CUCM 8.5.1 ip phone 7800
Garay Gutierrez
Hello
        I have CUCM 8.5.1.10000-26, and I need to install ip phone 7821, but I don't have the device to add it to Call Manager.
        mi question is What is the release 8.5.1 that I have to update to get this ip phone in the devices.
        and where in www.cisco.com can I found the compatibility matrix for 8.5.1 with IP Phones
     thank you very much for your help
17 Replies 17
Jaime Valencia
See here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
java
if this helps, please rate
Jaime
         thanks a lot
         very helpful
Hi Aman,
Thanks for your reply.
I have a query,
I see the download file is 1021 MB, will the following patch upload helps me to solve this?
7821/7841/7861 SIP IP Phone load signed COP file - Compatible CUCM Versions: 8.5(1)+
cmterm-78xx.10-2-1-12SR1-4.cop.sgn
Siva.
Hi Siva,
I doubt that you will get an option to add 78XX phone by uploading above firmware.
you can try that else upload latest device pack .After that u can upgrade to latest firmware.
regds,
aman
Hi Aman,
cmterm-78xx.10-2-1-12SR1-4.cop.sgn has been uploaded to cucm, but still the phone shows phone not registered.
i tried to add manually, but whats the phone type i should select ?
Please help.
Siva.
did u restart tftp service?
regds,
aamn
Yes i did.
we have pair of CUCM (publisher and subscriber), i done the installation only for cucm-pub, should i need to do this for sub too?
Cisco TftpStartedActivatedTue Dec 2 17:32:57 20140 days 00:00:09
Not required as of now.
I still doubt that you need to upload DP on PUB,restart it and 78xx should regsiter.
Do the same exercise for SUB as well.
regds,
aman
Done for SUB, but no luck.
I could not see the phone type 7821 on device default page.
Hi Aman,
Can i try your first option, since this not workout.
"you can download the device pack 8.5(1.17126) from link
https://software.cisco.com/download/release.html?i=!y&mdfid=283423434&softwareid=282074299&release=8.5(1.17122)&os=
refer table 2: compatible devices
http://www.cisco.com/web/software/282074299/114019/cmterm-devicepack8_5_1_17126_1_Release_Notes.pdf
regds,
aman"
   I installed this package cmterm-devicepack8.5.1.17122-1.cop.sgn, from link indicated by  Jaime Valencia. (select cmterm-DP 8.5.1  April 1,2014)
after succesful installation (to install in pub and sub), I reset tftp server, but it didnt work (the device exist in device default but not register)
then I had to reset the cluster (first publisher after suscriber).
after that it works fine.
and the firmware is sip78xx.10-1-1SR1-4
regards
When you are adding support for a new device , the cluster needs a reboot after installing the file. For firmware upgrade scenarios a restart of TFTP is sufficient.
Manish
upload dp in both servers and restart them
