CUCM 8.5 - CIPC
Ayaz Khan
Just wondering if there is a quick way to mirror an IP phone to a CIPC, I want to avoid manually adding the lines and SD to CIPC.  User wants to replicate their deskphone (DN, Speed dial, BLF) to CIPC.
I tried to supercopy the phone, but it seams that I can only copy it to the exact same phone model.
Ayaz
Jaime Valencia
Export the CIPC and then change the phone model/MAC and necessary info as appropriate and then import again.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
