CUCM 8.5 and Unity Connection 7.x integration
If I order CUCM 8.5, so would work Unity Connection 7.x with it?
In Cisco Unified Communications Compatibility Tool I see that CUCM 8.5 haven't compatibility with 7.x versions voicemail.
Rob Huffman
Hi Dmitriy,
Yes, you would be good to go here
Supported Version Combinations for Cisco Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Cheers!
Rob
Rob Huffman
Hi Dmitriy,
Cheers!
Rob
what about the opposite , can Unity connection 8.5 be integrated with CUCM 7?
thanks.
Hi Marco,
Yes, the reverse would also be fully supported
Cheers!
Rob
thank you
