05-05-2011 02:54 PM - edited 03-16-2019 04:50 AM
Hi All,
I have installed CUCM8_0_2 and subscribed Extension mobilty in two of my 7960 phones. Everytime I am logging in to the phone phone login is successfull , followed bya phon restart .,after that phone comes up with the new extension from the device profile. Phone restarts as well whenever I am logging out.
After few search on the discussion forum and CUCM feature guide, I found that its a user locale issue. I have tried to keep all the user locales value as same and tried login and logout,but the phone is still resetting .
Can anyone suggest me if I am missing out any steps ?
Response awaited.
KA
05-05-2011 04:16 PM
There's absolutely no problem from what I can read, that's part of the login and logout process.
10. The service responds in a defined XML format to the request with a restart to load the user device profile (that indicates success) or with a failure message.
11. The application returns the correct notification to the device. The phone restarts with the user device profile.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fsem.html#wp1078613
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-06-2011 02:15 AM
Hi Java,
Thanks a lot for the reply and confirmation .
Kumarjeet
