CUCM 8.5 - MOH - Callers hear .wav file from beginning
joshua.gertig
We are implementing a custom MoH file that was developed by American on Hold. It's just some music and a little sales pitch. It's about 45 seconds long.
We've discovered though, that when a first caller is put on hold, they hear the .wav file from the beginning, however if a second caller is put on hold, let's say 20 seconds later, they do not hear the .wav file from the beginning, but rather come in right in the middle of the sales speech.
I was reading documentation that seemed to confirm that this is how it works.
Is there a way around this? We'd like to configure our system so that each caller that is put on hold will hear the .wav file from the beginning.
Josh
Chris Deren
Are you using unicast or multicast MOH?
Chris
Hi Joshua.
Try to remove Play continuosly flag on the  selected MOH audio source.
Carlo
Please rate all helpful posts "The more you help the more you learn"
