core active analize
If you get mi this output I can look in to it, please make SURE your putty or SSH client has enought buffer, this output can be big.
Cheers
Content for Community-Ad
August's Community Spotlight Awards
