05-27-2013 02:14 AM - edited 03-16-2019 05:31 PM
Hi all,
I have never tried auto-registration before and today I got 2 x phones to register and pickup DNs, but they have no dial tone and cannot call.
Should auto registered phones be able to call each other with bogus DNs?
I am asking because I have to replicate my customer's 8.5(1) pub in the lab (on different 7845H2 hardware) and after DRS built successfully I am now issues getting phones to register on the fake box - certificate related issues I think.. 29 days left to work it out before licencing strangles the box.
many thanks
Solved! Go to Solution.
05-27-2013 06:19 AM
So it have to be a CSS/Patition problem. Try assigning the same CSS use for for normal call to the Auto registration CSS.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
05-27-2013 04:36 AM
Hi Paul,
Did u start call manager service in CUCM server where phones are registered?
regds,
aman
05-27-2013 05:07 AM
yeah I think so... I will spend more time on it tomorrow but, I looked through serviceability and the usual suspects are activated/running
I guess if phones auto registered then CM must be enabled yeah?
05-27-2013 05:28 AM
Hi Paul,
Are you sure after auto-registration phones have a line assing? One time after a auto-registration process of more than 500 phone lines were deleted so the phoen doesn't have any line to make call.
05-27-2013 06:07 AM
I can only go on the line displays on the 7970s... i defined a range and they now show the first 2 numbers from that range.
They both say registered in CCM but have fast-busy tone only... can't call.
I wondererd if default CSS/partitions etc is enough to get them going, or if I need to assign legit numbers from the cluster dial patterns.... never played with auto-reg before.
I just need a couple of phones working for some 3rd party CA testing
05-27-2013 06:19 AM
05-27-2013 04:10 PM
I worked it out I'd changed the IP address to suit the lab environment.
I needed to clear certificates by setting 'Prepare Cluster for Rollback to pre 8.0 = true', and then restart tftp & tvs, and reboot phones. They picked up empty tftp & tvs certificates and away they went.
Found it in here: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_5_1/ipchange/ipchg851.pdf
Thanks for all the above advice guys.
05-27-2013 05:25 PM
Update to that...
I found I had changed CSS as well during trouble shooting, so thanks leosalcie that was good advice - rated. I believe I had 2 x problems stopping them. Great to have it all working I can begin testing now.
Cheers,
Paul
