I had CCM 4.1.3 and needed to upgrade to version 8.0(2c). I ran the DMA for CCM 7.1.2 and was able to get the tar file. The customer ordered new hardware and it came with CUCM 8.0.X System Installation DVD and System Recovery DVD. The other media that usually come with the server like Upgrade DVD is not included anymore.
Anyway, I am currently running CUCM 7.1(2a) and need to upgrade to CUCM 8.0.X.Do you know if the upgrade files are now included in the System Installation DVD?
Is upgrading to version 8.0.X as simple as going to the OS Admin Page>Software Upgrade and then running the CUCM 8.0.X System Install DVD or is the upgrade media separate and have to be ordered thru the Cisco PUT tool?
