07-20-2016 12:00 PM - edited 03-17-2019 07:36 AM
Guys,
I am working on a phone migration at the moment from an 8.6 cluster in mixed mode (Security mode 1) to a 11.0 cluster in non secure (security mode 0)
8.6 cluster: PHones have ITL and CTL
11.0 cluster: PHones have ITL only
I followed the consolidation procedure from here:
And phones can now move between clusters without issue. However, Ive noticed that they keep the CTL file with all the old servers in - even when registered to the new 11.0 CM.
I can see the ITLs update to the 11.0 cluster, but the CTL stays with the old names of the 8.6 cluster.
Is this going to be an issue? I believe not, but does anyone have any experience of this?
07-20-2016 02:07 PM
11.x does not have any new CTL to be installed on the phones with the 11.x servers, you'd need to remove the CTL if you don't want to have it. OR you'd need to enable mixed mode and then push that new CTL.
07-20-2016 02:27 PM
Yeah I figured as much. That's what I'm wondering though....
We don't want to run in mixed mode. So is leaving the CTL on there going to be an issue?
07-20-2016 02:29 PM
No, if you ever think that you *might* have to enable mixed mode, you can update the CTL on 8.6 with the 11.x servers, or if you're going to leave it on 11, you can just remove the CTL.
07-20-2016 02:36 PM
Ok, so there is no issue just leaving the CTL on there with the old servers, as long as we don't want to go mixed mode in future?
Problem is there will be quite a lot of phones. I wrote a perl script a long time ago to send XML key presses to the phones and delete the CTL/ITL, but I don't want to have to pull that back out to delete the CTL's if I don't have to.
07-20-2016 03:51 PM
No, right now with mixed mode set to 0, they only look at the ITL for security during registration, there are now plenty of tools from different vendors to do that, unifiedFX has one, voipintegration and uplinx as well.
