11-09-2012 02:10 AM - edited 03-16-2019 02:05 PM
Hi experts,
I need to know if it is possibile to have a CUCM cluster version 8.5(1), which is composed by an export-unrestricted publisher and an export-restricted subscriber. What kind of technical issues can I expect from this kind of setup?
Thank you in advance.
Solved! Go to Solution.
11-09-2012 05:05 AM
The answer to that will be NO! The versions on the servers in the cluster needs to be the same. If you have a mix of restricted and un restricted then you have broken that rule, and as you know broken rules leads to broken things
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
11-09-2012 04:23 AM
I don't think that is possible.
Please remember to rate helpful responses and identify helpful or correct answers.
11-09-2012 05:05 AM
